Hi, y all.
After suffering from a malfunctioning SD card ( and not beeing able to get an USB sctick working) i started buiding a new domoticz instance om my Pi. Because I was suffering from some ghost devices which kept popping op in my devices list I decided to start from scratch
I downloaded the latest Pi build, updated it and installed a clean version of Domoticz.
After installing for a while i noticed that it wasn't possilbe to save my stettings from a chrome session on mij laptop, but it worked just fine on the browser on my Pi. thinking that I would sole this later i proceed
After a day if installing end configuring my Zwave devices Domoticz just stoped working, WTF, tryd repairing teh database, no errors.
I Idiot used the malfunctioning SD card instead of the new one i had. > No worries, moved the instance from the bad to the good card and proceed.
You Guess, this didn't work. Domoticz keeps crashing, althoug the serice seems to run I don't get access to the website..
Please help... ( iI will post the loggings as soon as i'm able to get them)
Recovering database
- Domoticz version: Last Sta
Re: Recovering database
sudo service domoticz.sh status results in:
i@raspberrypi:~ $ sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Sun 2020-03-08 13:28:47 CET; 10min ago
Docs: man:systemd-sysv-generator(8)
Process: 394 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SU
mrt 08 13:28:45 raspberrypi systemd[1]: Starting LSB: Home Automation System...
mrt 08 13:28:47 raspberrypi domoticz.sh[394]: 2020-03-08 13:28:47.357 Status: D
mrt 08 13:28:47 raspberrypi domoticz.sh[394]: 2020-03-08 13:28:47.368 Status: B
mrt 08 13:28:47 raspberrypi domoticz.sh[394]: 2020-03-08 13:28:47.369 Status: S
mrt 08 13:28:47 raspberrypi domoticz.sh[394]: domoticz: Domoticz is starting up.
mrt 08 13:28:47 raspberrypi domoticz[414]: Domoticz is starting up....
mrt 08 13:28:47 raspberrypi domoticz[460]: Domoticz running...
mrt 08 13:28:47 raspberrypi systemd[1]: Started LSB: Home Automation System.
lines 1-14/14 (END)
lines 1-14/14 (END)
content of my crash.log
[New LWP 0]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
__waitpid (options=0, stat_loc=0x7ed39040, pid=465) at ../sysdeps/unix/sysv/linux/waitpid.c:30
30 ../sysdeps/unix/sysv/linux/waitpid.c: Bestand of map bestaat niet.
Id Target Id Frame
* 1 Thread 0x76ff1fb0 (LWP 460) "domoticz" __waitpid (options=0, stat_loc=0x7ed39040, pid=465) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2 Thread 0x75e0a220 (LWP 461) "Watchdog" __GI___nanosleep (remaining=0x75e09bc8, requested_time=0x75e09bc8) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
Thread 2 (Thread 0x75e0a220 (LWP 461)):
#0 __GI___nanosleep (remaining=0x75e09bc8, requested_time=0x75e09bc8) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 __GI___nanosleep (requested_time=0x75e09bc8, remaining=0x75e09bc8) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2 0x002785cc in sleep_milliseconds(long) ()
#3 0x002d8f7c in Do_Watchdog_Work() ()
#4 0x009f18fc in execute_native_thread_routine ()
#5 0x76efa494 in start_thread (arg=0x75e0a220) at pthread_create.c:486
#6 0x76d3b578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 1 (Thread 0x76ff1fb0 (LWP 460)):
#0 __waitpid (options=0, stat_loc=0x7ed39040, pid=465) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1 __waitpid (pid=465, stat_loc=0x7ed39040, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
#2 0x002d8840 in dumpstack_gdb(bool) ()
#3 0x002d8e2c in signal_handler(int, siginfo_t*, void*) ()
#4 <signal handler called>
#5 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#6 0x76c7b230 in __GI_abort () at abort.c:79
#7 0x00a1ad7c in __gnu_cxx::__verbose_terminate_handler() ()
#8 0x0097b45c in __cxxabiv1::__terminate(void (*)()) ()
#9 0x0097b4d0 in std::terminate() ()
#10 0x001f5fbc in main ()
Main thread:
[Inferior 1 (process 460) detached]
[New LWP 0]
Id Target Id Frame
Main thread:
Hi swilting.
Do I understand you correctly if I state that you stil have a good backup of the database? In that case you could reinstall Domoticz on a (different) as card and try to restore the database.
Check these howto's: https://sancla.com
The crashes could be related to plugins, first try it without of with minimal plugins and see how that works out for you. Just to be sure...
