Use Monit to monitor Zigate?
tjabas
Post by tjabas »
i use Monit to monitor Domoticz which works great, but recently i have noticed that the zigate plugin has chrashed, i think i have got it working now,
but is is possible to get Monit to restart the plugin if it chrashes, or reboot the pie?
should this be possible, and how do i set it up if so?
geertvercamer
Re: Use Monit to monitor Zigate?
Post by geertvercamer »
Hi Tjabas,
have you ever found a solution for this?
I have the same trouble with MelCloud plugin (Mitsubishi airco).
Thanks for any infomation.
kr
Geert
Domoticz version: 2024.7
geertvercamer wrote: Tuesday 07 September 2021 17:20 Hi Tjabas,
kr
Geert
You can do an http Json API call to update the hardware (=plugin). you have to be very carefull to give all plugin parameters else you destroy the database. https://www.domoticz.com/wiki/Domoticz_ ... e_hardware
