Presence and welcome light
Posted: Friday 17 January 2020 22:20
by Wous
Although DzVents seems to be powerful, I have to say that I've had more succes with other languages. Nevertheless I want to manage this language finally. Can someone help me with the next code?
I want to convert my mobile phone switches to the amount of people who are at home. At night, I want to trigger the arrival a light to switch on.
Next code gives a log that says who's arriving / leaving. No other logs are given and the User Variable isn't updated. What's wrong?
devices = {
'Wouter',
'Marieke'
logging = {
level = domoticz.LOG_DEBUG,
marker = "iemandThuis - "
execute = function(domoticz, device, triggerInfo)
local iemandThuis = domoticz.variables('iemandThuis')
local lamp = domoticz.devices('Banklamp')
domoticz.log('Nu is de bezetting: ', iemandThuis.value)
--local lamp = domoticz.devices('Keukentafellamp')
if device.active then
domoticz.log(device.name .. ' is thuis gekomen', domoticz.LOG_INFO)
if iemandThuis.value == 0 then
domoticz.log('nu moet de uservariable 1 worden')
iemandThuis.set(1)
if domoticz.time.isNightTime then
lamp.switchOn().forMin(20)
--lamp.dimLevel(60)
domoticz.log(device.name .. ' is alleen thuis, daarom keukentafellamp aangezet voor 20 minuten')
elseif iemandThuis.value == 1 then
iemandThuis.set(2)
else domoticz.log(device.name .. ' is vertrokken', domoticz.LOG_INFO)
if iemandThuis == 2 then
domoticz.variables('iemandThuis').set(1)
elseif iemandThuis == 1 then
domoticz.variables('iemandThuis').set(0)
Re: Presence and welcome light
Posted: Friday 17 January 2020 22:49
by boum
Code looks good.
I can only think to check the value and the type of the variable is integer, just add the log line:
domoticz.log('iemandThuis is ' .. iemandThuis.type .. ' and value ' .. iemandThuis.value, domoticz.LOG_INFO)
Re: Presence and welcome light [Solved]
Posted: Saturday 18 January 2020 0:49
by waaren
Wous wrote: Friday 17 January 2020 22:20
The above line is incorrect. it should be
domoticz.log('Nu is de bezetting: ' .. iemandThuis.value, domoticz.LOG_INFO)
Can you try this ? If not working as expected please include the log.
return
devices = {
'Wouter',
'Marieke'
logging =
local WouterThuis = domoticz.devices('Wouter').active and 1 or 0
local MariekeThuis = domoticz.devices('Marieke').active and 1 or 0
local inHouseBefore = iemandThuis.value
local peopleAtHome = WouterThuis + MariekeThuis
domoticz.log('Nu is de bezetting: ' .. iemandThuis.value,domoticz.LOG_INFO)
if inHouseBefore < 1 and domoticz.time.isNightTime then
--lamp.dimLevel(60)
domoticz.log(device.name .. ' is alleen thuis, daarom keukentafellamp aangezet voor 20 minuten',domoticz.LOG_INFO )
if inHouseBefore ~= peopleAtHome then iemandThuis.set(peopleAtHome) end
Posted: Saturday 18 January 2020 9:21
by Wous
That's it! domoticz.LOG_INFO is needed apparently.. Works as I wanted..
-- Count the attendees, based on the mobile phones (look for Check_presence)
-- On arrival after sunset light is switched on for x minutes.
devices = {
'switch 1',
'switch 2'
logging = {
level = domoticz.LOG_INFO,
--local lamp = domoticz.devices('Banklamp')
iemandThuis.set(1)
lamp.dimLevel(60)
domoticz.log(device.name .. ' is alleen thuis, daarom keukentafellamp aangezet voor 20 minuten', domoticz.LOG_INFO)
iemandThuis.set(2)
Posted: Saturday 18 January 2020 15:28
by waaren
Wous wrote: Saturday 18 January 2020 9:21
That was not the real issue.
In your code you misplaced
iemandThuis.value
in such a way that it was interpreted as the second parameter of the domoticz.log function (the loglevel) where it supposed to be part of the first parameter (the string to display).
Posted: Sunday 17 May 2020 13:10
by Larsoss
devices = {
'Wouter',
'Marieke'
logging = {
iemandThuis.set(1)
--lamp.dimLevel(60)
iemandThuis.set(2)
So if I want to use your script what value should I change? I use Idetect, and have the values "Is iemand thuis."
My lamp is called ''Woonkamerlamp''
And your Device is your phone I assume? So in my situation Lars Iphone
So like this?
devices = {
'Lars Iphone',
'Desiree Huawei'
logging = {
local iemandThuis = domoticz.variables('Is iemand thuis.')
local lamp = domoticz.devices('Woonkamerlamp')
iemandThuis.set(1)
lamp.dimLevel(60)
iemandThuis.set(2)
