[Solved] Zigate controller and firmware upgrade to 031a
Posted: Thursday 09 January 2020 13:38
Today I upgraded my Zigate USB controller to 031a (from 030e) - I did everything as described in manual and upgrade was executed without problems. Zigate plugin web interface tells me that Zigate was properly initialized with new firmware and is running fine. Domoticz Zigate version is 4.5.9, hardware is old one (blue).
Domoticz still tells me that there are 33 devices in inventory, but non of them is reporting anything. Scan of the network shows 0 devices connected.
Domoticz version is 4.11597, build hash: 70664be92
If I enable "Accept new hardware" - lights on controller does not start blinking. I also pressed the "Erase" button on web interface to "erase the permanent data memory of Zigate" in secret hope that I'll be able to re-pair - but to no avail. If I put it into "accept new hardware" mode and try to pair old devices - nothing happens.
Here is the part of log file:
2020-01-09 13:33:29.216 Status: (Zigate) Initialized version 4.5, author 'zaraki673 pipiche38'
2020-01-09 13:33:29.217 Status: (Zigate) Zigate plugin stable-4.5.9 started
2020-01-09 13:33:29.217 (Zigate) Debug: 0
2020-01-09 13:33:29.217 Status: (Zigate) Python Version - 3.7.3 (default, Oct 7 2019, 12:56:13)
2020-01-09 13:33:29.217 Status: (Zigate) Switching Heartbeat to 5 s interval
2020-01-09 13:33:29.217 Status: (Zigate) DomoticzVersion: 4.11597
2020-01-09 13:33:29.217 Status: (Zigate) DomoticzHash: 70664be92
2020-01-09 13:33:29.217 Status: (Zigate) DomoticzBuildTime: 2019-12-30 00:14:56
2020-01-09 13:33:29.217 Status: (Zigate) load PluginConf
2020-01-09 13:33:29.218 Status: (Zigate) enableReadAttributes set to 1
2020-01-09 13:33:29.218 Status: (Zigate) allowOTA set to 1
2020-01-09 13:33:29.218 Status: (Zigate) batteryOTA set to 1
2020-01-09 13:33:29.218 Status: (Zigate) filename set to /opt/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-07.json
2020-01-09 13:33:29.218 Status: (Zigate) pluginHome set to /opt/domoticz/plugins/Domoticz-Zigate/
2020-01-09 13:33:29.218 Status: (Zigate) homedirectory set to /opt/domoticz/plugins/Domoticz-Zigate/
2020-01-09 13:33:29.218 Status: (Zigate) pluginData set to /opt/domoticz/plugins/Domoticz-Zigate/Data/
2020-01-09 13:33:29.218 Status: (Zigate) pluginConfig set to /opt/domoticz/plugins/Domoticz-Zigate/Conf/
2020-01-09 13:33:29.218 Status: (Zigate) pluginOTAFirmware set to /opt/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-01-09 13:33:29.218 Status: (Zigate) pluginReports set to /opt/domoticz/plugins/Domoticz-Zigate/Reports/
2020-01-09 13:33:29.218 Status: (Zigate) pluginWWW set to /opt/domoticz/plugins/Domoticz-Zigate/www/
2020-01-09 13:33:29.218 Status: (Zigate) Opening DomoticzDB in raw
2020-01-09 13:33:29.218 Status: (Zigate) Plugin Database: DeviceList-7.txt
2020-01-09 13:33:29.221 Status: (Zigate) DeviceConf loaded
2020-01-09 13:33:29.221 Status: (Zigate) load ListOfDevice
2020-01-09 13:33:29.227 Status: (Zigate) Entries loaded from /opt/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-7.txt : 11
2020-01-09 13:33:29.227 Error: (Zigate) checkListOfDevice2Devices - Okrogel switch - 00158d0003496dfd not found in Plugin Database
2020-01-09 13:33:29.227 Status: (Zigate) Transport mode: USB
2020-01-09 13:33:29.227 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2020-01-09 13:33:29.228 Status: (Zigate) Zigate set Time Server
2020-01-09 13:33:29.228 (Zigate) setTimeServer - Setting UTC Time to : 631892009
2020-01-09 13:33:29.228 Status: (Zigate) Software reset
2020-01-09 13:33:29.229 Status: (Zigate) ZigateConf setting Channel(s) to: 0
2020-01-09 13:33:29.229 Status: (Zigate) setChannel - Channel set to : 00000000
2020-01-09 13:33:29.229 Status: (Zigate) Set Zigate as a Coordinator
2020-01-09 13:33:29.229 (Zigate) setTimeServer - Setting UTC Time to : 631892009
2020-01-09 13:33:29.229 Status: (Zigate) Start network
2020-01-09 13:33:29.229 Status: (Zigate) Configure Permit To Join
2020-01-09 13:33:29.229 Status: (Zigate) Request Accepting new Hardware for 254 seconds
