Ikea tradfri bulb: adjusting white color in Zigate
Posted: Friday 28 February 2020 13:10
by TonkaNL
I recently paired some Ikea white spectrum bulbs to Domoticz with Zigate.
https://www.ikea.com/nl/nl/p/tradfri-le ... -60408483/
The bulbs can be dimmed through Domoticz, but the white color can not be changed through domoticz. Is this correct, or am I doing something wrong?
I only see one dimmable device in Domoticz per bulb. No color adjusting device. I do not have a remote that can adjust color either.
Does anyone know a solution for this, through perhaps a script (dzvents or LUA)?
Best regards,
TonkaNL
Re: Ikea tradfri bulb: adjusting white color in Zigate
Posted: Friday 28 February 2020 13:14
by pipiche
Please le us know what is the plugin version ?
Could you also attach (not copy-paste) an export made from the plugin web admin -> tools > plugin devices raw (json)
Posted: Friday 28 February 2020 19:53
Hi Pipiche it looks like I have the same device LED1732G11 also no WarmWite level, only see the dimming switch. It was my first Zigbee device so I was happy that it already worked. I see it is not in your
compatible devices list .
My device list is attached, it is device "Hanglamp Eetkamer" , "Model":"TRADFRI bulb E27 W opal 1000lm"
I am on plugin 4.7.005
Posted: Friday 28 February 2020 23:19
by pipiche
Are we talking about that one:
https://zigbee.blakadder.com/Ikea_LED1732G11-E27.html ?
That is only dimable light, not change of white color, and the Model: TRADFRI bulb E27 W opal 1000lm match with the fact that it is only LvlControl
Posted: Saturday 29 February 2020 12:20
by TonkaNL
Hi Pipiche,
With this Ikea bulb the white balance is also changeable.
See the yellow/white/blue logo on the box.
- Bulb
- E50F01F7-26CF-4D51-9CB8-E95A0597D9EE.jpg (272.37 KiB) Viewed 1183 times
Posted: Saturday 29 February 2020 13:34
by pipiche
TonkaNL wrote: Saturday 29 February 2020 12:20
Hi Pipiche,
Could you please let me know on which version of the plugin you are ?
And indeed the 'TRADFRI bulb E27 WS opal 1000lm' should be seen as a WW color
In case you are on the latest version at least 4.7.004 or above this should work, and if it is not , please provide the log during the pairing process
Posted: Saturday 29 February 2020 13:36
by TonkaNL
The version of the plugin is 4.7.3
Pairing log is underway.
Posted: Saturday 29 February 2020 13:37
by pipiche
Please update the plugin, you need at least 4.7.004
Posted: Saturday 29 February 2020 14:10
by TonkaNL
Succes!! Tnx.
Posted: Saturday 29 February 2020 17:28
pipiche wrote: Saturday 29 February 2020 13:34
I missed one letter W vs WS ... So no color change for me.
