setRGB & dimTo in one function?  [Solved]
rudder66
Domoticz version: 4.11553
Post by rudder66 »
Hi all!
I use Xiaomi Gateway 2 as a nightlight.
To do this, I use a simple dzvents script:
		devices = { 51 }
	execute = function(domoticz, MOTION)
	local RGB = domoticz.devices(1)
	local LUXMETER = domoticz.devices(50)
    if (MOTION.state == 'On' and domoticz.time.matchesRule('between 21:30 and 60 minutes after sunrise')) then
        if (LUXMETER.lux <= 8 and RGB.active == false) then
            RGB.setRGB(255, 54, 0)
            RGB.dimTo(5)
        elseif (LUXMETER.lux > 8 and RGB.active) then
            RGB.switchOff()
    elseif (MOTION.state == 'Off' and domoticz.time.matchesRule('between 21:30 and 65 minutes after sunrise')) then
        if (RGB.active) then
            RGB.switchOff()
All is well, but there is one problem:
when starting functions
RGB.setRGB (255, 54, 0)
RGB.dimTo (5)
the nightlight is first turned on with 100% brightness, and after that the brightness decreases to the required 5%.
That is, I visually observe a flash.
How to make the nightlight turn on immediately with a given color and brightness?
Thank you!
Re: setRGB & dimTo in one function?
rudder66 wrote: Monday 06 January 2020 9:51 How to make the nightlight turn on immediately with a given color and brightness?
Can you try this ? ( using setColor method of RGBWWW deviceType)
		devices = { 51 }
            RGB.setColor(255, 54, 0, 5)
            RGB.switchOff()
            RGB.switchOff()
rudder66
Re: setRGB & dimTo in one function?  [Solved]
Post by rudder66 »
@waaren, you are just power! Everything works as it should!
I also need to go to the wiki page more often to get acquainted with the updates.
My offline dzvents manual did not have such a function. :(
Solved
