Months kWh usage to virtual counter
Posted: Monday 09 December 2019 20:08
by djdevil
Hi everyone, I need to create a virtual kWh counter used monthly and read the data from my energy meter. place the photos to better understand, I tried to use this script but it shows me the daily Khw and not the total monthly ones
local httpResponses = "monthTotal"
timer = { "every 15 minutes" },
httpResponses = { httpResponses .. "*" }
logging = {
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when script works as expected
marker = httpResponse
execute = function(dz, item)
-- ****************************** Your settings below this line ***************************************************
usageDevice = dz.devices(xxxx) -- Replace xxxx with ID of energyDevice you want to track
monthTotal = dz.devices(yyyy) -- Create as virtual managed counter (energy) and change yyyy to the ID of the new device
-- ****************************** No changes required below this line *********************************************
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local function triggerJSON(id, period, delay)
local delay = delay or 0
local URLString = dz.settings['Domoticz url'] .. "/json.htm?type=graph&sensor=counter&range=" ..
period .. "&idx=" .. id
dz.openURL({ url = URLString,
method = "GET",
callback = httpResponses .. "_" .. period}).afterSec(delay)
local function calculateMonthTotal(rt)
local monthTotal = 0
local currentMonth = dz.time.rawDate:sub(1,7)
for id, result in ipairs(rt) do
if rt[id].d:sub(1,7) == currentMonth then
logWrite(rt[id].d .. " ==>> " .. rt[id].v)
monthTotal = monthTotal + rt[id].v
return monthTotal * 1000
if not item.isHTTPResponse then
triggerJSON(usageDevice.id, "month")
elseif item.ok then -- statusCode == 2xx
monthTotal.update(0,calculateMonthTotal(item.json.result))
logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")" ,dz.LOG_ERROR)
logWrite(item.data)
hosting immagini gratis
Re: Months kWh usage to virtual counter
Posted: Monday 09 December 2019 21:22
by waaren
djdevil wrote: Monday 09 December 2019 20:08
rl=
https://it.imgbb.com/]hosting immagini gratis[/url]
You created a virtual device
counter. You should create a virtual device
managed counter
btw. Please also change
to
Posted: Monday 09 December 2019 22:12
by djdevil
thank you very much! works great! if you want instead I want to extrapolate the result of the last two months by adding them together?
Posted: Monday 09 December 2019 22:19
by waaren
djdevil wrote: Monday 09 December 2019 22:12
Please help me understand what you want to see in the target device.
If today is december 9th, do you then want the whole of november plus 1-9 december or do you want october 9th - december 9th. ?
Posted: Monday 09 December 2019 22:21
by djdevil
I want every virtual counter to be able to see the sum of the kWh used such as October and November
Posted: Monday 09 December 2019 23:33
by waaren
djdevil wrote: Monday 09 December 2019 22:21
Is this what you mean ?
local httpResponses = 'twoMonthTotal'
timer = { 'on 1/* at 04:17' }, -- if you get data from previous months you only have to do this once a month at a quiet time
httpResponses = { httpResponses .. '*' }
logging = {
marker = httpResponses
twoMonthTotals = dz.devices(yyyy) -- Create as virtual managed counter (energy) and change yyyy to the ID of the new device
local URLString = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=' ..
period .. '&idx=' .. id
method = 'GET',
callback = httpResponses .. '_' .. period}).afterSec(delay)
local function calculateTwoMonthTotal(rt)
local twoMonthTotal = 0
local dateFmt = '%Y-%m'
monthMinus1 = os.date(dateFmt,os.time{day=1, year=dz.time.year, month=dz.time.month - 1 })
monthMinus2 = os.date(dateFmt,os.time{day=1, year=dz.time.year, month=dz.time.month - 2 })
if result.d:sub(1,7) == monthMinus1 or result.d:sub(1,7) == monthMinus2 then
logWrite(result.d .. ' ==>> ' .. result.v)
twoMonthTotal = twoMonthTotal + result.v
return twoMonthTotal * 1000
triggerJSON(usageDevice.id, 'year')
twoMonthTotals.update(0,calculateTwoMonthTotal(item.json.result))
logWrite('Could not get (good) data from domoticz. Error (' .. (item.statusCode or 999) .. ')' ,dz.LOG_ERROR)
logWrite(item.data)
Re: Months kWh usage to virtual counter [Solved]
Posted: Tuesday 10 December 2019 0:07
by djdevil
Tested and worked thanks to waaren as you always are a magician! Resolved!
