Zigate with Paulmann 500.44 dimmer creates 2 devices
Posted: Tuesday 14 January 2020 20:30
by waltervl
I have bought a Paulmann LED dimmer https://en.paulmann.com/indoor-lighting ... w-ac/50044
It connects but Domoticz creates 2 exactly the same devices in the devicelist. I am on latest stable Zigate plugin and latest firmware (but just updated before this action). Domoticz v4.11070
Log file while creating:
- Screenshot_2020-01-14 Thuis.png (30.38 KiB) Viewed 483 times
- Spoiler: show
- 2020-01-14 20:18:29.173 Status: (ZiGate) Entering work loop.
2020-01-14 20:18:29.173 Status: (ZiGate) Initialized version 4.5, author 'zaraki673 pipiche38'
2020-01-14 20:18:29.178 Status: (ZiGate) Zigate plugin stable-4.5.9 started
2020-01-14 20:18:29.179 Status: (ZiGate) Python Version - 3.6.9 (default, Nov 7 2019, 10:44:02)
2020-01-14 20:18:29.179 Status: (ZiGate) Switching Heartbeat to 5 s interval
2020-01-14 20:18:29.179 Status: (ZiGate) DomoticzVersion: 4.11070
2020-01-14 20:18:29.179 Status: (ZiGate) DomoticzHash: b55b8274a
2020-01-14 20:18:29.179 Status: (ZiGate) DomoticzBuildTime: 2019-08-05 10:16:51
2020-01-14 20:18:29.179 Status: (ZiGate) load PluginConf
2020-01-14 20:18:29.180 Status: (ZiGate) enablegroupmanagement set to 1
2020-01-14 20:18:29.180 Status: (ZiGate) enableReadAttributes set to 1
2020-01-14 20:18:29.180 Status: (ZiGate) channel set to 17
2020-01-14 20:18:29.180 Status: (ZiGate) filename set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-08.json
2020-01-14 20:18:29.180 Status: (ZiGate) pluginHome set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/
2020-01-14 20:18:29.180 Status: (ZiGate) homedirectory set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/
2020-01-14 20:18:29.180 Status: (ZiGate) pluginData set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/Data/
2020-01-14 20:18:29.180 Status: (ZiGate) pluginConfig set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/Conf/
2020-01-14 20:18:29.180 Status: (ZiGate) pluginOTAFirmware set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-01-14 20:18:29.180 Status: (ZiGate) pluginReports set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/Reports/
2020-01-14 20:18:29.180 Status: (ZiGate) pluginWWW set to /home/udoox86/domoticz/plugins/Domoticz-Zigate/www/
2020-01-14 20:18:29.180 Status: (ZiGate) Opening DomoticzDB in raw
2020-01-14 20:18:29.182 Status: (ZiGate) Plugin Database: DeviceList-8.txt
2020-01-14 20:18:29.196 Status: (ZiGate) DeviceConf loaded
2020-01-14 20:18:29.196 Status: (ZiGate) load ListOfDevice
2020-01-14 20:18:29.242 Status: (ZiGate) Entries loaded from /home/udoox86/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-8.txt : 19
2020-01-14 20:18:29.247 Status: (ZiGate) Transport mode: USB
2020-01-14 20:18:29.247 Status: (ZiGate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2020-01-14 20:18:29.248 Status: (ZiGate) Zigate set Time Server
2020-01-14 20:18:29.248 Status: (ZiGate) Configure Permit To Join
2020-01-14 20:18:29.248 Status: (ZiGate) Request Accepting new Hardware for ever
2020-01-14 20:18:29.249 Status: (ZiGate) Trigger a Topology Scan
