Zigate and Aqara Relay power measurement?
Posted: Wednesday 22 January 2020 13:36
by pfloryann
I use Aqara wireless relay with Zigate and works fine but in Domoticz i have not seen power measurement from this relay(model LLKZMK11LM). I saw on some websites that this relay has the power measurement functionality . Is true or not and i want to know if this functionality will be added for Zigate and Domoticz. Thank you!
Re: Zigate and Aqara Relay power measurement?
Posted: Wednesday 22 January 2020 13:43
by pipiche
I don't known. I don't have such relay and cannot commennt on it.
If it is capable to provide power measurement then this is not a zigate related issue.
On beta branch of the plugin, could you please provide an export of Tools -> Devices raw (json) and attach it here
Posted: Wednesday 22 January 2020 14:03
by pfloryann
In my domoticz is simple switch on/off with 2 channels. But can you read on this site
https://www.zigbee2mqtt.io/devices/LLKZMK11LM.html
I will attach devices raw this evening
Posted: Wednesday 22 January 2020 14:11
by pipiche
as said, could you please provide me the export information of "f Tools -> Devices raw (json) and attach it here" ?
Posted: Wednesday 22 January 2020 14:16
by pfloryann
Yes, but i can't now because i'm away. When i get home i'll try to make this export.
Posted: Wednesday 22 January 2020 14:29
by pipiche
no problem.
The issue is not about is it providing Consomption or not, the issue is to see how to get it.
Are you on the plugin beta branch ?
Posted: Wednesday 22 January 2020 15:45
by pfloryann
I'm not sure, i have to check. This option is only on beta branch?
Posted: Wednesday 22 January 2020 15:47
by pipiche
The option to export yes, and at the same time I just pushed an update on beta, which might be enough to enable Power/Meter.
So if you want to test, make sure you are on the plugin beta branche
git pull
git checkout beta
git pull
Then you need to remove the 2 switches (in domoticz) , and redo the pairing. From that you should get 3 widgets per line
- 1 switch
- 1 Power for Instant power
- 1 Meter for instant and / daily/weekly consomption
if it works
Posted: Wednesday 22 January 2020 20:09
by pfloryann
Please check json
Posted: Wednesday 22 January 2020 20:17
by pipiche
Ok.
So what I suggest is , if you want , do what I suggested above in order to test and dig into that.
Usally after the pairing you'll get 2 Power/Meters widgets one for each swicth. I however suspect that (as Xiaomi did for one of their switch), you'll get only the total on One.
Posted: Friday 24 January 2020 13:28
by pfloryann
Yes you're right, it's working now. In domoticz were created 2 switches and 2 power usage widgets, but only 1 power usage widget(ch1) is working and show live power for both switches.
This function is avaible only on the beta branch?
Thank you!
Posted: Friday 24 January 2020 13:41
by pipiche
pfloryann wrote: Friday 24 January 2020 13:28
Thank you!
Correctn only available on beta branche, I'll update in order to have the Meter/POwer created only on the first channel
