Synology install doesn't run Topic is solved
Installed the package on Synology DS718+ but when I run it, it starts loading and after a few seconds it shows the RUN button again so it didn't start. Where can I find some logfile or something to check what possibly went wrong? Or does somebody have any idea what to check?
- jumbotroll
Re: Synology install doesn't run
If you installed the Python version, you have to install Python 3.xx first or domoticz don't run.Maurice69 wrote: ↑Thursday 26 December 2019 14:14 Installed the package on Synology DS718+ but when I run it, it starts loading and after a few seconds it shows the RUN button again so it didn't start. Where can I find some logfile or something to check what possibly went wrong? Or does somebody have any idea what to check?
https://global.download.synology.com/do ... mber=24922
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
Thnx! That was the solution....
Hello
I had domoticz version 4.0.97 running on synology DS218+ with DSM version 6.6.2-24922 update 2. All was working fine.
I use theme Aurora also
When updating to version 4.10.717 found on http://www.jadahl.com Clicking the run button has no effect the plug-in stays on stopped.
I went back to version 4.0.97 reinstall it and it works
What do I wrong with the installation of the newest version ?
Thanks in advance for your help
Patou
Patou
Users browsing this forum: Amazon [Bot] and 1 guest
