dzVents error after upgrading to v4.11775 [Solved]
johnrwoods
Domoticz version: 2022.2
Post by johnrwoods »
I have just upgraded to v4.11775 and am now getting the following error every minute:
Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:462: bad argument #1 to 'for iterator' (table expected, got string)
I have disabled all of my event scripts but the error persists.
Any help would be appreciated.
Last edited by johnrwoods on Thursday 05 March 2020 18:29, edited 1 time in total.
Re: dzVents error after upgrading to v4.11775
johnrwoods wrote: Thursday 05 March 2020 7:24 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:462: bad argument #1 to 'for iterator' (table expected, got string)
You will only get this error if you have a syntax fault in one of your scripts like
timer = 'every minute',   -- this generates the error in line 462
timer = { 'every minute' }, -- correct syntax
Can you please double check that no active scripts are left in
/home/pi/domoticz/scripts/dzVents/scripts
or in
/home/pi/domoticz/scripts/dzVents/generated_scripts/
johnrwoods
That was it. I had:
timer = ( 'at 04:00 on sun' )
I have replaced the () with curly brackets {}.
Thank you very much.
johnrwoods
Re: dzVents error after upgrading to v4.11775 [Solved]
Solved
