Presence and welcome light  [Solved]
Wous
Post by Wous »
Although DzVents seems to be powerful, I have to say that I've had more succes with other languages. Nevertheless I want to manage this language finally. Can someone help me with the next code?
I want to convert my mobile phone switches to the amount of people who are at home. At night, I want to trigger the arrival a light to switch on.
Next code gives a log that says who's arriving / leaving. No other logs are given and the User Variable isn't updated. What's wrong?
		devices = {
			'Wouter',
			'Marieke'
	logging = {
    level = domoticz.LOG_DEBUG,
    marker = "iemandThuis - "
	execute = function(domoticz, device, triggerInfo)
	    local iemandThuis = domoticz.variables('iemandThuis')
	    local lamp = domoticz.devices('Banklamp')
	    domoticz.log('Nu is de bezetting: ', iemandThuis.value)
	    --local lamp = domoticz.devices('Keukentafellamp')
	    if device.active then
		    domoticz.log(device.name .. ' is thuis gekomen', domoticz.LOG_INFO)
		    if iemandThuis.value == 0 then
		        domoticz.log('nu moet de uservariable 1 worden')
	            iemandThuis.set(1)
	            if domoticz.time.isNightTime then
			        lamp.switchOn().forMin(20)
			        --lamp.dimLevel(60)
			        domoticz.log(device.name .. ' is alleen thuis, daarom keukentafellamp aangezet voor 20 minuten')
	        elseif iemandThuis.value == 1 then
	            iemandThuis.set(2)
	    else domoticz.log(device.name .. ' is vertrokken', domoticz.LOG_INFO)
	        if iemandThuis == 2 then
	            domoticz.variables('iemandThuis').set(1)
	        elseif iemandThuis == 1 then
	            domoticz.variables('iemandThuis').set(0)
boum
Domoticz version: 4.10717
Re: Presence and welcome light
Post by boum »
Code looks good.
I can only think to check the value and the type of the variable is integer, just add the log line:
	    domoticz.log('iemandThuis is ' .. iemandThuis.type .. ' and value ' .. iemandThuis.value, domoticz.LOG_INFO)
Re: Presence and welcome light  [Solved]
Wous wrote: Friday 17 January 2020 22:20 Can someone help me with the next code?
The above line is incorrect. it should be
domoticz.log('Nu is de bezetting: '  ..  iemandThuis.value, domoticz.LOG_INFO)
Can you try this ? If not working as expected please include the log.
return
        devices = {
            'Wouter',
            'Marieke'
    logging =
        local WouterThuis = domoticz.devices('Wouter').active and 1 or 0
        local MariekeThuis = domoticz.devices('Marieke').active and 1 or 0
        local inHouseBefore = iemandThuis.value
        local peopleAtHome = WouterThuis + MariekeThuis
        domoticz.log('Nu is de bezetting: ' .. iemandThuis.value,domoticz.LOG_INFO)
            if inHouseBefore < 1  and domoticz.time.isNightTime then
                --lamp.dimLevel(60)
                domoticz.log(device.name .. ' is alleen thuis, daarom keukentafellamp aangezet voor 20 minuten',domoticz.LOG_INFO )
        if inHouseBefore ~= peopleAtHome  then iemandThuis.set(peopleAtHome) end
Wous
Post by Wous »
That's it! domoticz.LOG_INFO is needed apparently.. Works as I wanted..
    -- Count the attendees, based on the mobile phones (look for Check_presence)
    -- On arrival after sunset light is switched on for x minutes.
		devices = {
			'switch 1',
			'switch 2'
	logging = {
    level = domoticz.LOG_INFO,
	    --local lamp = domoticz.devices('Banklamp')
	            iemandThuis.set(1)
			        lamp.dimLevel(60)
			        domoticz.log(device.name .. ' is alleen thuis, daarom keukentafellamp aangezet voor 20 minuten', domoticz.LOG_INFO)
	            iemandThuis.set(2)
Wous wrote: Saturday 18 January 2020 9:21 That's it! domoticz.LOG_INFO is needed apparently.. Works as I wanted..
That was not the real issue.
In your code you misplaced
iemandThuis.value
in such a way that it was interpreted as the second parameter of the domoticz.log function (the loglevel) where it supposed to be part of the first parameter (the string to display).
Larsoss
Post by Larsoss »
Wous wrote: Friday 17 January 2020 22:20 Although DzVents seems to be powerful, I have to say that I've had more succes with other languages. Nevertheless I want to manage this language finally. Can someone help me with the next code?
		devices = {
			'Wouter',
			'Marieke'
	logging = {
	            iemandThuis.set(1)
			        --lamp.dimLevel(60)
	            iemandThuis.set(2)
So if I want to use your script what value should I change? I use Idetect, and have the values ​​"Is iemand thuis."
My lamp is called ''Woonkamerlamp''
And your Device is your phone I assume? So in my situation Lars Iphone
So like this?
		devices = {
			'Lars Iphone',
			'Desiree Huawei'
	logging = {
	    local iemandThuis = domoticz.variables('Is iemand thuis.')
	    local lamp = domoticz.devices('Woonkamerlamp')
	            iemandThuis.set(1)
			        lamp.dimLevel(60)
	            iemandThuis.set(2)
Raspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
Users browsing this forum: TiXav and 1 guest
