I was wondering if a DS18B20 (3 wire) sensor can be used with a Qubino dimmer ZMNHDD1 ?
Dimmer ZMNHDD1 has a 3 pin input for a sensor (TS), and i suppose it might be possible that the Qubino sensor is just a DS18B20 type...
Anyone?
Temperature sensor DS18B20 usable for Qubino?
Ron
- Domoticz version: 2.2284
Re: Temperature sensor DS18B20 usable for Qubino?
Thanks, just as i expected.
It is more easy to use the original Qubino sensor, but these are to large for what i am using it for.
I will mount the sensor in the lower part of the wall socket covering plate, to monitor the room temperature.
Soldering and isolating of the wires is not a problem for me, but good to know the connections are in contact with the mains supply!
