Heater control with rotary encoder
Zachtstaart2002
Post by Zachtstaart2002 »
I was looking to make a stable control for de temperature in my house. The goal was to set a temperature setting by rotary controler and send that setting to domoticz. If the temperature setting is changed by Domoticz user the new temperature setting must be send to NodeMCU.
I want to 3D print a housing to accomadate a LCD screen 2X16 line one to display temperature set by rotary encoder ans temperature and humidity.
To do that i used two NodeMCU units.
One to run with ESPEASY who will send temperature and humidity to Domotics using a virtual device, and control a relais to turn of or on the heater (central heating system).
The second NodeMCU is running Arduino code i wrote. It controls the rotary encoder to set de temerature inside the house. The temperature set by rotary encoder gets send to a virtual setpoint device in Domotics. If a Domoticz user changes the temperature the seconde NodeMCU receives the change and sends the new temperature to a lcd screen.
To send the new temperature setting from Domoticz i wrote a LUA script that runs on device change.
For me this works fine. It does what i was looking for. Since i could not find much information on how to make a wifi themostat that is compatible with Domoticz.
I hope other hobbyist can use this information. Enjoy
Arduino sketch
Program for Thermostatic heater control on NodeMCU and Domoticz
The goal is to set a temperature setting by rotary controler and send that setting to domoticz
If the temperature setting is changed by Domoticz user a LUA script send the temperature setting to NodeMCU
Line two is used to display temperature and humidity messured by DHT22
Written by Willem Pelkman 24-11-2019
// Used library
#include <RotaryEncoder.h>
#include <ESP8266WiFi.h>
#include "DHT.h"
#include <ESP8266HTTPClient.h>
#include <LiquidCrystal_I2C.h>
// WIFI acces point
#ifndef STASSID
#define STASSID "<YOURE SSID>"
#define STAPSK  "<YOURE SSID PASWOORD>"
#endif
// Uncomment one of the lines below for whatever DHT sensor type you're using!
//#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
// DHT Sensor connected on pin
uint8_t DHTPin = D5;
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
// float to save temperature and humidity
float T;
float H;
// Get SSID value in variable
const char* ssid = STASSID;
const char* password = STAPSK;
// Define rotary encoder pins Note Optional Pins can be -1
const RotaryEncoder::OptPin GND = -1; // Use GND pin
const RotaryEncoder::OptPin VCC = -1; // Use V+ pin
const RotaryEncoder::OptPin SW  = -1; // Switch
const RotaryEncoder::Pin    DT  = D6; // Data
const RotaryEncoder::Pin    CLK = D7; // Clock
// define constants
int ledpin = D4; // pin internal led
int repeat = 15; // startup value temperature setting rotary encoder
int temperatuur = 15; // startup value temperature setting webrequest
int prevrepeat = 15; // startup value previus repeat value
int prevtemperatuur = 15; // startup value previus temperatuur value
int timeSinceLastRead = 0; // time the DHT is last read
int startup = 0; // detection first loop to get first value DHT senser before timer starts
// LCD display
int lcdColumns = 16;
int lcdRows = 2;
// char to lose digits after .
