beginner question
adval40
Domoticz version: 4.11528
beginner question
Post by adval40 »
I started with dzvents since 2 days.
I want to switch a device with 'between 00:47 and 00:48',
this is of course an example
		timer = {
		    'between 00:47 and 00:48' ,
	execute = function(domoticz, timer)
	    domoticz.devices('Printer voorkamer')   .switchOn()
the .switchOn () command is wrong I don't know what the correct command is
thank you in advance
besix
Re: beginner question
Post by besix »
Hello
switchOn command is Ok
only in execute you have to say when it should be On
		timer = {
	    if domoticz.time.matchesRule('between 00:47 and 00:48') then
	    domoticz.devices( ' Printer voorkamer ' ).switchOn()
salvacalatayud
Post by salvacalatayud »
Why don't just put a timer to the switch instead? It is easy and you don't need any coding
Enviado desde mi Mi A2 mediante Tapatalk
adval40 wrote: Wednesday 29 January 2020 1:23 I want to switch a device with 'between 00:47 and 00:48',
The switchOn() method is ok but you have spaces before .switchOn() that should not be there. Try this one.
return
    on =
        timer =
            'at 08:31-08:33',
    execute = function(dz)
        dz.devices('Printer voorkamer').switchOn()
besix wrote: Wednesday 29 January 2020 6:48 switchOn command is Ok
I am sorry but no. In this script the matchesRule does not add any value. The script will only be executed 'at 00:47-00:48' so the matchesRule will always evaluate to true.
