Page 1 of 10
Dashticz Graphs - Features, Fixes & Updates
Posted: Saturday 29 February 2020 22:17
by clinkadink
Dashticz graphs have been updated this evening.
Fixed: undefined second Y axis added when 2 or more datasets present with the same unit of measure.
New:
groupByDevices
New graph block parameter added,
groupByDevice, allowing user to show the
live status of several devices in a single graph. Instead of the data being group by
time intervals, it is grouped by the
devices. Note, unlike other graphs, this type of graph does not report on historic data. I.e. there are no 'last', 'today', 'month' buttons.
- Spoiler: show
blocks['server_status'] = {
title: 'Server Status',
devices: [17, 18, 189, 190, 192],
groupByDevice: true,
beginAtZero: true
The feature works with device sensors such as counter, percentage and temperature.
With temperature sensors that have setpoints, it calculates whether the device is:
The office and penthouse rooms are showing red, as the temperature is
above the setpoint ...
- Spoiler: show
blocks['all_zones'] = {
title: 'Room Temperatures',
devices: [6, 11, 12, 8, 14, 9, 15, 235, 10, 13],
beginAtZero: true
Same as above, but setting
groupByDevice to
'horizontal' shows this ...
- Spoiler: show
groupByDevice: 'horizontal',
beginAtZero: true
As always, with all updates to this beta, any feedback is appreciated
Re: Dashticz Graphs - New Features, Fixes & Updates
Posted: Sunday 01 March 2020 9:59
by EdwinK
Okay, this I got to work
Posted: Monday 02 March 2020 13:05
by Ewaldharmsen
I have a problem with graphs as defined in the manual:
This works:
columns[3]['blocks'] = [
'graph_6'
But adding this has no effect:
blocks['graph_6'] = {
graphTypes : ['te', 'hu'],
legend: true
Any clue why?
Posted: Monday 02 March 2020 13:47
by HansieNL
Ewaldharmsen wrote: Monday 02 March 2020 13:05
This works:
'graph_6'
legend: true
Any clue why?
Can you try to add:
devices: [6], to the block.
For latest manual see:
https://dashticz.readthedocs.io/en/beta ... raphs.html
Posted: Monday 02 March 2020 19:45
by Ewaldharmsen
thanks! I was looking at the maste documentation
Posted: Monday 02 March 2020 20:10
by Ewaldharmsen
I now have this:
blocks['graph_5'] = {
devices: [5,11],
interval: 5,
sortDevices: true,
custom : {
"Vandaag": {
range: 'day',
filter: '24 hours',
data: {
Outside: 'd.te_5',
Inside: 'd.te_11',
Humidity: 'd.hu_5'
height : '300px'
Some other questions:
1) I have one sensor which is not always on, so for instance 6hours of data is missing for d.te_11. Tos 6 hours are then not displayed at all, also not for d.te_5. How can I prevent that?
2) I now have one button "vandaag", can I hide that button?
Posted: Monday 02 March 2020 21:25
by clinkadink
1. You can use
spanGaps
- If true, lines will be drawn between points with no or null data
- If false, points with NaN data will create a break in the line (default)
2. You can hide the buttons group for that graph by adding this to your custom.css.
[data-id='graph_5'] .graphbuttons {
display: none;
Although this means you will not be able to use other buttons such as zoom and debug. If you want to hide individual buttons, instead of the whole button group, you will need to use this.
[data-id='graph_5'] .graphbuttons:nth-child(1) {
display: none;
The number in brackets is the button number you want to hide (1 being the first on the left).
Posted: Tuesday 03 March 2020 9:24
by Ewaldharmsen
This works now, but spanGaps: doesnt do anything, I stil have a gap in my graph, even if I make it true:
devices: [Temp_Studeerkamer,Weerstation],
spanGaps: false,
legend: {
'te_5': 'Outside',
'te_11': 'Inside',
'hu_5': 'Humidity'
height : '300px'
- Working.JPG (108.66 KiB) Viewed 4914 times
But I want "today" be te default not "Last hours"
This doesn't work:
spanGaps: false,
custom : {
"24H": {
range: 'day',
filter: '24 hours',
data: {
Outside: 'd.te_5',
Inside: 'd.te_11',
Humidity: 'd.hu_5'
legend: {
'te_5': 'Outside',
'te_11': 'Inside',
'hu_5': 'Humidity'
height : '300px'
If I do the above, it places the the inside temperature and humidity on the right y-ax and the outside temperature on the left y-ax.
see this:
- custom.JPG (112.92 KiB) Viewed 4914 times
If I add CSS:
display: none;
this is the result:
- css.JPG (117.86 KiB) Viewed 4914 times
Posted: Tuesday 03 March 2020 9:44
by EdwinK
EdwinK wrote: Sunday 01 March 2020 9:59
And finally I got the 'outside vs inside temp' graph to work as well. And I feel stupid for not finding it any sooner. Forgot to change the IDX in the script. Only changed it in the devices line.