2020-01-09 13:33:29.229 Status: (Zigate) Trigger a Topology Scan
2020-01-09 13:33:29.229 Status: (Zigate) Trigger a Energy Level Scan
2020-01-09 13:33:29.229 Status: (Zigate) Network Energy Level Report: 0000
2020-01-09 13:33:29.229 Status: (Zigate) -----------------------------------------------
2020-01-09 13:33:29.229 Status: (Zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
2020-01-09 13:33:29.330 Status: (Zigate) Major Version Num: 0003
2020-01-09 13:33:29.330 Status: (Zigate) Installer Version Number: 031a
2020-01-09 13:33:29.632 Status: (Zigate) 'Factory new' Restart status: NFN_START
2020-01-09 13:33:29.934 Status: (Zigate) Busy Node
2020-01-09 13:33:29.934 (Zigate) Start Network status : Success
2020-01-09 13:33:30.035 (Zigate) Permit Join status: 00
2020-01-09 13:33:30.035 (Zigate) ---> self.permitTojoin['Starttime']: 1578573209
2020-01-09 13:33:30.035 (Zigate) ---> Current time : 1578573210
2020-01-09 13:33:30.035 (Zigate) ---> self.Ping['Permit'] (prev) : None
2020-01-09 13:33:30.035 Status: (Zigate) Accepting new Hardware: Disable
2020-01-09 13:33:30.035 (Zigate) ---> self.Ping['Permit'] (new ) : Off
2020-01-09 13:33:30.141 Status: (Zigate) Zigate addresses ieee: 00158d0001ee04c9 , short addr: 0000
2020-01-09 13:33:30.141 Status: (Zigate) Network state UP, PANID: d9d7 extPANID: 0xf7261c14f504723c Channel: 11
2020-01-09 13:33:30.381 (Zigate) Permit Join status: 01
2020-01-09 13:33:30.381 (Zigate) ---> self.permitTojoin['Starttime']: 1578573209
2020-01-09 13:33:30.381 (Zigate) ---> Current time : 1578573210
2020-01-09 13:33:30.381 (Zigate) ---> self.Ping['Permit'] (prev) : Off
2020-01-09 13:33:30.381 Status: (Zigate) Accepting new Hardware: On
2020-01-09 13:33:30.381 (Zigate) ---> self.Ping['Permit'] (new ) : On
2020-01-09 13:33:30.482 Status: (Zigate) Zigate addresses ieee: 00158d0001ee04c9 , short addr: 0000
2020-01-09 13:33:30.482 Status: (Zigate) Network state UP, PANID: d9d7 extPANID: 0xf7261c14f504723c Channel: 11
2020-01-09 13:33:30.657 Status: (Zigate) Number of devices recently active in Zigate = 33
2020-01-09 13:33:30.657 Status: (Zigate) [00] DevID = 00 Network addr = bbb4 IEEE = 00158d0003496dfd LQI = 098 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.657 Status: (Zigate) [01] DevID = 01 Network addr = 0800 IEEE = 0000000000000000 LQI = 016 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.657 Status: (Zigate) [02] DevID = 02 Network addr = 0000 IEEE = 0000000000000000 LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.657 Status: (Zigate) [03] DevID = 03 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 004 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [05] DevID = 05 Network addr = 0800 IEEE = 0000000000000000 LQI = 016 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [06] DevID = 06 Network addr = 0000 IEEE = 0000000000000000 LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [07] DevID = 07 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 009 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [09] DevID = 09 Network addr = 0800 IEEE = 0000000000000000 LQI = 016 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [10] DevID = 0a Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [11] DevID = 0b Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [12] DevID = 0d Network addr = ff00 IEEE = 00158d0003496dfd LQI = 000 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [13] DevID = 0e Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [14] DevID = 0f Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [15] DevID = 11 Network addr = ff00 IEEE = 00158d0003496dfd LQI = 000 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [16] DevID = 12 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [17] DevID = 13 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [18] DevID = 15 Network addr = ff00 IEEE = 00158d0003496dfd LQI = 000 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.658 Status: (Zigate) [19] DevID = 16 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [20] DevID = 17 