LUA script repeating like crazy
Reneke44
Domoticz version: 4.11780
Post by Reneke44 »
I don't really know how to describe this. I'm trying to make a script that turns on or off the living room lights, based on the sValue of a text device.
The text device is being updated by a Plex webhook. That works fine. So does my script. It just keeps repeating like crazy, where it actually should only run when the text device changes. It's really basic for the moment, but when I can get this behavior fixed I can build on from this. Please help?
This is my script:
-- Plex verlichting woonkamer
 if (string.find(otherdevices['Plex-Woonkamer'],'play') or
     string.find(otherdevices['Plex-Woonkamer'],'resume'))
 then
     commandArray['LED-strip-TV']='Off'
     commandArray['LED-strip-TV']='On'
jvdz
Domoticz version: 4.107
Re: LUA script repeating like crazy
Post by jvdz »
That's because you do not test for changed device, so with each event you will send a new event creating an endless loop.
Something like this probably will fix that:
if devicechanged['Plex-Woonkamer'] then
    if string.find(otherdevices['Plex-Woonkamer'],'play')
    or string.find(otherdevices['Plex-Woonkamer'],'resume') then
Jos
Reneke44
Post by Reneke44 »
Thank you Jos. That looks like the solution. I’m trying to learn LUA and did see the devicechanged function, but didn’t know where to insert it.
Thank you :)
