compare time from fixing time..
Posted: Friday 14 February 2020 15:33
by OedzesG
hallo,
here a noob question again
for a script i needed to know how manny minutes are past since a fixed time..
for example:
fix time is: '15:00'
now its 15:30
so the number 30 is what i need..
this dosnt work
dz.time.compare('15:00:00').minutes
Re: compare time from fixing time..
Posted: Friday 14 February 2020 16:47
by waaren
OedzesG wrote: Friday 14 February 2020 15:33
this doesn't work
The compare method require two dzVents time objects.
return
on =
timer =
'every minute',
execute = function(dz)
local myTime = '15:00:00'
local someTime = dz.time.makeTime(dz.time.rawDate .. ' ' .. myTime) -- this will create the time object someTime
-- compare require two dzVents time objects (first one here is dz.time, second one is someTime )
dz.log('Delta time between ' .. dz.time.rawTime .. ' and ' .. someTime.rawTime .. ' is ' .. dz.time.compare(someTime).minutes .. ' minutes.', dz.LOG_FORCE)
Posted: Friday 14 February 2020 21:38
by OedzesG
thanks again waaren!
is there also a way to get the current minute in this week, month and year?
Posted: Saturday 15 February 2020 2:08
by waaren
OedzesG wrote: Friday 14 February 2020 21:38
you could try this
return
on =
timer =
'every minute',
local day = 86400 -- (24 * 60 * 60)
local function makeTime(date)
return dz.time.makeTime(date .. ' 00:00:00')
local weekStart = makeTime(os.date("%Y-%m-%d",os.time()- ( dz.time.wday - 1 ) * day))
local dayStart = makeTime(dz.time.rawDate)
local monthStart = makeTime(dz.time.year .. '-' .. dz.time.month ..'-01')
local yearStart = makeTime(dz.time.year .. '-01-01')
dz.log('Minutes today: ' .. dayStart.minutesAgo, dz.LOG_FORCE)
dz.log('Minutes this week: ' .. weekStart.minutesAgo, dz.LOG_FORCE)
dz.log('Minutes this month: ' .. monthStart.minutesAgo, dz.LOG_FORCE)
dz.log('Minutes this year: ' .. yearStart.minutesAgo, dz.LOG_FORCE)
Posted: Sunday 16 February 2020 1:46
by OedzesG
Thnx waaren! thats exactly what i needed..
Posted: Thursday 26 December 2024 12:52
by andrehj
(Sorry to revive an old topic, but I couldn't find anything more recent.)
waaren wrote: Friday 14 February 2020 16:47
return
on =
timer =
'every minute',
After a lot of studying, I still fail to understand how the Compare function should be used.
As far as I understand, this "dz.time.compare(someTime).minutes" only compares the
current time with the time stored in the time object "someTime" and returns that difference in a number of minutes.
But how can one compare two time objects named for instance "Time1" and "Time2"?
The manual doesn't help either, see
https://wiki.domoticz.com/DzVents:_next ... ime_object
-- compare two times
print(domoticz.time.compare(myDevice.lastUpdate).secs))
It says it compares two times, but all it does is compare the current time with another time....
Posted: Friday 27 December 2024 22:56
by boum
have you just tried:
print(Time1.compare(Time2).minutes)
