Hello!
I have installed my domoticz on windows. Latest Beta Version (11650)
Also the latest Dahticz version (https://github.com/Dashticz/dashticz) from today
I want to use the Dashticz Dashboard but that not working.
Always comes unknown error.
I install it in this folder
\Domoticz\www\templates\dashticz
In the custom folder i configuration the CONFIG.js
At first i only changed my IP,PORT and rename to CONFIG.js, finish
var config = {}
config['domoticz_ip'] = 'http://IP:PORT';
config['app_title'] = 'Dashticz V3';
Who is the fault? Need i special settings in domoticz?
JSON works fine also i have a other custom page (frontpage.html) this works.
http://IP:PORT/json.htm?type=devices&rid=1
Thanks a lot
What is wrong in my config.js or domoticz settings
- HansieNL
Re: What is wrong in my config.js or domoticz settings
- Spoiler: show
On https://dashticz.readthedocs.io/en/master/ you can find the manual what is needed and how to install Dashticz. There are two options: Automatic install and Manual Setup. You don't have to change anything in Domoticz.
If manual installed you have to run your own webserver with PHP to use Dashticz.
Hope this info will help you.
Blah blah blah
Hello, thanks a lot, yes you help me very much.
Yet it works.
Yet it works.