Posted: Sunday 12 January 2020 13:32
by RduPre
I changed the script to 1 month total, see below.
Did I do this correctly, because the device doesn't get update and there are no errors.
local httpResponses = 'oneMonthTotal'
{ timer = { "every 5 minutes" }}, -- script draait iedere 5 minuten
-- timer = { 'on 1/* at 04:17' }, -- if you get data from previous months you only have to do this once a month at a quiet time
logging = {
usageDevice = dz.devices(513) -- Replace xxxx with ID of energyDevice you want to track
oneMonthTotal = dz.devices(1862) -- Create as virtual managed counter (energy) and change yyyy to the ID of the new device
local URLString = dz.settings['192.168.0.186:8080'] .. '/json.htm?type=graph&sensor=counter&range=' ..
method = 'GET',
local function calculateoneMonthTotal(rt)
local oneMonthTotal = 0
if result.d:sub(1,7) == monthMinus1 then
oneMonthTotal = oneMonthTotal + result.v
return oneMonthTotal * 1000
oneMonthTotals.update(0,calculateoneMonthTotal(item.json.result))
logWrite(item.data)
Posted: Sunday 12 January 2020 13:44
by waaren
RduPre wrote: Sunday 12 January 2020 13:32
You should not change
dz.settings['Domoticz url'] to something like
dz.settings is a table and 'Domoticz url' is a key in that table. The value of that element is already your domoticz url.
So what you did here is asking dzVents to get the value of the element with key '192.168.0.186:8080'
Have not checked the rest of your modifications.
Posted: Sunday 12 January 2020 14:04
by RduPre
Ah Stupid of me....
I did change it back, but still without any update nor errors
Ow i think I see my error, wait...
Posted: Sunday 12 January 2020 14:21
by RduPre
Here is the script I use, which works for 1 month.
timer = { 'every 5 minutes' }, -- if you get data from previous months you only have to do this once a month at a quiet time
logging = {
method = 'GET',
oneMonthTotal.update(0,calculateoneMonthTotal(item.json.result))
logWrite(item.data)
Posted: Sunday 23 May 2021 0:37
by kniazio
I have such an error
Error: dzVents: local netWork not open for dzVents openURL call !
Posted: Sunday 23 May 2021 1:05
by waaren
kniazio wrote: Sunday 23 May 2021 0:37
__________________________________________________________________________________________________________________________
When not yet familiar with dzVents please start with reading
Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 (and / or ::1 when using IPv6 ) to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
___________________________________________________________________________________________________________________________
Posted: Sunday 23 May 2021 6:54
by kniazio
Now I have
Start internal script: FCounter: HTTPResponse: "oneMonthTotal_year"
2021-05-23 06:53:00.623 Status: dzVents: Debug: oneMonthTotal: Processing device-adapter for Dom: Custom sensor device adapter
2021-05-23 06:53:00.625 Status: dzVents: Debug: oneMonthTotal: Processing device-adapter for Zużycie_Dom: Counter device adapter
2021-05-23 06:53:00.625 Status: dzVents: Error (2.4.15): oneMonthTotal: An error occured when calling event handler FCounter
2021-05-23 06:53:00.625 Status: dzVents: Error (2.4.15): oneMonthTotal: .../domoticz/scripts/dzVents/generated_scripts/FCounter.lua:39: bad argument #1 to 'ipairs' (table expected, got nil)
2021-05-23 06:53:00.625 Status: dzVents: Info: oneMonthTotal: ------ Finished FCounter
Perhaps because the value that the script calculates for me is with a "minus" sign
Posted: Sunday 23 May 2021 14:53
by waaren
kniazio wrote: Sunday 23 May 2021 6:54
Sorry but your version is too old to give support. If you want help then please upgrade to a recent version and include the full script and log.
