Temp and Humidity OpenGarage  [Solved]
xHuubx
Post by xHuubx »
I have build a a garage door controller with the use of OpenGarage. Now I also added a Temperature and Humidity sensor. Every 10 minutes I would like to read out the values and store them in my Domticz, unfortunately I am not that experienced in using dzVents scripts in doing this..
OpenGarage has a API (https://github.com/OpenGarage/OpenGarag ... I1.1.0.pdf) with this you can go to the url and the data is shown, this looks like:
Schermafbeelding 2019-11-26 om 13.38.16.png (50.23 KiB) Viewed 1898 times
I tried:
		timer = {
			'every 10 minutes' -- just an example to trigger the request
		httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://192.168.178.16/jc',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.statusCode == 200) then
				if (item.isJSON) then
					local someValue = item.json.someValue  -- just an example
					-- update some device in Domoticz
					domoticz.devices('myTextDevice').updateText(someValue)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
I created a dummy myTextDevice, but the reponse is Nill..
2019-11-26 13:51:00	nil
Can someone help me ?
Re: Temp and Humidity OpenGarage
xHuubx wrote: Tuesday 26 November 2019 13:52 I have build a a garage door controller with the use of OpenGarage. Now I also added a Temperature and Humidity sensor. Every 10 minutes I would like to read out the values and store them in my Domticz, unfortunately I am not that experienced in using dzVents scripts in doing this..
Happy to help but which information do you want in the virtual text device ?
Do you want the temperature and humidity in a virtual temp/hum sensor or separate or everything in the text device ?
So many questions and so few answers.... :D
xHuubx
Post by xHuubx »
Only the Temp and Humidity in a virtual temp/hum sensor would be great!
xHuubx wrote: Tuesday 26 November 2019 15:41 Only the Temp and Humidity in a virtual temp/hum sensor would be great!
Can you try this ?
local scriptVar = 'garageData'
return
    on =
        timer =
            'every 10 minutes'
        httpResponses =
            scriptVar
        logging =
            level = domoticz.LOG_DEBUG, -- change to LOG_ERROR when everything works as expected
            marker = scriptVar,
    execute = function(dz, item)
        -- Enter your settings below this line
        local garageURL = 'http://192.168.178.16/jc'
        local temperatureHumidityDevice = dz.devices('garage') -- Change to name of your virtual temp / humidity device
        -- No changes required below this line
        local function humidityStatus(temperature, humidity) -- as used indz source
            if humidity <= 30 then return dz.HUM_DRY
            elseif humidity >= 70 then return dz.HUM_WET
            elseif  humidity >= 35 and humidity <= 65 and temperature >= 22 and temperature <= 26 then return dz.HUM_COMFORTABLE end
            return dz.HUM_NORMAL
        if item.isTimer then
            dz.openURL(
                    url = garageURL,
                    callback = scriptVar,
        elseif item.isHTTPResponse and item.ok then
            if not(item.isJSON) then item.json = dz.utils.fromJSON(item.data) end
            temperatureHumidityDevice.updateTempHum( rt.temp, rt.humid, humidityStatus( rt.temp, rt.humid ) )
            dz.log('There was a problem handling the request; response is ' .. item.data, dz.LOG_ERROR)
xHuubx
Post by xHuubx »
I tried your suggestion, now I get following error:
Schermafbeelding 2019-11-26 om 19.23.45.png (111.56 KiB) Viewed 1865 times
Nil value.. I have set the interval on 1 minute to test it..
xHuubx wrote: Tuesday 26 November 2019 19:25 I tried your suggestion, now I get following error:
I made a small change. Please try again with this and if still not working share your json return from the browser and loglines as text in a code window.
return
    on =
        timer =
            'every 10 minutes'
        httpResponses =
            scriptVar
        logging =
            marker = scriptVar,
            dz.openURL(
                    url = garageURL,
            rt = item.json
xHuubx
Re: Temp and Humidity OpenGarage  [Solved]
Post by xHuubx »
It worked!! this is awesome!
The log:
Schermafbeelding 2019-11-26 om 20.45.53.png (131.01 KiB) Viewed 1853 times
And the sensor data in Domoticz:
Schermafbeelding 2019-11-26 om 20.44.37.png (72.28 KiB) Viewed 1853 times
Great job waaren, thx again!
