Zigate error pairing Topic is solved
pfloryann
Domoticz version: 4.1
Post by pfloryann »
I removed one xiaomi motion sensor from domoticz and zigate. When I tried to pair again I have this:
2020-02-03 23:21:10.846 Status: (Zigate) Device Announced ShortAddr: 01ff, IEEE: 00158d0001daf6e5 REJOIN: 0x00 - join a network through association RSSI: 0
2020-02-03 23:21:11.248 Status: (Zigate) [1] NEW OBJECT: 1b7e TimeOut in 0045 restarting at 0x004d
2020-02-03 23:21:16.117 Status: (Zigate) Device Announced ShortAddr: 01ff, IEEE: 00158d0001daf6e5 REJOIN: 0x00 - join a network through association RSSI: 0
2020-02-03 23:21:16.117 Error: (Zigate) Decode004d - New Device 01ff 00158d0001daf6e5 already exist in IEEE2NWK
2020-02-03 23:22:01.259 Error: (Zigate) [5] NEW OBJECT: 1b7e Not able to get all needed attributes on time
2020-02-03 23:22:01.259 Error: (Zigate) processNotinDB - not able to find response from 1b7e stop process at 0045
2020-02-03 23:22:01.260 Error: (Zigate) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model:
2020-02-03 23:22:01.260 Error: (Zigate) processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '', 'Ep': {}, 'Heartbeat': '1', 'RIA': '5', 'RSSI': {}, 'Battery': {}, 'Model': '', 'MacCapa': '80', 'IEEE': '00158d0001daf6e5', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [(1580764844.5285008, '0100', None), (1580764844.634483, '0100', None), (1580764844.736923, '0100', None), (1580764844.8392324, '0100', None), (1580764844.941659, '0100', None)], 'LogicalType': 'End Device', 'Manufacturer': '', 'Manufacturer Name': '', 'NbEp': '', 'PowerSource': '', 'ReadAttributes': {'Ep': {'01': {'0000': {}}, '02': {'0000': {}}, '03': {'0000': {}}, '06': {'0000': {}}, '09': {'0000': {}}}, 'TimeStamps': {'01-0000': 1580764844, '02-0000': 1580764844, '03-0000': 1580764844, '06-0000': 1580764844, '09-0000': 1580764844}}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'Time': '2020-02-03 23:20:51', 'MsgType': '8011', 'LastSeen': 1580764844}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'Announced': 1580764844.5261285, 'ConsistencyCheck': 'Bad Pairing'}
Domoticz on Raspberry Pi 4 with Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy
pipiche
Re: Zigate error pairing
Post by pipiche »
There are 2 possibilities
(1) The Zigate is full ( if you have reached 40 devices )
(2) Something went wrong during the discovery process, so you should restart the plugin and retry the pairing
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
pfloryann
Post by pfloryann »
I have 28 dedIves.. Doesn t work.. The beta plugin and stable the same problem
pipiche
Post by pipiche »
pfloryann wrote: Tuesday 04 February 2020 14:46 I have 28 dedIves.. Doesn t work.. The beta plugin and stable the same problem
As said, there is either the Zigate full or the Device not responding correctly, so you must try again (but before and after each failure, you need to restart the plugin so the bad pairing is removed from the Plugin DB).
Make sure when doing the pairing that you are closed to the Zigate
pfloryann
Post by pfloryann »
Ok this motion sensor coud be bad..but i can't pair no other Aqara temperature sensor this is not seen by zigate. I think is a problem when if a device is removed from domoticz and i tried to add it again. Please check. I have this problem with xioami motion sensor first version and Aqara Temp sensor and barometer.
pipiche
Post by pipiche »
pfloryann wrote: Tuesday 04 February 2020 15:30 Ok this motion sensor coud be bad..but i can't pair no other Aqara temperature sensor this is not seen by zigate. I think is a problem when if a device is removed from domoticz and i tried to add it again. Please check. I have this problem with xioami motion sensor first version and Aqara Temp sensor and barometer.
You can pair/unpair and pair again. I'm doing that 10th time a day when testing ... So no worry on that.
Last I'm not telling the device is bad, I'm telling that during the discovery something is not happening, this could be realated to a timing issue, interferences on Zigbee ....