char strt[7];
char strh[7];
byte ledState = 0; // ledstate for ledblink
unsigned long ledinterval = 500; // delay for ledblink
unsigned long previousMillis = 0; // previus milles when ledstate changed
// Tell library which pin does what. Note Optional Pins can be -1
RotaryEncoder encoder(GND, VCC, SW, DT, CLK);
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
// set LCD address, number of columns and rows
// if you don't know your display address, run an I2C scanner sketch
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows);
// Function to scroll text
// The function acepts the following arguments:
// row: row number where the text will be displayed
// message: message to scroll
// delayTime: delay between each character shifting
// lcdColumns: number of columns of your LCD
void scrollText(int row, String message, int delayTime, int lcdColumns) {
  for (int i = 0; i < lcdColumns; i++) {
    message = " " + message;
  message = message + " ";
  for (int pos = 0; pos < message.length(); pos++) {
    lcd.setCursor(0, row);
    lcd.print(message.substring(pos, pos + lcdColumns));
    delay(delayTime);
void setup() {
  Serial.begin(115200);
  encoder.Begin(1); // Start, with a re-bias of 1
  pinMode(DHTPin, INPUT); // DHT pin mode
  dht.begin(); // initialize DHT sensor
  // initialize LCD
  lcd.init();
  // turn on LCD backlight
  lcd.backlight();
  // prepare LED
  pinMode(ledpin, OUTPUT);
  digitalWrite(ledpin, 0);
  // Connect to WiFi network
  Serial.println();
  Serial.println();
  Serial.print(F("Connecting to "));
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  IPAddress ip(<STATIC IP ADRES FOR NodeMCU);
  IPAddress gateway(192, 168, 1, 1);
  IPAddress subnet(255, 255, 255, 0);
  WiFi.config(ip, gateway, subnet);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(F("."));
  Serial.println();
  Serial.println(F("WiFi connected"));
  // Start the server
  server.begin();
  Serial.println(F("Server started"));
  // Print the IP address
  Serial.println(WiFi.localIP());
void loop() {
  rotatie();  //detect rotary controler change state
  vergelijking(); // check if Domoticz or Rotary encoder changed and make value te same
  timeSinceLastRead += 1; // Increase counter of last time read DHT sensor
  templezer();  // Function to read DHT sensor
  led(); // Led blink function
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  Serial.println(F("new client"));
  client.setTimeout(5000); // default is 1000
  // Read the first line of the request
  String req = client.readStringUntil('\r');
  Serial.println(F("request: "));
  Serial.println(req);
  // Match the request coming from Domoticz or HTML page
  if (req.indexOf(F("/tempset/10")) != -1) {
    temperatuur = 10;
  } else if (req.indexOf(F("/tempset/11")) != -1) {
    temperatuur = 11;
  } else if (req.indexOf(F("/tempset/12")) != -1) {
    temperatuur = 12;
  } else if (req.indexOf(F("/tempset/13")) != -1) {
    temperatuur = 13;
  } else if (req.indexOf(F("/tempset/14")) != -1) {
    temperatuur = 14;
  } else if (req.indexOf(F("/tempset/15")) != -1) {
    temperatuur = 15;
  } else if (req.indexOf(F("/tempset/16")) != -1) {
    temperatuur = 16;
  } else if (req.indexOf(F("/tempset/17")) != -1) {
    temperatuur = 17;
  } else if (req.indexOf(F("/tempset/18")) != -1) {
    temperatuur = 18;
  } else if (req.indexOf(F("/tempset/19")) != -1) {
    temperatuur = 19;
  } else if (req.indexOf(F("/tempset/20")) != -1) {
    temperatuur = 20;
  } else if (req.indexOf(F("/tempset/21")) != -1) {
    temperatuur = 21;
  } else if (req.indexOf(F("/tempset/22")) != -1) {
    temperatuur = 22;
  } else if (req.indexOf(F("/tempset/23")) != -1) {
    temperatuur = 23;
  } else if (req.indexOf(F("/tempset/24")) != -1) {
    temperatuur = 24;
  } else if (req.indexOf(F("/tempset/25")) != -1) {
    temperatuur = 25;
  } else if (req.indexOf(F("/tempset/26")) != -1) {
    temperatuur = 26;
  } else if (req.indexOf(F("/tempset/27")) != -1) {
    temperatuur = 27;
  } else if (req.indexOf(F("/tempset/28")) != -1) {
    temperatuur = 28;
  } else if (req.indexOf(F("/tempset/29")) != -1) {
    temperatuur = 29;
  } else if (req.indexOf(F("/tempset/30")) != -1) {
    temperatuur = 30;
  } else {
    Serial.println(F("invalid request"));
  // read/ignore the rest of the request
  // do not client.flush(): it is for output only, see below
  while (client.available()) {
    // byte by byte is not very efficient but works
    client.read();
  // Send the response to the HTML page wich can reached on HTTP://<IP NodeMCU>
  client.print(F("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nTEMPERATUUR pagina"));
  client.print(F("<br><br>Click <a href='http://"));
