compare time from fixing time..
OedzesG
Post by OedzesG »
hallo,
here a noob question again :D
for a script i needed to know how manny minutes are past since a fixed time..
for example:
fix time is: '15:00'
now its 15:30
so the number 30 is what i need..
this dosnt work
dz.time.compare('15:00:00').minutes
Re: compare time from fixing time..
OedzesG wrote: Friday 14 February 2020 15:33 this doesn't work
The compare method require two dzVents time objects.
return
	on =
		timer =
			'every minute',
	execute = function(dz)
	    local myTime = '15:00:00'
	    local someTime = dz.time.makeTime(dz.time.rawDate .. ' ' .. myTime) -- this will create the time object someTime
	    -- compare require two dzVents time objects (first one here is dz.time, second one is someTime )
		dz.log('Delta time between  ' .. dz.time.rawTime .. ' and ' .. someTime.rawTime .. ' is ' .. dz.time.compare(someTime).minutes .. ' minutes.', dz.LOG_FORCE)
OedzesG
Post by OedzesG »
thanks again waaren! :D
is there also a way to get the current minute in this week, month and year?
OedzesG wrote: Friday 14 February 2020 21:38 is there also a way to get the current minute in this week, month and year?
you could try this
return
    on =
        timer =
            'every minute',
        local day = 86400 -- (24 * 60 * 60)
        local function makeTime(date)
            return dz.time.makeTime(date .. ' 00:00:00')
        local weekStart = makeTime(os.date("%Y-%m-%d",os.time()- ( dz.time.wday - 1 ) * day))
        local dayStart = makeTime(dz.time.rawDate)
        local monthStart = makeTime(dz.time.year .. '-' .. dz.time.month ..'-01')
        local yearStart = makeTime(dz.time.year .. '-01-01')
        dz.log('Minutes today: ' .. dayStart.minutesAgo, dz.LOG_FORCE)
        dz.log('Minutes this week: ' .. weekStart.minutesAgo, dz.LOG_FORCE)
        dz.log('Minutes this month: ' .. monthStart.minutesAgo, dz.LOG_FORCE)
        dz.log('Minutes this year: ' .. yearStart.minutesAgo, dz.LOG_FORCE)
OedzesG
Post by OedzesG »
Thnx waaren! thats exactly what i needed..
andrehj
Domoticz version: 2026.4
Post by andrehj »
(Sorry to revive an old topic, but I couldn't find anything more recent.)
waaren wrote: Friday 14 February 2020 16:47 The compare method require two dzVents time objects.
return
	on =
		timer =
			'every minute',
After a lot of studying, I still fail to understand how the Compare function should be used.
As far as I understand, this "dz.time.compare(someTime).minutes" only compares the current time with the time stored in the time object "someTime" and returns that difference in a number of minutes.
But how can one compare two time objects named for instance "Time1" and "Time2"? :?:
The manual doesn't help either, see https://wiki.domoticz.com/DzVents:_next ... ime_object
    -- compare two times
    print(domoticz.time.compare(myDevice.lastUpdate).secs))
It says it compares two times, but all it does is compare the current time with another time....
boum
Domoticz version: 4.10717
Post by boum »
andrehj wrote: But how can one compare two time objects named for instance "Time1" and "Time2"? :?:
have you just tried:
    print(Time1.compare(Time2).minutes)