Last, if you are not able to pair any more devices, I'm afraid that the only alternative I see :
ErasePDM (to reset entirely Zigate) and redo the pairing ( you don't have to remove any devices from Domoticz not Plugin, they will be reconnected automatically)
pfloryann
Post by pfloryann »
I reflashing an 1 year old backup right now, after i will make update for domoticz and zigate plugin. Let see if it works. I using domoticz and zigate...for heating, lights, alarm and i need to work corectly.
pfloryann
Post by pfloryann »
Now i have multiple errors...how can fix these errors? Pairing don't works
2020-02-04 18:44:25.953 Error: (Zigate) Decode8030 - Unknown addr mode 2d in 5000022da0
2020-02-04 18:44:26.055 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:26.156 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:26.157 Error: (Zigate) Decode8030 - Unknown addr mode 2d in 5100022da0
2020-02-04 18:44:26.259 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:26.360 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:26.361 Error: (Zigate) Decode8030 - Unknown addr mode c3 in 520002c387
2020-02-04 18:44:26.462 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:31.264 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:34.572 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:40.924 (Zigate) timedOutDevice unit Spoturi bucatarie nwkid: 5201
2020-02-04 18:44:40.961 (Zigate) timedOutDevice unit lumina bar nwkid: 5201
2020-02-04 18:44:40.996 Error: (Zigate) Command: 0x0100:Read Attribute request failed on
2020-02-04 18:44:40.996 Error: (Zigate) - Device: Spoturi bucatarie NwkID: 5201 IEEE: 00158d0003cbdb3b
2020-02-04 18:44:40.996 Error: (Zigate) - Code: e9 Status: No acknowledgement received when expected
2020-02-04 18:44:42.502 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:44.518 (Zigate) UpdateDevice - (Spoturi bucatarie) 0:Off
2020-02-04 18:44:44.362 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:44:49.500 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 80f2 with Data : 4480f201040000000021000200ec
2020-02-04 18:44:49.502 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 80f2 with Data : 4580f201040600000018000101
2020-02-04 18:44:51.577 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:00.590 EventSystem: Event triggered: lumina intrare_3
2020-02-04 18:45:00.425 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:02.293 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:10.906 (Zigate) UpdateDevice - ( lumina bar) 0:Off
2020-02-04 18:45:10.904 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:12.304 (Zigate) UpdateDevice - (Senzor miscare intrare) 1:On
2020-02-04 18:45:12.472 EventSystem: Event triggered: lumina intrare_2
2020-02-04 18:45:12.643 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:20.851 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.852 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.854 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.855 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.856 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.908 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.909 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.910 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:20.913 Error: (Zigate) Decode8102 - Receiving a message from unknown device : b2ad with Data : 01b2ad01040600000018000101
2020-02-04 18:45:21.618 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 80f2 with Data : 4680f201040000000021000200ec
2020-02-04 18:45:21.621 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 80f2 with Data : 4780f201040600000018000101
2020-02-04 18:45:25.925 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: d0
2020-02-04 18:45:25.928 Error: (Zigate) Decode8030 - Unknown addr mode c3 in 5a0002c387
2020-02-04 18:45:26.030 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:26.135 Error: (Zigate) Decode8030 - Unknown addr mode b2 in 5b0002b239
2020-02-04 18:45:26.237 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:27.592 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:30.937 Error: (Zigate) Decode8030 - Unknown addr mode b2 in 5c0002b239
2020-02-04 18:45:31.039 Error: (Zigate) ZigateRead - Decoder not found for 8011
2020-02-04 18:45:34.357 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 80f2 with Data : 4880f201040000000021000200ec
2020-02-04 18:45:34.360 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 80f2 with Data : 4980f201040600000018000101
2020-02-04 18:45:34.612 Error: (Zigate) ZigateRead - Decoder not found for 8035
2020-02-04 18:45:34.664 Error: (Zigate) ZigateRead - Decoder not found for 8035
pipiche
Post by pipiche »
you have a latest firmware on Zigate, so it is key that you have either the latest stable version or better are on beta branche
pfloryann
Post by pfloryann »
I solved a part of devices after erase the permanent data memory of Zigate from 4.5.5 pugin and pair again...after i updated to the 4.6.073 plugin but i can't pair water leak sensor:
2020-02-04 20:30:23.995 Status: (Zigate) (efad/00158d000444bee5) send a Leave indication and will be outside of the network. RSSI: 00
2020-02-04 20:30:26.122 (Zigate) DeviceExist - Update Status from Left to 'inDB' for NetworkID : 3d99
2020-02-04 20:30:26.328 (Zigate) Device Announced ShortAddr: 3d99, IEEE: 00158d000444bee5 with an Unknown RejoinFlag: XX
2020-02-04 20:30:26.107 Status: (Zigate) Device Announced ShortAddr: 3d99, IEEE: 00158d000444bee5 REJOIN: 0x00 - join a network through association RSSI: 0
2020-02-04 20:30:26.107 Status: (Zigate) NetworkID : 3d99 is replacing efad and is attached to IEEE : 00158d000444bee5
2020-02-04 20:30:26.329 Status: (Zigate) Device Announced ShortAddr: 3d99, IEEE: 00158d000444bee5 REJOIN: 0x00 - join a network through association RSSI: 48
Remains at this stage he does not create the object in domoticz.