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [21] DevID = 19 Network addr = ff00 IEEE = 00158d0003496dfd LQI = 000 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [22] DevID = 1a Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [23] DevID = 1b Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [24] DevID = 1d Network addr = ff00 IEEE = 00158d0003496dfd LQI = 000 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [25] DevID = 1e Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [26] DevID = 1f Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [27] DevID = 21 Network addr = ff00 IEEE = 00158d0003496dfd LQI = 000 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [28] DevID = 22 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [29] DevID = 23 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [30] DevID = 25 Network addr = ff00 IEEE = 00158d0003496dfd LQI = 000 Power = 01 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [31] DevID = 26 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 000 Power = 00 not found in ListOfDevices
2020-01-09 13:33:30.659 Status: (Zigate) [32] DevID = 27 Network addr = 0000 IEEE = 00158d0003496dfd LQI = 255 Power = 00 not found in ListOfDevices
2020-01-09 13:33:39.230 Status: (Zigate) Zigate set to Certification : CE
2020-01-09 13:33:39.230 Status: (Zigate) Start Web Server connection
2020-01-09 13:33:39.236 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2020-01-09 13:33:39.236 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 16897 version: 12217572 - filename: 159698-TRADFRI-driver-lp-1.2.217.ota.ota size: 173246 Bytes
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 10241 version: 13009572 - filename: 10035515-TRADFRI-bulb-cws-1.3.009.ota.ota size: 178366 Bytes
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 8449 version: 12214572 - filename: 159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota size: 168318 Bytes
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 16641 version: 12245572 - filename: 159495-TRADFRI-transformer-1.2.245.ota.ota size: 181118 Bytes
2020-01-09 13:33:39.236 (Zigate) ota_decode_new_image - Image 1004764-TRADFRI-bulb-cws-1.3.009.ota.ota already imported. Type: 10241 with better version 13009572 versus 13009572
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 4548 version: 12214572 - filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota size: 157822 Bytes
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 8707 version: 12221572 - filename: 10035534-TRADFRI-bulb-ws-gu10-1.2.221.ota.ota size: 172734 Bytes
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 4546 version: 12248572 - filename: 159701-TRADFRI-wireless-dimmer-1.2.248.ota.ota size: 172926 Bytes
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 4549 version: 22008631 - filename: 10005778-4.1-TRADFRI-onoff-shortcut-control-2.2.008.ota.ota size: 179582 Bytes
2020-01-09 13:33:39.236 Status: (Zigate) Available Firmware Type: 4353 version: 20022623 - filename: 10005777-4.1-TRADFRI-control-outlet-2.0.022.ota.ota.signed size: 204222 Bytes
2020-01-09 13:33:39.237 Status: (Zigate) Available Firmware Type: 8705 version: 12221572 - filename: 10035514-TRADFRI-bulb-ws-1.2.221.ota.ota size: 172734 Bytes
2020-01-09 13:33:39.237 Status: (Zigate) Available Firmware Type: 16900 version: 20022623 - filename: 10038562-TRADFRI-sy5882-bulb-ws-2.0.022.ota.ota.signed size: 209790 Bytes
2020-01-09 13:33:39.237 Status: (Zigate) Available Firmware Type: 8706 version: 12217572 - filename: 159695-TRADFRI-bulb-ws-1000lm-1.2.217.ota.ota size: 173246 Bytes
2020-01-09 13:33:39.237 Status: (Zigate) Available Firmware Type: 4545 version: 12223573 - filename: 159699-2.1-TRADFRI-remote-control-1.2.223.ota.ota.signed size: 159806 Bytes
2020-01-09 13:33:39.237 Status: (Zigate) Available Firmware Type: 16898 version: 12217572 - filename: 159697-TRADFRI-driver-hp-1.2.217.ota.ota size: 173246 Bytes
2020-01-09 13:33:47.432 (Zigate) TxPower set to: 00
Any idea how to get my devices back?
Please, help!
Cheers and thnx, Jan Zorz
Please, help!
