GoodWe: Get data from Semportal
CrazyFrog
Post by CrazyFrog »
I have update my lua script to extract the data from the new "Goodwe semsportal" and pass it on to Domoticz.
Questions or tips to improve the script, I'd love to hear them
-- Created by Raymond Wiertz
-- DateTime: 2020-02-13
-- Tracking your token
-- To find out your token, you must execute the CURL command below from the command line.
-- curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login;
local UserName = ""
local Password = ""
local token = ""
local refresh_time = 180 -- secondens
local sensorSolarPanels = "solar panels" -- name of your
-- get login token
local loginCommand = string.format("curl --silent --output /dev/null --cookie-jar - -c cookie.txt -d 'account=%s&pwd=%s&code=' https://www.semsportal.com/Home/Login",UserName,Password)
-- get data from site
local getDataCommand = string.format("curl -b cookie.txt -d 'str={\"api\":\"v1/PowerStation/GetMonitorDetailByPowerstationId\",\"param\":{\"powerStationId\":\"%s\"}}&s=v1/PowerStation/GetMonitorDetailByPowerstationId' 'https://www.semsportal.com//GopsApi/Post?s=v1/PowerStation/GetMonitorDetailByPowerstationId'",token)
i=1
function isempty(s)
  return s == nil or s == ''
function getExecuteCommand(command)
  local f = assert(io.popen(command, 'r'))
  s = assert(f:read('*a'))
  f:close()
  return s
function stripchars(str, chrs)
    local s = str:gsub("["..chrs:gsub("%W","%%%1").."]", '')
    return s
function getValue(value, searchString)
   local response = ""
   searchString = string.format("%q", searchString)
   dummy, startPos = string.find(value, searchString )
   if not(startPos == nil) then
      dummy, endPos = string.find(value, ",", startPos)
      response = string.sub(value, startPos, endPos-1)
      response = string.gsub(response, ":", "")
      response = string.gsub(response, "\"", "")
      response = string.gsub(response, " ", "")
   return response
function timedifference(s)
    year    = string.sub(s, 1, 4)
    month   = string.sub(s, 6, 7)
    day     = string.sub(s, 9, 10)
    hour    = string.sub(s, 12, 13)
    t1 = os.time()
    t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes,sec=seconds}
    return difference
function UpdateDevice(device, data)
    idx = otherdevices_idx[device]
    if (idx == nil) then
        print('** Unknown device'..device)
        commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
        i = i+1
difference = timedifference(otherdevices_lastupdate[sensorSolarPanels])
if (difference > refresh_time) then
    getExecuteCommand(loginCommand)
    local data = getExecuteCommand(getDataCommand)
--print(data)
    if (isempty(data) == false) then
        output_power = getValue(data, "output_power")
        last_refresh_time = getValue(data, "last_refresh_time")
        eDay = getValue(data, "eDay")
        print("last_refresh_time :" .. last_refresh_time)
        print("output_power :" .. output_power)
        print("eDay :" .. eDay)
        current = tonumber(stripchars(output_power, "kwhKWH"))
        dayTotal = tonumber(eDay)*1000
        UpdateDevice(sensorSolarPanels, current..";"..dayTotal)
hopefully the script will continue to work in the near future.
Have fun with it.
Sjuul
Re: GoodWe: Get data from Semportal
Post by Sjuul »
This script isn't work on my Raspberry PI 4.
The error message is:
2021-09-13 20:29:00.536 Error: EventSystem: in Goodwe solar SEMS 2020: [string "-- Created by Raymond Wiertz ..."]:58: bad argument #1 to 'sub' (string expected, got nil)
Is the someone how have this working in a LUA script?
Regards Sjuul.
