i found a very cheap wifi led lamp bulb dimmable at Aliexpress : https://www.aliexpress.com/item/4000159 ... 4c4dtQrWad
that use a android app "Techlife Pro".
i ask to developers : is it possible to integrate this to Domoticz ?
i found that someone already found how to integrate this to OpenHab : https://community.openhab.org/t/hacking ... ulbs/85940
TechLife Pro wifi led lamp bulbs
jonhdimagio
- FireWizard
Re: TechLife Pro wifi led lamp bulbs
Found this as well.
https://community.home-assistant.io/t/t ... ate/141510
Reading it, I think it is not easy.
It uses MQTT, redirecting the communication to your own MQTT server is relative easy, but it seems that the communication is binary.
I suggest to use at least a Packet Capture app on your phone, in order to get some ideas, what is going on between your app and the Chinese server.
You can use it with Google Home.
But, I think integrating it into Domoticz and also Home Assistant or OpenHab will remain a real challenge,
Found this as well.
