I have 8 rooms, each one has a thermostat (a virtual device in Domoticz). dzVents scripts control heating, and also control the thermostat setpoint across the day.
Sometimes, I would like to set the temperature manually for some time. There is no simple way, I could add a switch for each room with auto/manual positions, but this really bloats the interface.
Is it possible to have a thermostat with an additional embedded selector switch? And if not wouldn't this be something super useful for everyone that should be added to the feature request?
Cheers!
Thermostat with manual/auto switch
jake
Re: Thermostat with manual/auto switch
What about if you use a dzvents variables to separate thermostat updates between automatic ones and manual ones: per thermostat make the script put 'auto' or 'man' in it. When you use variables with time stamp, you can even decide how long you want a 'man' status to lock the thermostat in that position. No necessary additional switchesgalinette wrote:Hi,
Cheers!
Downside is that you won't see the difference between manual and automation thermostat control and you also can't put it back in auto mode. Probably you still need 1 switch to remove all manual overrides in that case
kimot
- Domoticz version: v3.8153
I am using separate selector switch for similar case.
I use one setpoint and selector switch decisions if I regulate room air temperature or concrete floor temperature.
I your DzVents script you can divide program execution according actual selector state.
I think for the specific room is quite clear.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
galinette
Yes, I know these two workarounds (script and/or second switch). I just wanted to mention that a thermostat with mode selector button would be super helpful for many, especially on large homes with lots of switches.
I think I will use an additional switch and start thinking into designing my own UI using custom panels, as soon as I have time
