Problem with groups and dzVents [Solved]
Posted: Saturday 21 December 2019 13:20
by havnegata
First of all I want to thank all the great contributors on this forum! I have gotten a lot help just by looking at the examples, but now I'm a bit stuck. I have TWO Ikea bulbs which I'm trying to turn on simultaneously by using two motion sensors and found that I can turn on ONE of them (710) by using this code (some of you will obviously recognize the code, thanks to you!):
devices = {
'Bevegelse_trapp2etasje', 'Bevegelse_Fibaro'}
execute = function(dz, item)
local LuxDevice = dz.devices(695)
local Lux = LuxDevice.lux
local Lights = dz.devices(710)
if Lux < 12 and item.state == "On" then
Lights.cancelQueuedCommands()
if dz.time.matchesRule("at 23:01-06:00") then
Lights.dimTo(10)
Lights.dimTo(50)
elseif item.state == "Off" and Lights.state == "On" then
Lights.switchOff().afterSec(90)
But as I stated in the beginning I want to turn BOTH bulbs on simultaneously, so then I put them in a group and called it "Lys2etasje".
devices = {
local Lights = dz.groups("Lys2etasje")
Lights.dimTo(10)
Lights.dimTo(50)
But the last script doesn't turn any bulbs on. Any thoughts?
Edit: no errors in logs (Have enabled Debug (Everything))
I'm using Conbee II and two Ikea Tradfri bulbs, a motion sensor from Fibaro and one from Xiaomi and deCONZ plugin
Re: Problem with groups and dzVents
Posted: Saturday 21 December 2019 17:51
by waaren
havnegata wrote: Saturday 21 December 2019 13:20
Kind of surprised you don't see any errors in the log. dimTo is not one of the
available group methods and if I try your script at my test system it will come with the message:
Error: dzVents: Error: (2.5.3) ... 18: attempt to call a nil value (field 'dimTo')
Please see below for a script example where you can overcome this by using a function that will loop through all devices in a group.
return
on =
devices =
'Bevegelse_Fibaro',
logging =
level = domoticz.LOG_DEBUG
_G.logMarker = _G.moduleLabel
local function groupDimTo(group, level)
group.devices().forEach(function(dv)
dv.dimTo(level)
end)
groupDimTo(Lights, 10)
groupDimTo(Lights, 50)
Posted: Saturday 21 December 2019 18:25
by havnegata
Wow! That's awesome! Thanks a lot!
Posted: Monday 23 December 2019 21:33
by havnegata
Now there is only a small problem. The lights turn on fine, but they won't turn off. There are still no errors in the log
Posted: Monday 23 December 2019 22:05
by waaren
havnegata wrote: Monday 23 December 2019 21:33
My guess is that the state of Lights is not "On" when the script reaches line 37. Can you try to change that line from
to
elseif item.state == "Off" and Lights.state ~= "Off" then
Posted: Wednesday 25 December 2019 17:51
by havnegata
Thanks for your help
I tried your solution, but it didn't give me my wanted result. So I minimized the script a little and this works:
return
on =
devices =
'Bevegelse_Fibaro',
logging =
level = domoticz.LOG_DEBUG,
marker = "Yngve"
if item.state == "On" then
Lights.switchOn().checkFirst()
Lights.switchOff().afterSec(60)
But it would be nice to be able to expand it a bit, but then it won't turn off:
return
on =
devices =
'Bevegelse_Fibaro',
logging =
marker = "Yngve"
dv.dimTo(level)
end)
Lights.switchOff().afterSec(90) -- also, without success, tried with: groupDimTo(Lights, 0)
This part works:
return
on =
devices =
'Bevegelse_Fibaro',
logging =
marker = "Yngve"
dv.dimTo(level)
end)
But the Off-part doesn't:
I also tried to exchange this part:
with this part:
groupDimTo(Lights, 0).afterSec(90)
without success
Posted: Saturday 28 December 2019 0:36
by waaren
havnegata wrote: Wednesday 25 December 2019 17:51
Hi can you try this ?
return
on =
devices =
'Bevegelse_Fibaro',
logging =
dv.dimTo(level)
end)
local function groupOff(group, delay)
delay = delay or 0
dv.switchOff().afterSec(delay)
end)
elseif item.state == "Off" then
groupOff(Lights, 90)
Posted: Sunday 29 December 2019 10:31
by havnegata
Sorry for the late reply, but because of Christmas I haven't been at home. Tested now and it still doesn't turn off. Here is something from the log (I find it difficult to extract the relevant loglines, tips is appreciated
- Spoiler: show
return
on =
devices =
-- 'Bevegelse_trapp2etasje',
'Bevegelse_Fibaro',
'Bevegelse_StueSoer', -- added another motion sensor for simplifying testing
logging =
marker = "Yngve" -- this helped me a bit for filtering
-- _G.logMarker = _G.moduleLabel -- what does this do?
dv.dimTo(level)
end)
delay = delay or 0
end)
elseif item.state == "" then
2019-12-29 10:27:22.753 Status: dzVents: Info: Yngve: ------ Start internal script: Test lys 2 etasje: Device: "Bevegelse_StueSoer (Aeotec_gen5)", Index: 139
2019-12-29 10:27:22.754 Status: dzVents: Debug: Yngve: Processing device-adapter for Lux_Fibaro: Lux device adapter
2019-12-29 10:27:22.754 Status: dzVents: Debug: Yngve: Processing device-adapter for Lys2etasje: Group device adapter
2019-12-29 10:27:22.755 Status: dzVents: Debug: Yngve: Processing device-adapter for 2etasje_gangnord: Switch device adapter
2019-12-29 10:27:22.755 Status: dzVents: Debug: Yngve: Constructed timed-command: Set Level 50
2019-12-29 10:27:22.756 Status: dzVents: Debug: Yngve: Processing device-adapter for 2etasje_gangsør: Switch device adapter
2019-12-29 10:27:22.756 Status: dzVents: Debug: Yngve: Constructed timed-command: Set Level 50
2019-12-29 10:27:22.756 Status: dzVents: Info: Yngve: ------ Finished Test lys 2 etasje
Posted: Sunday 29 December 2019 15:15
by waaren
havnegata wrote: Sunday 29 December 2019 10:31
Why did you remove the Off in this line ?
It should either be
or
Posted: Sunday 29 December 2019 16:07
by havnegata
Don't know how that happened, but anyways, great success! Thanks again, waaren, great support!