  client.print(WiFi.localIP());
  client.print(F("/tempset/10'>here</a> to set temp on 10."));
  client.print(F("<br>Click <a href='http://"));
  client.print(F("/tempset/11'>here</a> to set temp on 11."));
  client.print(F("/tempset/12'>here</a> to set temp on 12."));
  client.print(F("/tempset/13'>here</a> to set temp on 13."));
  client.print(F("/tempset/14'>here</a> to set temp on 14."));
  client.print(F("/tempset/15'>here</a> to set temp on 15."));
  client.print(F("/tempset/16'>here</a> to set temp on 16."));
  client.print(F("/tempset/17'>here</a> to set temp on 17."));
  client.print(F("/tempset/18'>here</a> to set temp on 18."));
  client.print(F("/tempset/19'>here</a> to set temp on 19."));
  client.print(F("/tempset/20'>here</a> to set temp on 20."));
  client.print(F("/tempset/21'>here</a> to set temp on 21."));
  client.print(F("/tempset/22'>here</a> to set temp on 22."));
  client.print(F("/tempset/23'>here</a> to set temp on 23."));
  client.print(F("/tempset/24'>here</a> to set temp on 24."));
  client.print(F("/tempset/25'>here</a> to set temp on 25."));
  client.print(F("/tempset/26'>here</a> to set temp on 26."));
  client.print(F("/tempset/27'>here</a> to set temp on 27."));
  client.print(F("/tempset/28'>here</a> to set temp on 28."));
  client.print(F("/tempset/29'>here</a> to set temp on 29."));
  client.print(F("/tempset/30'>here</a> to set temp on 30.</html><br><br>"));
  // print current value of variable to serial for debuging
  Serial.print(F("repeat is nu "));
  Serial.println((repeat));
  Serial.print(F("temperatuur is nu "));
  Serial.println((temperatuur));
  // The client will actually be *flushed* then disconnected
  // when the function returns and 'client' object is destroyed (out-of-scope)
  // flush = ensure written data are received by the other side
  Serial.println(F("Disconnecting from client"));
void rotatie() {
  if (encoder.Switch()) { // Hard override! Not used
  else {
    int value = encoder.Get(); // Returns positive for clockwise turn
    repeat += value;   // We want to INCREASE the value by turning right
    if (repeat <= 10) { // minimum temperature setting
      repeat = 10;
    else if (repeat >= 30) { // maximum temperature setting
      repeat = 30;
    if (value != 0) {   // Did it change?
      Serial.print("Ingestelde Temperatuur ");    // Print tekst
      Serial.print('=');
      Serial.print(" ");
      Serial.print(repeat); // Print value of repeat = temperature setting
      Serial.println(" Graden Celcius");
void vergelijking() {
	// If repeat is changed by turning rotary encoder make temperature the same value
	// If temperature is changed by Domoticz webrequest make repeat same value
	// advertise new value to Domoticz by PrintInfo
  if (prevrepeat != repeat) {
    prevrepeat = repeat;
    temperatuur = repeat;
    prevtemperatuur = repeat;
    printInfo();
  } else if (prevtemperatuur != temperatuur) {
    prevtemperatuur = temperatuur;
    repeat = temperatuur;
    prevrepeat = temperatuur;
    printInfo();
void templezer() {
  if (startup == 0)  {
    T = dht.readTemperature(); // Gets the values of the temperature
    H = dht.readHumidity(); // Gets the values of the humidity
    dtostrf(T, 2, 0, strt);
    dtostrf(H, 2, 0, strh);
    Serial.print("Gemeten Temperatuur ");    // Print tekst
    Serial.print('=');
    Serial.print(" ");
    Serial.print(T); // Print new result
    Serial.print("Gemeten Vochtigheid ");    // Print tekst
    Serial.print('=');
    Serial.print(" ");
    Serial.print(H); // Print new result
    Serial.println(" %");
    startup = 1;
  } else if (timeSinceLastRead > 6000000) {
    Serial.print('=');
    Serial.print(" ");
    Serial.print(strt); // Print new result
    Serial.print('=');
    Serial.print(" ");
    Serial.print(strh); // Print new result
    printInfo();
void printInfo()
	// Send changes to Domoticz by json command set idx value as needed
  HTTPClient http;  //Object of class HTTPClient
  //  http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=switchlight&idx=395&switchcmd=On");
  //  int httpCode = http.GET();
  if (repeat == 10) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=10");
    int httpCode1 = http.GET();
  if (repeat == 11) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=11");
  if (repeat == 12) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=12");
  if (repeat == 13) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=13");
  if (repeat == 14) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=14");
  if (repeat == 15) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=15");
  if (repeat == 16) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=16");
