Does anyone know if Smappee still works in Domoticz?
Can’t get it to work. Keeps logging errors when reading the configuration file.
https://www.domoticz.com/wiki/Smappee
I used this link to set it up.
But it uses Lua 5.2 scripting and not sure if this is still supported by Domoticz.
Thank’s for the help.
John
Smappee
johnswinnen
- Egregius
- Domoticz version: v2024.7
Re: Smappee
What kind of data do you want from the Smappee?
I pull current power usage and daily totals with a php script.
Example for current power usage: https://github.com/Egregius/PHP-Floorpl ... epower.php, this is fetched every 4 seconds.
The daily usage is fetched every minute in another cron script, example starting at line 669 (at this moment, this could change of course) of https://github.com/Egregius/PHP-Floorpl ... cron60.php
fantilator
- Domoticz version: 3.5877
Re: Smappee
Has annyone got Smappee to work when domoticz in installed in Docker on a synology NAS?
If so, can you please tell me some tips and trick on how to get it to work?
