Shelly 2.5 Tasmota Shutter and MQTT Update to Domotic
Posted: Tuesday 18 February 2020 10:36
i have a problem and im sure the problem its me!
So i have a shelly 2.5 flashed with Tasmota and the shutter option enabled.
I can control the shutter in percentage. When im now going to change the value in domoticz the shutter will start moving in the desired direction. But as soon as the shelly sends an MQTT update with the percentage to domoticz, the direction will change. The value will handled as new setpoint in domoticz and re-send via MQTT. That means the shutter is moving down, domoticz gets an updated value via MQTT from the shelly and re-sends this value to the shelly.
When i raise the TelePeriod to 300 i can avoid this mostly. But i need to make sure that this will not happen. I could set TelePeriod 0 to avoid any updates. Usually i only use Domoticz for controlling the shutter, but this will then not be bi-directional any more.
Can somebody point me to the right direction please???
Regards!
Regards!
