DzVents JSON with SHT3x-0x44 sensor  [Solved]
cncforhobby
Domoticz version: 4.11590
Post by cncforhobby »
I am new to this forum, so please let me know if this topic should be put somewhere else.
At this moment I use a Sonoff S20 with tasmota firmware and a BME280 sensor connected to it.
I have no problems at all with this code (will show the problem in a bit!)
I send a http request :
http://192.168.10.4/cm?cmnd=status%2010
which receives:
"StatusSNS": {
"Time": "2020-02-15T20:37:04",
"BMP180": {
"Temperature": 17.3,
"Pressure": 1008.4
"PressureUnit": "hPa",
"TempUnit": "C"
Update the temperature and baro to a sensor in Domoticz:
if (item.isHTTPResponse) then
			if (item.statusCode == 200) then
				if (item.isJSON) then
					local myTemperature = item.json.StatusSNS.BMP180.Temperature
                                        local myPressure = item.json.StatusSNS.BMP180.Pressure
             					-- update device in Domoticz
				domoticz.devices('Sonoff_TB').updateTempHumBaro(myTemperature,'0','0', myPressure)
The problem occurrs with my new SHT-31 sensor wich names itself SHT3X-0x44
The resonse:
"StatusSNS": {
"Time": "2020-02-15T20:45:10",
"SHT3X-0x44": {
"Temperature": 19.6,
"Humidity": 54.1
"TempUnit": "C"
The code I use to get the value is the same:
local myTemperature = item.json.StatusSNS.SHT3X-0X44.Temperature
But (off course) the code doesn't get the "-0x44". I tried to work around it but that doesn't solved the problem...
local myTemperature = item.json.StatusSNS.'SHT3X-0X44'.Temperature
and
local myTemperature = item.json.StatusSNS."SHT3X-0X44".Temperature
Does anybody know a workaround for this?
Thanks in advance.
boum
Domoticz version: 4.10717
Re: DzVents JSON with SHT3x-0x44 sensor  [Solved]
Post by boum »
Try:
local myTemperature = item.json.StatusSNS['SHT3X-0X44'].Temperature
In Lua, the dot is used to access table element as a syntactic sugar, so this strictly is equivalent to:
local myTemperature = item['json']['StatusSNS']['SHT3X-0X44']['Temperature']
cncforhobby
Hi! Thanks for the quick reply. It's working now!!! :D :D :D
I just had to use the line below with 0x44 instead of 0X44
local myTemp = item['json']['StatusSNS']['SHT3X-0x44']['Temperature']
