Hi!
i have a zigate usb version on my raspberry pi, i have read that there is a way to make a backup of the zigate in a windows computer,
but where is the paired zigbee devices stored? is it in domoticz or the zigbee stick?
the backup in windows seemed a bit tricky, it seemed that i need to do it in the windows dos promt, or is there a easier way?
Zigate backup?
Re: Zigate backup?
In Domoticz you have all related widgets which are stored.
In the Zigate plugin (under Data/DeviceList-xx.txt ) you have all devices related informations
On the Zigate firmware PDM you have all Zigate paired devices information
What I would recommend to do is
- make a propre backup of domoticz and plugin environment
In case you scrach the Zigate hardware, you'll have simply to repair the devices, but you won't loose anythink else. Automatically the plugin will reconnect the devices
tjabas
Re: Zigate backup?
i usually do backups of the sd card itself, so i always have a fresh backup, so you mean that everything is stored in the sd card, so if the zigate device breaks down and i have to get a new one everything will work emediately?
Re: Zigate backup?
What I said, is that you'll have to re-pair each devices, but all your configuration, history will remain.tjabas wrote: Friday 06 December 2019 22:20 i usually do backups of the sd card itself, so i always have a fresh backup, so you mean that everything is stored in the sd card, so if the zigate device breaks down and i have to get a new one everything will work emediately?
tjabas
Re: Zigate backup?
ok, now i understand, thank you very much
tjabas
Re: Zigate backup?
i have installed the NXP software on my windows10 computer and i have tried to do a backup of the zigate, but with no success, the plan was to back it up since i have another zigate and have that one as a backup in case the main zigate goes corrupted.
i have followed the guide on the zigate site, i use powershell and i go to the directory where nxp is installed, but i cant the software to make a backup.
or is there any other software that i can use to make a backup?
tjabas
Re: Zigate backup?
I thought that i might do an update,
today i managed to make an backup of the zigate, the problem before was that i had the zigate site translated to swedish, that changed some of the copy/paste line, so that was why it didnt work.
Re: Zigate backup?
THat is good news. If you want to make a English version for the benefits of others, please do so and that could be hosted on https://github.com/pipiche38/Domoticz-Z ... ter/en-eng, so feel freetjabas wrote: Sunday 15 December 2019 13:53 I thought that i might do an update,
