i have a problem and im sure the problem its me!
So i have a shelly 2.5 flashed with Tasmota and the shutter option enabled.
I can control the shutter in percentage. When im now going to change the value in domoticz the shutter will start moving in the desired direction. But as soon as the shelly sends an MQTT update with the percentage to domoticz, the direction will change. The value will handled as new setpoint in domoticz and re-send via MQTT. That means the shutter is moving down, domoticz gets an updated value via MQTT from the shelly and re-sends this value to the shelly.
When i raise the TelePeriod to 300 i can avoid this mostly. But i need to make sure that this will not happen. I could set TelePeriod 0 to avoid any updates. Usually i only use Domoticz for controlling the shutter, but this will then not be bi-directional any more.
Can somebody point me to the right direction please???
Regards!
Shelly 2.5 Tasmota Shutter and MQTT Update to Domotic
Re: Shelly 2.5 Tasmota Shutter and MQTT Update to Domotic
I use shelly 2.5 with the original firmware and works perfect
Enviado desde mi Mi A2 mediante Tapatalk
Oh this is good to know, but i dont like the cloud services, so I moved to Tasmota.
Many thanks!
Many thanks!
I don't like cloud services, shelly works localy via mqtt.mrox wrote:Oh this is good to know, but i dont like the cloud services, so I moved to Tasmota.
Many thanks!
May I ask you how do you integrate the original shelly to domoticz? I cant find MQTT.
There is a plugin called shelly to mqtt, search the forummrox wrote:May I ask you how do you integrate the original shelly to domoticz? I cant find MQTT.
I need to run domoticz beta then, and i had recently some issues with that. I will stick to the Tasmota fw for the Shelly 2.5.
Many thanks for your support!
how are you able to move dummy device blind with percentage in domoticz and trigger the relay on tasmota?
i have nodemcu flashed with tasmota 8.1 with added roller shutter, but if i move slide inside domoticz the relays are not triggered
if i move slide on tasmota webpage the relays are trigered but the value is not reported in domoticz
may i ask to you how you succeed on make talking tasmota with blinds and domoticz
