How to connect RFXCOM to a Dooma / Dooya switch-receiver ?
caloux
Post by caloux »
I have several switches and remotes "Dooma" (french brand name) for my rolling shutters.
Dooma products are also available on Aliexpress under the Dooya brand.
I use Dooma / Dooya DC227 wall switches which are receivers compatibles too with Dooya remote DC306 / DC307 / DC229 .... The Dooma / Dooya range works well with my Somfy shutters. A video presents these Dooma / Dooya models:
https://www.youtube.com/watch?v=UDbF9zFVfJk&t=2s
I am beginner with Domoticz /RFXCOM on Raspberry 3. I can add Dio, Chacon... devices in Domoticz but Dooya / Dooma devices are not recognized in auto sniffer mode in Domoticz. When I use the manual mode with the Blind T6 - DC106 protocol (compatible with Dooya according to several topics...), my Dooya receiver does not recognize the RFXCOM signals.
A website sell a box that seems to be a Rapsberry with an RFXCOM so it must be possible ...:
see : https://automatismepassion.com/home/170 ... phone.html
Then, how to integrate in Domoticz a Dooya switch like the DC227 Dooya / Dooma (not the Dooya models with integrated receivers in tubular motor, see the You Tube video to see my model) ? https://www.youtube.com/watch?v=UDbF9zFVfJk&t=2s
For the moment I drive my shutters with a Raspberry that drives a relay card plugged to an original Dooya remote but now I would like to expand the control with a RFXCOM 433E on Raspberry.
Thank you for your help
b_weijenberg
Re: How to connect RFXCOM to a Dooma / Dooya switch-receiver ?
Post by b_weijenberg »
Use Pro1 firmware in the RFXtrx433E and check with RFXmngr and BlindsTx enabled if the Dooya remote is received.
RFX-433, RFX-433EMC, RFX-868
caloux
Post by caloux »
Yes ! Perfect with the Firmware Pro1, download and upload firmware Pro1 in Domoticz and now my Dooma/Dooya remotes are received in auto mode(protocol Blinds DC106 detected).
Thanks you b_weijenberg !
Laserdokter
Post by Laserdokter »
All great, however the people owing an XL version still have a problem. (cannot load any other firmware)
When will this Domoticz "bug" be solved? I updated from stable to beta(4.11590) to see if it is solved, but unfortunately T1-T4 is still not selectable.
Automatic recognition of remote also does not work RAEX YR1326 compatible remote and TQA25 motor. I could however in RFXmanager pair and controll the blind.
Is there a workaround for RFXtrx433XL users?
b_weijenberg
Use RFXflash on a Windows system to update the RFXtrx433XL firmware.
