ZiGate adding AqaraWall Switch (not detected)
Posted: Sunday 19 January 2020 12:04
by egrueda
Hi all, I'm moving from xiaomi gateway to a Zigate USB adapter.
I've succesfuly migrated door sensor, smart socket and small rounded switch.
But I am not able to pair a simple Aqara Single Wall Switch
Model code is WXKG03LM, which is "Fully operationnal" according to thje plugin wiki
But I just can't get to pair it.
I've enabled verbose debug, I put the zigbee adapter in join mode, blue led blinks.
Then I try to click my switch but get no log
I click 5 times, no luck
I press for 10 seconds, it shows nothing.
Am I missing something?
Please, can you help?
Re: ZiGate adding AqaraWall Switch (not detected)
Posted: Sunday 19 January 2020 15:25
by pipiche
It should pair.
Does the Xiaomi gw still on ? If so try to power off
Does the switch is not far from the zigate ?
When doing the reset ( more than 8s) do you have the switch led turning red or flashing ?
Posted: Sunday 19 January 2020 19:24
by pipiche
egrueda wrote: Sunday 19 January 2020 12:04
Could you provide the log. Is there anything happening ?
Posted: Sunday 19 January 2020 19:41
by egrueda
Nothing in the log
I'm using verbose=2 and there's absolutely nothing
Posted: Sunday 19 January 2020 20:25
by pipiche
It should pair.
Posted: Friday 24 January 2020 22:21
by egrueda
Sorry, @pipiche, didn't see your answer
pipiche wrote: Sunday 19 January 2020 20:25It should pair.
All my other aqara devices have paired easily
pipiche wrote: Sunday 19 January 2020 20:25Does the Xiaomi gw still on ? If so try to power off
Xiaomi hw is off from the begining.
pipiche wrote: Sunday 19 January 2020 20:25Does the switch is not far from the zigate ?
Both are close, about 15 cm or less
pipiche wrote: Sunday 19 January 2020 20:25When doing the reset ( more than 8s) do you have the switch led turning red or flashing ?
Yes, I can see leds flashing, but nothing in the log
I've enabled web interface for the plugin, updated firmware and plugin.
And have enought knowledge to run commands and move through the system, so I can send you what you need and make all testing.
Hope you can point me in the right direction.
Thanks in advance
Posted: Friday 24 January 2020 23:26
by egrueda
Damn! it was a hardware issue!
I've removed the battery from the switch for about half an hour.
When I put the battery again, zigate felt a disturbance in the Force and log information started to arrive.
All is working now, easily. So I think there was somethin wrong with the switch itself, but couldn't explain more.
Thank you very much!
Posted: Saturday 25 January 2020 6:58
by pipiche
Great news
