Problem with groups and dzVents  [Solved]
havnegata
Domoticz version: V4.10162
Post by havnegata »
First of all I want to thank all the great contributors on this forum! I have gotten a lot help just by looking at the examples, but now I'm a bit stuck. I have TWO Ikea bulbs which I'm trying to turn on simultaneously by using two motion sensors and found that I can turn on ONE of them (710) by using this code (some of you will obviously recognize the code, thanks to you!):
            devices = {
                'Bevegelse_trapp2etasje', 'Bevegelse_Fibaro'}
    execute = function(dz, item)
            local LuxDevice = dz.devices(695)
            local Lux = LuxDevice.lux
            local Lights = dz.devices(710)
            if Lux < 12 and item.state == "On" then
            Lights.cancelQueuedCommands()
		if dz.time.matchesRule("at 23:01-06:00") then
			Lights.dimTo(10)
			Lights.dimTo(50)
        elseif item.state == "Off" and Lights.state == "On" then
            Lights.switchOff().afterSec(90)
But as I stated in the beginning I want to turn BOTH bulbs on simultaneously, so then I put them in a group and called it "Lys2etasje".
            devices = {
            local Lights = dz.groups("Lys2etasje")
			Lights.dimTo(10)
			Lights.dimTo(50)
But the last script doesn't turn any bulbs on. Any thoughts?
Edit: no errors in logs (Have enabled Debug (Everything))
I'm using Conbee II and two Ikea Tradfri bulbs, a motion sensor from Fibaro and one from Xiaomi and deCONZ plugin
Re: Problem with groups and dzVents
havnegata wrote: Saturday 21 December 2019 13:20 I'm a bit stuck. I have TWO Ikea bulbs which I'm trying to turn on simultaneously by using two motion sensors
Kind of surprised you don't see any errors in the log. dimTo is not one of the available group methods and if I try your script at my test system it will come with the message:
Error: dzVents: Error: (2.5.3) ... 18: attempt to call a nil value (field 'dimTo')
Please see below for a script example where you can overcome this by using a function that will loop through all devices in a group.
return
    on =
        devices =
            'Bevegelse_Fibaro',
       logging =
        level = domoticz.LOG_DEBUG
        _G.logMarker =  _G.moduleLabel
        local function groupDimTo(group, level)
            group.devices().forEach(function(dv)
                dv.dimTo(level)
            end)
                groupDimTo(Lights, 10)
                groupDimTo(Lights, 50)
havnegata
Post by havnegata »
Wow! That's awesome! Thanks a lot!
havnegata
Post by havnegata »
Now there is only a small problem. The lights turn on fine, but they won't turn off. There are still no errors in the log
havnegata wrote: Monday 23 December 2019 21:33 Now there is only a small problem. The lights turn on fine, but they won't turn off. There are still no errors in the log
My guess is that the state of Lights is not "On" when the script reaches line 37. Can you try to change that line from
to
        elseif item.state == "Off" and Lights.state ~= "Off" then
havnegata
Post by havnegata »
Thanks for your help :-) I tried your solution, but it didn't give me my wanted result. So I minimized the script a little and this works:
return
    on =
        devices =
            'Bevegelse_Fibaro',
       logging =
        level = domoticz.LOG_DEBUG,
        marker = "Yngve"
         if item.state == "On" then
            Lights.switchOn().checkFirst()
            Lights.switchOff().afterSec(60)
But it would be nice to be able to expand it a bit, but then it won't turn off:
return
    on =
        devices =
            'Bevegelse_Fibaro',
       logging =
        marker = "Yngve"
                dv.dimTo(level)
 end)
            Lights.switchOff().afterSec(90)					-- also, without success, tried with: groupDimTo(Lights, 0)
This part works:
return
    on =
        devices =
            'Bevegelse_Fibaro',
       logging =
        marker = "Yngve"
                dv.dimTo(level)
 end)
But the Off-part doesn't:
I also tried to exchange this part:
with this part:
groupDimTo(Lights, 0).afterSec(90)
without success
havnegata wrote: Wednesday 25 December 2019 17:51 Thanks for your help :-) I tried your solution, but it didn't give me my wanted result. So I minimized the script a little and this works:
Hi can you try this ?
return
    on =
        devices =
            'Bevegelse_Fibaro',
       logging =
                dv.dimTo(level)
            end)
        local function groupOff(group, delay)
            delay = delay or 0
                dv.switchOff().afterSec(delay)
            end)
        elseif item.state == "Off" then
            groupOff(Lights, 90)
havnegata
Post by havnegata »
Sorry for the late reply, but because of Christmas I haven't been at home. Tested now and it still doesn't turn off. Here is something from the log (I find it difficult to extract the relevant loglines, tips is appreciated :-) ).
return
    on =
        devices =
           -- 'Bevegelse_trapp2etasje',
            'Bevegelse_Fibaro',
            'Bevegelse_StueSoer',               -- added another motion sensor for simplifying testing
       logging =
        marker = "Yngve"                        -- this helped me a bit for filtering
       -- _G.logMarker =  _G.moduleLabel        -- what does this do?
                dv.dimTo(level)
            end)
            delay = delay or 0
            end)
        elseif item.state == "" then
2019-12-29 10:27:22.753 Status: dzVents: Info: Yngve: ------ Start internal script: Test lys 2 etasje: Device: "Bevegelse_StueSoer (Aeotec_gen5)", Index: 139
2019-12-29 10:27:22.754 Status: dzVents: Debug: Yngve: Processing device-adapter for Lux_Fibaro: Lux device adapter
2019-12-29 10:27:22.754 Status: dzVents: Debug: Yngve: Processing device-adapter for Lys2etasje: Group device adapter
2019-12-29 10:27:22.755 Status: dzVents: Debug: Yngve: Processing device-adapter for 2etasje_gangnord: Switch device adapter
2019-12-29 10:27:22.755 Status: dzVents: Debug: Yngve: Constructed timed-command: Set Level 50
2019-12-29 10:27:22.756 Status: dzVents: Debug: Yngve: Processing device-adapter for 2etasje_gangsør: Switch device adapter
2019-12-29 10:27:22.756 Status: dzVents: Debug: Yngve: Constructed timed-command: Set Level 50
2019-12-29 10:27:22.756 Status: dzVents: Info: Yngve: ------ Finished Test lys 2 etasje
havnegata wrote: Sunday 29 December 2019 10:31 Sorry for the late reply, but because of Christmas I haven't been at home. Tested now and it still doesn't turn off. Here is something from the log (I find it difficult to extract the relevant loglines, tips is appreciated :-) ).
Why did you remove the Off in this line ?
It should either be
or
elseif item.state ~= "On" then
havnegata
Post by havnegata »
:oops: Don't know how that happened, but anyways, great success! Thanks again, waaren, great support! :D
Users browsing this forum: Google [Bot] and 0 guests
