Zigate Plugin - git errors
pipiche
Post by pipiche »
In case you are getting errors like that when trying to update the Zigate Plugin
git pull
Auto-merging www/index.html
CONFLICT (add/add): Merge conflict in www/index.html
Auto-merging plugin.py
CONFLICT (content): Merge conflict in plugin.py
Auto-merging Tools/Fedora/pi-zigate-fedora.py
CONFLICT (add/add): Merge conflict in Tools/Fedora/pi-zigate-fedora.py
Auto-merging ReleaseNotes.md
CONFLICT (content): Merge conflict in ReleaseNotes.md
Auto-merging OTAFirmware/IKEA-TRADFRI/159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/159698-TRADFRI-driver-lp-1.2.217.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/159697-TRADFRI-driver-hp-1.2.217.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/159695-TRADFRI-bulb-ws-1000lm-1.2.217.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/159495-TRADFRI-transformer-1.2.245.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/10035534-TRADFRI-bulb-ws-gu10-1.2.221.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/10035515-TRADFRI-bulb-cws-1.3.009.ota.ota.signed
Auto-merging OTAFirmware/IKEA-TRADFRI/10005777-4.1-TRADFRI-control-outlet-2.0.022.ota.ota.signed
Auto-merging Modules/zigateConsts.py
CONFLICT (add/add): Merge conflict in Modules/zigateConsts.py
Auto-merging Modules/readClusters.py
CONFLICT (content): Merge conflict in Modules/readClusters.py
Auto-merging Modules/pairingProcess.py
CONFLICT (add/add): Merge conflict in Modules/pairingProcess.py
Auto-merging Modules/legrand_netatmo.py
CONFLICT (add/add): Merge conflict in Modules/legrand_netatmo.py
Auto-merging Modules/input.py
CONFLICT (content): Merge conflict in Modules/input.py
Auto-merging Modules/heartbeat.py
CONFLICT (content): Merge conflict in Modules/heartbeat.py
Auto-merging Modules/domoticz.py
CONFLICT (content): Merge conflict in Modules/domoticz.py
Auto-merging Conf/DeviceConf.txt
CONFLICT (content): Merge conflict in Conf/DeviceConf.txt
Auto-merging Classes/OTA.py
Automatic merge failed; fix conflicts and then commit the result.
You will have to do a reinstall of the plugin. Here is the procedure to follow to not loose anything
https://github.com/pipiche38/Domoticz-Z ... install.md
pfloryann
Re: Zigate Plugin - git errors
Post by pfloryann »
Hi Pipiche,
I updated the beta plugin and i had the above erros . I followed the link steps for reinstall the plugin...all was fine but in the end i have an error. Now i using the stable because i can't change on beta. When i trying to change on beta i have this:
error: Your local changes to the following files would be overwritten by checkout:
Classes/PluginConf.py
Conf/Certified/IKEA_TRADFRI/TRADFRI wireless dimmer.json
Modules/domoticz.py
Modules/input.py
Modules/output.py
Modules/schneider_wiser.py
ReleaseNotes.md
www/1-es2015.353ada42944e3ad6b3c9.js
www/1-es5.353ada42944e3ad6b3c9.js
www/10-es2015.cd11cb80c7c2775a37e1.js
www/10-es5.cd11cb80c7c2775a37e1.js
www/11-es2015.32de84e4b0564a1f16dd.js
www/11-es5.32de84e4b0564a1f16dd.js
www/12-es2015.5fbfab36313ed12ab427.js
www/12-es5.5fbfab36313ed12ab427.js
www/3rdpartylicenses.txt
www/6-es2015.30570632f2e844aef491.js
www/6-es5.30570632f2e844aef491.js
www/7-es2015.a0d3f6fb9bcc65f6c55e.js
www/7-es5.a0d3f6fb9bcc65f6c55e.js
www/8-es2015.dab4f1b6c189d31968b3.js
www/8-es5.dab4f1b6c189d31968b3.js
www/9-es2015.53ab70203d988144ba40.js
www/9-es5.53ab70203d988144ba40.js
www/fa-brands-400.088a34f78f530102fd96.eot
www/fa-brands-400.273dc9bf9778fd37fa61.ttf
www/fa-brands-400.822d94f19fe574778652.woff2
www/fa-brands-400.d72293118cda50ec50c3.svg
www/fa-brands-400.f4920c94c0861c537f72.woff
www/fa-regular-400.3ac49cb33f43a6471f21.eot
www/fa-regular-400.9efb86976bd53e159166.woff2
www/fa-regular-400.a57bcf76c178aee452db.woff
www/fa-regular-400.d2e53334c22a9a4937bc.svg
www/fa-regular-400.ece54318791c51b52dfd.ttf
www/fa-solid-900.2aa6edf8f296a43b32df.ttf
www/fa-solid-900.7a5de9b08012e4da4050.svg
www/fa-solid-900.7fb1cdd9c3b889161216.eot
www/fa-solid-900.93f284548b42ab76fe3f.woff
www/fa-solid-900.f6121be597a72928f54e.woff2
www/index.html
www/main-es2015.1255721b88c9f50e16ae.js
www/main-es5.1255721b88c9f50e16ae.js
www/polyfills-es2015.2e0d70ba805191d1aa0d.js
www/polyfills-es5.5771b725ec36c3694c88.js
www/robots.txt
www/runtime-es2015.5ba7ce892a11ce43e949.js
www/runtime-es5.5ba7ce892a11ce43e949.js
www/styles.24cb59b78766d11a93ad.css
Please commit your changes or stash them before you switch branches.
Aborting
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Post by pipiche »
Please follow the procedure which was given. You should not copy but move in order to start from a clean/empty situation
