Timer issues
arjan93
Timer issues
Post by arjan93 »
Hello all,
I am new with programming through dzvents and run into some problems with the timers.
I try to understand how it works and have made a script that is as simple as possible, but even that doesn't work yet. Can someone tell me what I am doing wrong?
This is the script i made:
timer = {'every minute'},
execute = function(domoticz, timer)
if dz.time.matchesRule('at 19:13') then
domoticz.devices('Dummy lamp 1').switchOn()
Re: Timer issues
arjan93 wrote:Can someone tell me what I am doing wrong?
Here you should use domoticz.time.matchesrule
arjan93
Re: Timer issues
Post by arjan93 »
waaren wrote: Friday 07 February 2020 22:58
Thanks for the answer but unfortunately it still doesn't work. I don't know what I'm doing wrong.
The dummy lamp 1 switch does not switch on.
boum
Domoticz version: 4.10717
Re: Timer issues
Post by boum »
You're also not very helpful ;)
You should post some logs of what happens.
Have you read https://www.domoticz.com/wiki/DzVents:_ ... h_Domoticz ? It's a good start. You should also add domoticz.log calls in your script to help debugging.