Posted: Sunday 23 May 2021 15:07
by kniazio
waaren wrote: Sunday 23 May 2021 14:53
What version is it about? Version of (what)?
2021-05-23 15:32:00.482 Error: dzVents: Error: (3.0.2) oneMonthTotal: An error occurred when calling event handler FCounter
2021-05-23 15:32:00.482 Error: dzVents: Error: (3.0.2) oneMonthTotal: .../domoticz/scripts/dzVents/generated_scripts/FCounter.lua:39: bad argument #1 to 'ipairs' (table expected, got nil)
021-05-23 15:33:00.375 Status: dzVents: Info: oneMonthTotal: ------ Start internal script: FCounter:, trigger: "every minute"
2021-05-23 15:33:00.386 Status: dzVents: Debug: oneMonthTotal: Processing device-adapter for Dom: Custom sensor device adapter
2021-05-23 15:33:00.387 Status: dzVents: Debug: oneMonthTotal: Processing device-adapter for Zużycie_Dom: Counter device adapter
2021-05-23 15:33:00.387 Status: dzVents: Debug: oneMonthTotal: OpenURL: url = http://127.0.0.1:8082/json.htm?type=graph&sensor=counter&range=year&idx=63
2021-05-23 15:33:00.387 Status: dzVents: Debug: oneMonthTotal: OpenURL: method = GET
2021-05-23 15:33:00.387 Status: dzVents: Debug: oneMonthTotal: OpenURL: post data = nil
2021-05-23 15:33:00.387 Status: dzVents: Debug: oneMonthTotal: OpenURL: headers = nil
2021-05-23 15:33:00.387 Status: dzVents: Debug: oneMonthTotal: OpenURL: callback = oneMonthTotal_year
2021-05-23 15:33:00.387 Status: dzVents: Info: oneMonthTotal: ------ Finished FCounter
2021-05-23 15:33:00.388 Status: dzVents: Info: ------ Start internal script: FMeter:, trigger: "every minute"
2021-05-23 15:33:00.388 Status: dzVents: Debug: OpenURL: url = http://192.168.1.199/solar_api/v1/GetPowerFlowRealtimeData.fcgi
2021-05-23 15:33:00.388 Status: dzVents: Debug: OpenURL: method = GET
2021-05-23 15:33:00.388 Status: dzVents: Debug: OpenURL: post data = nil
2021-05-23 15:33:00.388 Status: dzVents: Debug: OpenURL: headers = nil
2021-05-23 15:33:00.388 Status: dzVents: Debug: OpenURL: callback = Fronius
2021-05-23 15:33:00.388 Status: dzVents: Info: ------ Finished FMeter
2021-05-23 15:33:00.389 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-05-23 15:33:00.456 Status: dzVents: Info: Handling httpResponse-events for: "oneMonthTotal_year"
2021-05-23 15:33:00.456 Status: dzVents: Info: oneMonthTotal: ------ Start internal script: FCounter: HTTPResponse: "oneMonthTotal_year"
2021-05-23 15:33:00.469 Status: dzVents: Debug: oneMonthTotal: Processing device-adapter for Dom: Custom sensor device adapter
2021-05-23 15:33:00.470 Status: dzVents: Debug: oneMonthTotal: Processing device-adapter for Zużycie_Dom: Counter device adapter
2021-05-23 15:33:00.470 Status: dzVents: Info: oneMonthTotal: ------ Finished FCounter
2021-05-23 15:33:00.470 Error: dzVents: Error: (3.0.2) oneMonthTotal: An error occurred when calling event handler FCounter
2021-05-23 15:33:00.470 Error: dzVents: Error: (3.0.2) oneMonthTotal: .../domoticz/scripts/dzVents/generated_scripts/FCounter.lua:39: bad argument #1 to 'ipairs' (table expected, got nil)
I ran the script on a brand new system on another Raspberry Pi4
Posted: Sunday 23 May 2021 17:10
by kniazio
I chose another meter for counting monthly energy which shows positive values and the script worked immediately. Probably the problem lies in the negative results of the measurement
Posted: Tuesday 25 May 2021 15:30
by kniazio
Can it be solved somehow?
