Conditional not evaluated
juankar
Domoticz version: 4.
Post by juankar »
Hello
I have this blocky script
The logic is
If (vest-mov== on and vest-lux <20)
       set vestibulo = on
       if (time > sunset and pasillo == off )
            set pasillo = off
    if (vest-mov== off and vestibulo == on)
        set vestibulo = off
In plain text: if a movement sensor is on and it's dark, then turn vestibulo light on and if time is after sunset then turn light pasillo on too.
The problem is:
            set pasillo = off
is evaluate always to TRUE, so it always set vestibulo and pasillo to on when the movement sensor is on and light is under 20.
I can not understand why this logic doesn´t work
Any idea?
wouterlet
Re: Conditional not evaluated
Post by wouterlet »
Sorry you can't use an "if->do" in another "if->do anymore. I understooth that it was possible years ago, but not anymore...
juankar
Post by juankar »
Thanks for your answer
I solved my problem with a huge conditional.
So this is a problem of Blocky, I cannot understand the reason of this behavior, it's a basic program construction in any language.
Blocky is a good idea for no-programmers, but if it doesn't work....
I think that dZevents will be the language for scripts in Domoticz, at least in my home.
Bye
RogerSch
Post by RogerSch »
wouterlet wrote: Thursday 27 February 2020 21:08 Sorry you can't use an "if->do" in another "if->do anymore. I understooth that it was possible years ago, but not anymore...
Sorry for the late response. But is this really true. Who can confirm this?
RogerSch wrote: Saturday 16 May 2020 7:23
There are at least 50 posts on this forum confirming that it does not work. I cannot confirm it ever worked though.. :)
juankar
Post by juankar »
I nmy opinion, if you need a complex conditional sentence or complex script it's better to use dzVents, Lua or Python.
