error in logs zigate
tjabas
Hi!
i keep geting this error in the log:
2019-12-17 11:19:44.285 Error: (zigate) Command: 0x0092:On/Off failed on Källartrappan ikea lampa
2019-12-17 11:19:44.285 Error: (zigate) - Device: Källartrappen ikea lampa NwkID: a7bd IEEE: 086bd7fffe0102c8
2019-12-17 11:19:44.285 Error: (zigate) - Code: e9 Status: No acknowledgement received when expected
2019-12-17 11:19:45.980 Error: (zigate) Command: 0x0092:On/Off failed on Hörnlampa
2019-12-17 11:19:45.980 Error: (zigate) - Device: Hörnlampa NwkID: b64a IEEE: 000d6ffffe1e55ce
2019-12-17 11:19:45.980 Error: (zigate) - Code: e9 Status: No acknowledgement received when expected
is there anyone that knows what this means?
and is it something to be worried about?
i have been googling it , but i cant find anything.
thanks.
thanks.
Re: error in logs zigate
These are logs telling that a command ( On or Off) has been sent to a device (Källartrappan ikea lampa), but Zigate didn't get any ack and so suspect that the command was not received.
Same for Hörnlampa
You might have some interferences .
Do you know what is your Wifi 2.4Ghz channel and you Zigbee channel (should get it in the log at plugin start)
Same for Hörnlampa
tjabas
if you mean the the wifi channel on my router? if so its set to 1 on my wifi router.
and in domoticz it shows: 2019-12-17 16:45:59.745 Status: (zigate) Network state UP, PANID: a968 extPANID: 0x42345bd5086b4cc9 Channel: 15
You might be interested on that article:https://github.com/pipiche38/Domoticz-Z ... -Zigbee.md
while I think Wifi on 1 and Zigbee on 15 should be acceptable.
tjabas
thanks, i will check that
tjabas
i have checked my channel settings, and i have made some changes so it seems like the error codes doesnt occur so often any more, but i have an other error that appears sometimes:
2019-12-19 14:42:45.952 Error: (zigate) LQI:LQIresp - Receive unexpected message 6d000903036edf42345bd5086b4cc9000d6ffffe9a085a0f496975b842345bd5086b4cc9000b3cfffef160fa0f7169863942345bd5086b4cc9000d6ffffe8ea8430f2669a7bd
what does that mean?
Not an issue at all, it is most likely due to a restart of the plugin while just before it was preparing a Topologie report and at restart the plugin receive an answer of a previous request sent before the restart ..tjabas wrote: Thursday 19 December 2019 14:45 i have checked my channel settings, and i have made some changes so it seems like the error codes doesnt occur so often any more, but i have an other error that appears sometimes:
tjabas
ok, thank you for the quick reply, then i will ignore that.
thank you.
thank you.
tjabas
is till get some errors, i have been trying different channels without any success , i have noticed another thing in the log:
zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
what does this mean?
This doesn't sound as an error. Please put the context, but I think this is the output of an Energy Report, which report some Transmission Failure !tjabas wrote: Monday 30 December 2019 18:53 is till get some errors, i have been trying different channels without any success , i have noticed another thing in the log:
tjabas
ok, this occur after a reboot of the pi, or of the zigate plugin.
i will post some more of the log.
2019-12-31 14:11:00.150 Status: (zigate) Network Energy Level Report: 0000
2019-12-31 14:11:00.151 Status: (zigate) -----------------------------------------------
2019-12-31 14:11:00.151 Status: (zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
2019-12-31 14:11:00.151 Status: (zigate) 0000 <- 6edf 32 0 193 175 185 160 169 161
2019-12-31 14:11:00.151 Status: (zigate) 0000 <- 75fe 30 0 198 166 174 167 163 162
2019-12-31 14:11:00.151 Status: (zigate) 0000 <- 8639 37 0 204 171 160 195 161 188
2019-12-31 14:11:00.151 Status: (zigate) 0000 <- b7bc 33 0 183 176 156 171 179 156
2019-12-31 14:11:00.151 Status: (zigate) 0000 <- 75b8 None None 0 0 0 0 0 0
2019-12-31 14:11:00.151 Status: (zigate) 0000 <- c7b7 40 0 167 171 176 215 168 183
2019-12-31 14:11:00.151 Status: (zigate) 0000 <- b64a 36 0 162 159 165 184 157 175
2019-12-31 14:11:00.152 Status: (zigate) 0000 <- 3f9d 32 0 195 163 167 197 162 163
2019-12-31 14:11:00.152 Status: (zigate) 0000 <- 8f3b None None 0 0 0 0 0 0
2019-12-31 14:11:00.152 Status: (zigate) 0000 <- a7bd None None 0 0 0 0 0 0
2019-12-31 14:11:00.152 Status: (zigate) 0000 <- ae82 None None 0 0 0 0 0 0
2019-12-31 14:11:00.152 Status: (zigate) 0000 <- 2bc9 None None 0 0 0 0 0 0
2019-12-31 14:11:00.152 Status: (zigate) 0000 <- da38 None None 0 0 0 0 0 0
tjabas wrote:ok, this occur after a reboot of the pi, or of the zigate plugin.
As stated those are not errors s , but a report of Energy
tjabas
Ok, thanks, and happy new year