  if (repeat == 17) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=17");
  if (repeat == 18) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=18");
  if (repeat == 19) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=19");
  if (repeat == 20) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=20");
  if (repeat == 21) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=21");
  if (repeat == 22) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=22");
  if (repeat == 23) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=23");
  if (repeat == 24) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=24");
  if (repeat == 25) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=25");
  if (repeat == 26) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=26");
  if (repeat == 27) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=27");
  if (repeat == 28) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=28");
  if (repeat == 29) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=29");
  if (repeat == 30) {
    http.begin("http://<YOURE DOMOTICZ IP>:8080/json.htm?type=command&param=setsetpoint&idx=630&setpoint=30");
void led()  {
	// Led blink function whitout delay
  unsigned long currentMillis = millis();
  if (currentMillis - previousMillis >= ledinterval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
    // if the LED is off turn it on and vice-versa:
    if (ledState == 0)
      ledState = 1;
      ledState = 0;
    // set the LED with the ledState of the variable:
    digitalWrite(ledpin, ledState);
void scroltext() {
	// Tekst to print on LCD display
  String messageStatic = "Temp ";
  int stringOne = repeat;
  String messageStatic2 = " setting";
  String stringTwo = messageStatic + stringOne + messageStatic2;
  // set cursor to first column, first row
  lcd.setCursor(0, 0);
  lcd.print(stringTwo);
  String str0 = "Gemeten temperatuur = ";
  float str1 = T;
  String str2 = " Graden Celcuis";
  String str3 = " Gemeten vochtigheid = ";
  float str4 = H;
  String str5 = " %";
  String messageToScroll = str0 + str1 + str2 + str3 + str4 + str5;
  scrollText(1, messageToScroll, 250, lcdColumns);
The LUA script that runs on Domoticz
for deviceName,deviceValue in pairs(otherdevices) do
    if (deviceName=='NodeMCU') then
    print('NodeMCU found')
    local tempset = tostring(deviceValue)
        if (uservariables["prevtempset"] ~= tempset) then
            print("vorigeTemp = "..(uservariables["prevtempset"]))
            print("tempset = "..(tempset))
            if (uservariables["prevtempset"] ~= tempset) then commandArray['Variable:prevtempset'] = tostring(tempset) end
            print('Temp verzenden')
            if tempset == "10.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/10"')
            elseif tempset == "11.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/11"')
            elseif tempset == "12.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/12"')
            elseif tempset == "13.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/13"')
            elseif tempset == "14.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/14"')
            elseif tempset == "15.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/15"')
            elseif tempset == "16.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/16"')
            elseif tempset == "17.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/17"')
            elseif tempset == "18.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/18"')
            elseif tempset == "19.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/19"')
            elseif tempset == "20.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/20"')
            elseif tempset == "21.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/21"')
            elseif tempset == "22.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/22"')
            elseif tempset == "23.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/23"')
            elseif tempset == "24.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/24"')
            elseif tempset == "25.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/25"')
            elseif tempset == "26.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/26"')
            elseif tempset == "27.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/27"')
            elseif tempset == "28.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/28"')
            elseif tempset == "29.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/29"')
            elseif tempset == "30.00" then
            os.execute ('curl -s "http://<YOURE NodeMCU IP>/tempset/30"')