Posted: Tuesday 03 March 2020 21:08
by clinkadink
Ewaldharmsen wrote: Tuesday 03 March 2020 9:24
I cannot see any gaps in your lines, so I am not clear on what you are trying achieve.
Ensure this is in your config.js
EdwinK wrote: Tuesday 03 March 2020 9:44
It places the the inside temperature and humidity on the right y-ax and the outside temperature on the left y-ax.
If you add custom data, you don't have to specify a custom legend too. Just try legend: true.
If I add CSS this is the result:
Is that not what you wanted?
Posted: Tuesday 03 March 2020 21:09
by clinkadink
Great to hear, good catch
Posted: Wednesday 04 March 2020 9:49
by Ewaldharmsen
thank you very much!
I could not find
in the manual.
That one works now.
But the gap is there still, I highligted it in red:
- gap.JPG (160.2 KiB) Viewed 4823 times
My current code is:
blocks['temperature'] = {
spanGaps: true,
maxTicksLimit: 10,
legend: {
'te_5': 'Outside',
'te_11': 'Inside',
'hu_5': 'Humidity'
height : '300px'
Posted: Wednesday 04 March 2020 13:04
by clinkadink
Ewaldharmsen wrote: Wednesday 04 March 2020 9:49
spanGaps will span any gaps (breaks) in a line. You do not have any gaps. The graph is accurately displaying the data provided from Domoticz. Understandably, If you want the graph to accurately report on the sensor for those 6 hours, the sensor needs to be on and providing data.
Posted: Wednesday 04 March 2020 14:58
by Ewaldharmsen
clinkadink wrote: Wednesday 04 March 2020 13:04
I still quite get it. I have 2 sensors one of which is alwasy on. The other not. The data of my always-on sensor is not showing because the other sensor has missing data.
Posted: Friday 06 March 2020 22:41
by Janco
In many of the graphs above and also in my own Dashticz graphs I notice the following bugs(?):
- Humidity seems to be expressed in ºC and temperature in % (which can be solved by defining them yourselves, but still)
- beginAtZero only works for one of the axes (in case of multiple axis)
Posted: Friday 06 March 2020 22:54
by clinkadink
Janco wrote: Friday 06 March 2020 22:41
- Please post the debug log (debugButton: true), this will help trace the issue
- beginAtZero can be applied to multiple axes with custom data/options, I will also look to see if the block param can be improved
Posted: Saturday 07 March 2020 0:34
by Janco
This is the resulting file.
Don't pay too much attention to the array value for beginAtZero. I tried a simple value as well, no change.
Since not everything is documented, I sometimes use trial and error.
Log file:
block_49158.json.zip
Block definition:
- Spoiler: show
- blocks['outside_weather'] = {
debugButton: true,
title: 'Outside',
devices: [158, 161],
graphTypes: ['te', 'hu', 'ba'],
graph: ['line', 'line', 'line'],
beginAtZero: [true, true, true],
buttonsSize: 5,
buttonsText: ['1', '7'],
buttonsColor: 'green',
legend: true,
height: '185px',
lineTension: 0.4,
borderWidth: 2,
datasetColors: ['red', 'yellow', 'white'],
custom: {
"today": {
range: 'day',
filter: '24 hours',
data: {
Temperature: 'd.te_158',
Humidity: 'd.hu_158',
Pressure: 'd.ba_161'
"3 days": {
range: 'month',
filter: '14 days',
data: {
width: 12,
Posted: Saturday 07 March 2020 0:51
by clinkadink
That's your graph block from your config.js. What I meant is the debug file from the graph's 'debug button' itself.
More info can be found at this link:
https://www.domoticz.com/forum/viewtopi ... 60#p237106
Posted: Saturday 07 March 2020 8:08
by Janco
I know what mean. It's just that for some reason the debug file didn't upload (maybe because I made a draft first?).
Second attempt:
Posted: Saturday 07 March 2020 10:20
by clinkadink
Janco wrote: Saturday 07 March 2020 8:08
Thanks for the log. I think I have found the issue, if I'm right, this only applies to graphs with multiple devices, each with multidata, but no Y labels specified in the custom data. I have tested my humidity/temp devices and the correct unit of measure is displayed.
As a test, please can you try changing this ...
- Spoiler: show
"data": {
"Temperature": "d.te_158",
"Humidity": "d.hu_158",
"Pressure": "d.ba_161"
To this ...
- Spoiler: show
"data": {
Please let me know if this corrects the Y axis label issue?
