Graph color
edwin1234
Domoticz version: 2021.1
Graph color
Post by edwin1234 »
I have set my bar graph color to yellow in the config file
blocks['graph_6'] = {
graph: 'bar',
datasetColors: ['yellow']
but the bar graph stays white.
Do i have to change something else?
Vomera
Re: Graph color
Post by Vomera »
Hmm i have the same problem
even no bar, no color, no height works for me.
Did it in the custom.js (earlier versions) and in the config.js. Nothing changes.
config.js or custom.js
blocks['graph_7257'] = {
graph: 'bar',
And is it possible to get rid of the icons and text?
edit: remove line 688 in the graph.js
I did it before to change the graph.js delete some title html tags, but now the grapsh.js has a new code
PS. i have to arange the text and the graph after the graph works again. Normally it looks like
clinkadink
Re: Graph color
Post by clinkadink »
For device idx 6, try adding the following line to your block.
devices: [6],
Vomera
Re: Graph color
Post by Vomera »
clinkadink wrote: Thursday 13 February 2020 18:51 For device idx 6, try adding the following line to your block.
devices: [6],
Tnx i already found it on another post :D
blocks['tempbuiten'] = {
graphTypes: ['te'],
devices: [7257],
height: '60px',
graph: 'line',
datasetColors: ['red'],
borderWidth: 1,
displayFormats : {
      minute: 'dd h:mm'
Only the hight doenst work, still figuring out
clinkadink
Re: Graph color
The "height" issue was a reported bug and was fixed late last night. Make sure you have the latest beta.
https://github.com/Dashticz/dashticz/tree/beta
Vomera
Re: Graph color
Post by Vomera »
clinkadink wrote: Thursday 13 February 2020 19:35 The "" issue was a reported bug and was fixed late last night. Make sure you have the latest beta.
I installed the beta 1 hour ago because there was also an issue about some update of the blocks.
graphTypes: ['te'],
devices: [7257],
height: '30px',
graph: 'line',
borderWidth: 1,
displayFormats : {
      minute: 'dd h:mm'
width: 12,
This should be the right code ? I can set it even on 600px , but doesnt work for me :)
clinkadink
Re: Graph color
Have you tried without any height added in your block?
Also, try CTRL + F5 to clear your cache? Shouldn't have to, but I cannot think what else - as this was part of last nights beta.
The fix is on line 48 of js/components/graph.js. It should show:
obj.blockId = me.mountPoint.slice(1);
clinkadink
Re: Graph color
Vomera wrote: Thursday 13 February 2020 19:56
graphTypes: ['te'],
devices: [7257],
height: '30px',
graph: 'line',
borderWidth: 1,
displayFormats : {
      minute: 'dd h:mm'
width: 12,
The height was fixed on Friday (10pm) in the latest beta. You can now set height in block config.
