Hi Guys,
My 2 Z-wave nodes with batteries (molitesensor and 2-pole switch from benext) do not automatically send temperature updates. (only if I wake them up manually)
The wake-up time is set to 300s.
The same value is always repeated.
Anyone idea's?
Thanks in advance
Grtz,
Mathias
Temperature monitoring
Re: Temperature monitoring
I have similar problem as temperature is not updated automatically.
Appreciate any idea.
Regards,
Roberto.
Regards,
Roberto.
rrozema
Please include your domoticz version plus platform you installed it on for best chances on getting answers.
One reason can be that your device is not yet properly recognised by openzwave. You can try to use the "vernieuw node info" button on the z-wave hardware page to make sure the device information is complete and up-to-date. Best wake up your device right after you've pressed the "vernieuw node info"to make sure the information gets sent in time. Keep (in a 2nd browser window) an eye on Domoticz log window to see if it refreshes properly.