2020-01-14 20:18:29.249 Status: (ZiGate) Trigger a Energy Level Scan
2020-01-14 20:18:29.352 Status: (ZiGate) Major Version Num: 0003
2020-01-14 20:18:29.353 Status: (ZiGate) Installer Version Number: 031a
2020-01-14 20:18:29.659 Status: (ZiGate) Accepting new Hardware: On
2020-01-14 20:18:29.771 Status: (ZiGate) Zigate addresses ieee: 00158d0001ed4521 , short addr: 0000
2020-01-14 20:18:29.771 Status: (ZiGate) Network state UP, PANID: 4e6c extPANID: 0x4e8fd40d0afd69a1 Channel: 11
2020-01-14 20:18:29.882 Status: (ZiGate) Number of devices recently active in Zigate = 9
2020-01-14 20:18:39.303 (ZiGate) Group Management - Init phase
2020-01-14 20:18:39.304 (ZiGate) --->GroupList.pck exists
2020-01-14 20:18:39.304 (ZiGate) --->Last Update of GroupList: 1578519150.9066834
2020-01-14 20:18:39.304 (ZiGate) ------------>Config file exists /home/udoox86/domoticz/plugins/Domoticz-Zigate/Conf/ZigateGroupsConfig-08.txt
2020-01-14 20:18:39.304 (ZiGate) ------------>Last Update of TXT Config File: 1559371930.9298615
2020-01-14 20:18:39.304 (ZiGate) ------------>Json Config file exists
2020-01-14 20:18:39.304 (ZiGate) ------------>Last Update of JSON Config File: 1571339970.1409502
2020-01-14 20:18:39.408 (ZiGate) TxPower set to: 00
2020-01-14 20:18:39.195 Status: (ZiGate) Zigate set to Certification : CE
2020-01-14 20:18:39.195 Status: (ZiGate) Start Group Management
2020-01-14 20:18:39.197 Status: (ZiGate) Start Web Server connection
2020-01-14 20:18:39.215 Status: (ZiGate) Web backend for Web User Interface started on port: 9440
2020-01-14 20:18:39.215 Status: (ZiGate) Plugin with Zigate firmware 031a correctly initialized
2020-01-14 20:18:39.304 Status: (ZiGate) --------->No update of Groups needed
2020-01-14 20:18:44.222 (ZiGate) Group: 81ba - ZiGate - Group woonkamer
2020-01-14 20:18:44.222 (ZiGate) Group: 81ba - [('58fc', '01'), ('a194', '01'), ('6216', '01'), ('0000', '01')]
2020-01-14 20:18:44.222 (ZiGate) - device: a194/01 90fd9ffffee58799
2020-01-14 20:18:44.222 (ZiGate) - device: 0000/01 00158d0001ed4521
2020-01-14 20:18:44.222 (ZiGate) Group: 0000 - ZiGate - Zigate Group 0000
2020-01-14 20:18:44.222 (ZiGate) Group: 0000 - [('4c74', '01')]
2020-01-14 20:18:44.222 (ZiGate) - device: 4c74/01 00158d00032d3827
2020-01-14 20:18:44.223 Status: (ZiGate) Group Management - startup done
2020-01-14 20:18:58.725 (ZiGate) Decode8043 - Overwrite ProfileID {} with 0104 from Ep: 01
2020-01-14 20:18:58.725 (ZiGate) Decode8043 - Overwrite ZDeviceID {} with 0104 from Ep: 01
2020-01-14 20:18:58.462 Status: (ZiGate) Device Annoucement ShortAddr: 3057, IEEE: 00158d00031458b5
2020-01-14 20:18:58.621 Status: (ZiGate) [-] NEW OBJECT: 3057 Request Simple Descriptor for Ep: 01
2020-01-14 20:18:58.725 Status: (ZiGate) [-] NEW OBJECT: 3057 Simple Descriptor EP 01
2020-01-14 20:18:58.725 Status: (ZiGate) [-] NEW OBJECT: 3057 ProfileID 0104
2020-01-14 20:18:58.725 Status: (ZiGate) [-] NEW OBJECT: 3057 ZDeviceID 0101
2020-01-14 20:18:58.726 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster IN Count: 07
2020-01-14 20:18:58.726 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster In 1: 0000 (Basic)
