GoodWe: Get data from Semportal
Posted: Thursday 27 February 2020 21:17
I have update my lua script to extract the data from the new "Goodwe semsportal" and pass it on to Domoticz.
Questions or tips to improve the script, I'd love to hear them
hopefully the script will continue to work in the near future.
Have fun with it.
-- Created by Raymond Wiertz
-- DateTime: 2020-02-13
-- Tracking your token
-- To find out your token, you must execute the CURL command below from the command line.
-- curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login;
local UserName = ""
local Password = ""
local token = ""
local refresh_time = 180 -- secondens
local sensorSolarPanels = "solar panels" -- name of your
-- get login token
local loginCommand = string.format("curl --silent --output /dev/null --cookie-jar - -c cookie.txt -d 'account=%s&pwd=%s&code=' https://www.semsportal.com/Home/Login",UserName,Password)
-- get data from site
local getDataCommand = string.format("curl -b cookie.txt -d 'str={\"api\":\"v1/PowerStation/GetMonitorDetailByPowerstationId\",\"param\":{\"powerStationId\":\"%s\"}}&s=v1/PowerStation/GetMonitorDetailByPowerstationId' 'https://www.semsportal.com//GopsApi/Post?s=v1/PowerStation/GetMonitorDetailByPowerstationId'",token)
i=1
function isempty(s)
return s == nil or s == ''
function getExecuteCommand(command)
local f = assert(io.popen(command, 'r'))
s = assert(f:read('*a'))
f:close()
return s
function stripchars(str, chrs)
local s = str:gsub("["..chrs:gsub("%W","%%%1").."]", '')
return s
function getValue(value, searchString)
local response = ""
searchString = string.format("%q", searchString)
dummy, startPos = string.find(value, searchString )
if not(startPos == nil) then
dummy, endPos = string.find(value, ",", startPos)
response = string.sub(value, startPos, endPos-1)
response = string.gsub(response, ":", "")
response = string.gsub(response, "\"", "")
response = string.gsub(response, " ", "")
return response
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes,sec=seconds}
return difference
function UpdateDevice(device, data)
idx = otherdevices_idx[device]
if (idx == nil) then
print('** Unknown device'..device)
commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
i = i+1
difference = timedifference(otherdevices_lastupdate[sensorSolarPanels])
if (difference > refresh_time) then
getExecuteCommand(loginCommand)
local data = getExecuteCommand(getDataCommand)
--print(data)
if (isempty(data) == false) then
output_power = getValue(data, "output_power")
last_refresh_time = getValue(data, "last_refresh_time")
eDay = getValue(data, "eDay")
print("last_refresh_time :" .. last_refresh_time)
print("output_power :" .. output_power)
print("eDay :" .. eDay)
current = tonumber(stripchars(output_power, "kwhKWH"))
dayTotal = tonumber(eDay)*1000
UpdateDevice(sensorSolarPanels, current..";"..dayTotal)
Have fun with it.
