Hello All,
How can I prevent that when I'am rebooting the Raspberry PI3, the TV is starting from Stand-bye and "showing the boot screen"?
The Pi is connected with HDMI to my Denon AVR and connected with HDMI Monitor port to mine Samsung Smart TV.
CEC is already disabled within the Kodi settings, also running on the same Pi....
How can I disapble this under the OS Rasbian?
Verion:
root@Domoticz:~# cat /etc/debian_version
10.2
Thanks in advanced,
Mike
How to prevent TV start at reboot? Topic is solved
AthomeDomotica
- Domoticz version: 2022.2
Domoticz, Controlicz, Philips HUE Gateway and bulbs, Z-Wave (Aecotec Stick) and Fibaro Dimmers, RFLink Gateway.
- Egregius
- Domoticz version: v2024.7
Re: How to prevent TV start at reboot?
A Rpi is already minimal hardware to run either Domoticz or Kodi. Use 2 devices for it and it'll be a lot better.
AthomeDomotica
Thanks for the reply
With the controller is no issue.
Only the reboot CEC/HDMI issue....
So if someone has fixed this, please let me know
Thanks in advance
Mike
This a possibility but not the question.Egregius wrote: Friday 27 December 2019 6:30 A Rpi is already minimal hardware to run either Domoticz or Kodi. Use 2 devices for it and it'll be a lot better.
Thanks in advance
Mike
AthomeDomotica
In the meanwhile, ..... found the solution for mine set-up
Here the solution and extra info on commands for HDMI
https://elinux.org/RPiconfig
hdmi_ignore_cec_init Doesn't sent initial active source message. Avoids bringing (CEC enabled) TV out of standby and channel switch when rebooting.
hdmi_ignore_cec_init=1
This did the trick.
Cheers,
Mike
This did the trick.
Cheers,
Mike
