A neo coolcam NAS-PD01Z motion sensor (PIR) switches on the light in my hallway.This has worked well for quite some time now. Yesterday however I noticed that the light was on much more than i'd expect. It kept going on immediately after it switched off. There was nobody in the hallway, so why did the light go on? Sometimes one of my cats trigger this light too, but there were none in the hallway either. So was it the battery in the sensor going weak? I replaced the battery in the unit and it still switched the light on. Looking at domoticz' log file i see that it really is the sensor sensing motion. What is going on? Am I being haunted? According to the deive log the device has been doning this for almostr 2 days now. And then it hit me: 2 days ago I replaced my wifi router by a new, stronger one. This router was bigger than the previous one, and it didn't fit in the location the old router was in. So I had to find a new location for the router and I had placed it inside the meteringcloset (is this even a word in english?). The sensor was no more than 10 centimeters away from the router's antennas, separated only by 1 wood board. So I moved the sensor a little bit further away from the router (roughly 1 meter was the most I could move it) and since then the sensor works fine again.
So it turns out these pir sensors can send out a signal to switch on when influenced by strong wifi signals. The advice to keep some distance between (powerfull) electrical devices is a valid one
