Ikea tradfri bulb: adjusting white color in Zigate
TonkaNL
I recently paired some Ikea white spectrum bulbs to Domoticz with Zigate.
https://www.ikea.com/nl/nl/p/tradfri-le ... -60408483/
The bulbs can be dimmed through Domoticz, but the white color can not be changed through domoticz. Is this correct, or am I doing something wrong?
I only see one dimmable device in Domoticz per bulb. No color adjusting device. I do not have a remote that can adjust color either.
Does anyone know a solution for this, through perhaps a script (dzvents or LUA)?
Best regards,
TonkaNL
Best regards,
TonkaNL
Re: Ikea tradfri bulb: adjusting white color in Zigate
Please le us know what is the plugin version ?
Could you also attach (not copy-paste) an export made from the plugin web admin -> tools > plugin devices raw (json)
- Domoticz version: 2026.3
Hi Pipiche it looks like I have the same device LED1732G11 also no WarmWite level, only see the dimming switch. It was my first Zigbee device so I was happy that it already worked. I see it is not in your compatible devices list .
My device list is attached, it is device "Hanglamp Eetkamer" , "Model":"TRADFRI bulb E27 W opal 1000lm"
I am on plugin 4.7.005
- export.json.txt
- (73.35 KiB) Downloaded 68 times
Are we talking about that one: https://zigbee.blakadder.com/Ikea_LED1732G11-E27.html ?
That is only dimable light, not change of white color, and the Model: TRADFRI bulb E27 W opal 1000lm match with the fact that it is only LvlControl
TonkaNL
Hi Pipiche,
With this Ikea bulb the white balance is also changeable.
See the yellow/white/blue logo on the box.
Could you please let me know on which version of the plugin you are ?TonkaNL wrote: Saturday 29 February 2020 12:20 Hi Pipiche,
And indeed the 'TRADFRI bulb E27 WS opal 1000lm' should be seen as a WW color
In case you are on the latest version at least 4.7.004 or above this should work, and if it is not , please provide the log during the pairing process
TonkaNL
The version of the plugin is 4.7.3
Pairing log is underway.
Please update the plugin, you need at least 4.7.004
TonkaNL
Succes!! Tnx.
I missed one letter W vs WS ... So no color change for me.pipiche wrote: Saturday 29 February 2020 13:34