2020-01-14 20:18:58.727 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster In 2: 0004 (Groups)
2020-01-14 20:18:58.727 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster In 3: 0003 (Identify)
2020-01-14 20:18:58.727 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster In 4: 0006 (On/Off)
2020-01-14 20:18:58.727 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster In 5: 0008 (Level Control)
2020-01-14 20:18:58.727 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster In 6: 0005 (Scenes)
2020-01-14 20:18:58.728 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster In 7: 1000 (Touchlink)
2020-01-14 20:18:58.728 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster OUT Count: 01
2020-01-14 20:18:58.728 Status: (ZiGate) [-] NEW OBJECT: 3057 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2020-01-14 20:18:59.238 (ZiGate) Too early, let's try to get the Model
2020-01-14 20:18:59.235 Status: (ZiGate) [0] NEW OBJECT: 3057 Request Model Name
2020-01-14 20:19:04.225 (ZiGate) Too early, let's try to get the Model
2020-01-14 20:19:04.220 Status: (ZiGate) [1] NEW OBJECT: 3057 Request Model Name
2020-01-14 20:19:09.233 (ZiGate) GetType - Model {} Profile ID : 0104 ZDeviceID : 0101
2020-01-14 20:19:09.234 (ZiGate) GetType - Model {} not found with Ep: 01 in DeviceConf. Continue with ClusterSearch
2020-01-14 20:19:09.234 (ZiGate) GetType - ClusterSearch return : Switch/LvlControl/
2020-01-14 20:19:09.236 (ZiGate) Request a Bind for 3057/01 on Cluster 0006
2020-01-14 20:19:09.236 (ZiGate) Request a Bind for 3057/01 on Cluster 0008
2020-01-14 20:19:09.236 (ZiGate) Request a Bind for 3057/01 on Cluster 0000
2020-01-14 20:19:09.232 Status: (ZiGate) [2] NEW OBJECT: 3057 Request Model Name
2020-01-14 20:19:10.600 (ZiGate) UpdateDevice - (ZiGate - LvlControl-00158d00031458b5-01) 1:11
2020-01-14 20:19:10.606 (ZiGate) UpdateDevice - (ZiGate - LvlControl-00158d00031458b5-01) 1:11
- Spoiler: show
- NwkId : "3057"
Stamp : Object {"Time":"2020-01-14 20:19:10","MsgType":"8102","LastSeen":"14/01/2020 20:18:58"}
Health : "Live"
Status : "inDB"
Battery : ""
RSSI : 177
Model : ""
IEEE : "00158d00031458b5"
ProfileID : "0104"
ZDeviceID : "0101"
DeviceType : "FFD"
LogicalType : "Router"
PowerSource : "Main"
App Version : "1"
Stack Version : "1"
HW Version : "1"
LastSeen : "14/01/2020 20:18:58"
Ep : Array[1] [{"Ep":"01","ClusterList":[{"0006":"On/Off"},{"0000":"Basic"},{"0004":"Groups"},{"0003":"Identify"},{"0008":"Level Control"},{"0005":"Scenes"},{"1000":"Touchlink"},{"0019":"Over-the-Air Upgrade"}]}]
WidgetList : Array[2] [{"_WidgetID":"139","WidgetName":"ZiGate - LvlControl-00158d00031458b5-01","WidgetType":"LvlControl"},{"_WidgetID":"140","WidgetName":"ZiGate - LvlControl-00158d00031458b5-01","WidgetType":"LvlControl"}]
LastCmds : Array[5] [{"CmdCode":"0120","TimeStamps":"14/01/2020 20:19:10"},{"CmdCode":"0100","TimeStamps":"14/01/2020 20:19:10"},{"CmdCode":"0100","TimeStamps":"14/01/2020 20:19:10"},{"CmdCode":"0100","TimeStamps":"14/01/2020 20:19:10"},{"CmdCode":"0100","TimeStamps":"14/01/2020 20:19:10"}]
Start at 14/01/2020 19:52:05