In web admin on plugin raw devices this sensor it was added but not in domoticz:
28 : Object {"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"34","Ep":{"01":{"0000":{"0000":"1","0007":"3","0003":"2","0005":"lumi.sensor_wleak.aq1","0004":"LUMI","0002":"2"
pfloryann
Post by pfloryann »
I solved the problem with Aqara water leak sensor...when i tried to pair for the first time, i had domoticz v4.110 and zigate plugin 4.6,073(attention at the old domoticz and new plugin)...and the sensor it was added that "voltage" type sensor. After i updated domoticz to v 4.11670 and i removed the wrong type sensor from domoticz and paired again...this time everything was fine.
Thank you Pipiche for your support!
pfloryann
Post by pfloryann »
I'm back all xiaomi or aqara motion sensors(I m tested with both - I have 2 new sensors) can't be paired with zigate with the latest plugin. Please fix it!
2020-02-05 00:21:16.071 Error: (Zigate) [5] NEW OBJECT: 2d8a Not able to get all needed attributes on time
2020-02-05 00:21:16.071 Error: (Zigate) processNotinDB - not able to find response from 2d8a stop process at 0045
2020-02-05 00:21:16.071 Error: (Zigate) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model:
2020-02-05 00:21:16.072 Error: (Zigate) processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '', 'Ep': {}, 'Heartbeat': '1', 'RIA': '5', 'RSSI': {}, 'Battery': {}, 'Model': '', 'MacCapa': '80', 'IEEE': '00158d00041f2389', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [(1580854796.891937, '0100', None), (1580854796.9977899, '0100', None), (1580854797.1002345, '0100', None), (1580854797.2027416, '0100', None), (1580854797.305145, '0100', None)], 'LogicalType': 'End Device', 'Manufacturer': '', 'Manufacturer Name': '', 'NbEp': '', 'PowerSource': '', 'ReadAttributes': {'Ep': {'01': {'0000': {}}, '02': {'0000': {}}, '03': {'0000': {}}, '06': {'0000': {}}, '09': {'0000': {}}}, 'TimeStamps': {'01-0000': 1580854796, '02-0000': 1580854796, '03-0000': 1580854796, '06-0000': 1580854796, '09-0000': 1580854796}}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'Time': '2020-02-05 00:20:03', 'MsgType': '8011', 'LastSeen': 1580854796}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'Announced': 1580854796.8896754, 'ConsistencyCheck': 'Bad Pairing'}
pfloryann
Post by pfloryann »
Nobody can test?
blooesky
Post by blooesky »
I have the same problem with Xiaomi motion sensor RTCGQ01LM and Aqara motion sensor RTCGQ11LM. I think the software does not receive the information correctly.
pipiche
Post by pipiche »
pfloryann wrote: Tuesday 04 February 2020 23:25 I'm back all xiaomi or aqara motion sensors(I m tested with both - I have 2 new sensors) can't be paired with zigate with the latest plugin. Please fix it!
I can understand your frustration and the pain to make it working, however please do accept that ALL of us are developing, maintaining the plugin, responding to questions, issues ....
So the tone of your statement "Please fix it!" is definitively not helping here
Take also in consideration, that Xiaomi is the the worst implementation of ZIgbee and all the community have issues getting Xiaomi working as they are deviating from the standard.
pfloryann
Post by pfloryann »
Sorry for my yesterday tone this was not my intention. I'm not frustrated, I said the problem I found after 4 hours of tests.
I agree that these devices have a malfunctioning but have worked without problems until recently an I thought we can find a solution. that was all.
pipiche
Post by pipiche »
pfloryann wrote: Wednesday 05 February 2020 18:47 Sorry for my yesterday tone this was not my intention. I'm not frustrated, I said the problem I found after 4 hours of tests.
You might find some answer in this link about Aqara/Xiaomi devices: https://community.hubitat.com/t/xiaomi- ... nected/623
pfloryann
Post by pfloryann »
Thank you Pipiche! I readed the informations from link and I tried to change the zigate channel from the zigate web interface for test pairing with aqara/xiaomi motion sensor, but even if I changed the channel to 20,25 or other and after I restarted the plugin, in domoticz remain channel 11. It is possible that changes is not effect?
2020-02-09 14:41:00.638 Status: (Zigate) Network state UP, PANID: 7b85 extPANID: 0x063adaced50a9f2e Channel: 11
pipiche
Post by pipiche »
2 things to know:
(1) if you change the Zigbee channel, you will have to repair all your devices
(2) After changing the Zigbee channel on Settings, you need to go to Admin -> Zigate and do a Soft Restart/Reset of the Zigate
pfloryann
Post by pfloryann »
OK. In this case I keep the channel 11. I will try with a new battery, maybe it will work. For the temperature sensor it worked.
Thank you!
