If I understand correctly, domoticz uses its own version of Lua for scripting. I see that my version ( I compiled it from sources on a Ubuntu mini PC) has a Lua subdirectory where a version of Lua is compiled. Is it possible to use a database such as Sqlite3 in this context? I tried a script requiring luasql.sqlite3 and in the log I see that domoticz is looking in quite a few subdirectories, including /usr/local/lib/lua/5.3 for instance, but of course it does not find the library I required. I tried to install Lua5.3 from sources in /usr/local and then luasql again from sources in the same directory, but that was not successful.
Can databases such as sqlite3 be used in dzvents? [Solved]
- waaren
Re: Can databases such as sqlite3 be used in dzvents? [Solved]
Did some testing with this and got it running under dzVents (domoticz specific API to Lua)mm148881 wrote: Sunday 17 November 2019 15:05 Hi,
--[[ dbTest.lua ( Play with database using Lua
this dzVents script is a test to work with the domoticz.db via an alternate route
sudo apt install lua5.3
sudo apt install liblua5.3-dev
sudo apt install libsqlite3-dev
sudo wget https://luarocks.org/releases/luarocks-3.2.0.tar.gz
sudo tar zxpf luarocks-3.2.0.tar.gz
cd luarocks-3.2.0
./configure
sudo make bootstrap
luarocks install luasocket
luarocks install luasec
luarocks install luasql-sqlite3
sudo cp <domoticz dir>/domoticz.db /tmp/dbTest.sqlite3
local sqlite3ScriptTrigger = 'sqlite3Trigger'
local testDatabase = '/tmp/dbTest.sqlite3'
return
on =
-- timer = {'every 10 minutes'}, -- when frequent broadcasts are required
devices = { sqlite3ScriptTrigger },
logging = { level = domoticz.LOG_DEBUG }, -- switch to LOG_DEBUG when not eoowrking as expected
execute = function(dz)
local driver = require "luasql.sqlite3"
local sqlite3 = assert (driver.sqlite3())
local db = assert (sqlite3:connect(testDatabase))
local result = assert (db:execute[[ create TABLE IF NOT EXISTS people (name varchar(5), email varchar(50) ) ]])
local insertTable = {
{ name="Jose das Couves", email="[email protected]", },
{ name="Manoel Joaquim", email="[email protected]", },
{ name="Maria das Dores", email="[email protected]", },
{ name="Renz Warden", email="rtca@gmailcom", },
for _, row in pairs(insertTable) do
result = assert (db:execute( string.format([[ INSERT INTO people VALUES ('%s', '%s')]], row.name, row.email)))
-- local cursor = assert (db:execute"SELECT name, email from people")
local cursor = assert (db:execute"SELECT Name, ID, svalue, nvalue, color from devicestatus")
local row = cursor:fetch ({}, "a")
dz.utils.dumpTable(row)
while row do
dz.log(string.format("Name: %s, id: %d, Color: %s" , row.Name, row.ID, row.Color ),dz.LOG_FORCE)
-- dz.log({ row } ,dz.LOG_FORCE)
row = cursor:fetch (row, "a")
-- close everything
cursor:close() -- already closed because all the result set was consumed
db:close()
sqlite3:close()
- mm148881
- Domoticz version: 4.11499
I installad the way you said and it works, although luasocket and luasec don't seem to be needed. Also, is there a good reason not to use a sqlite3 database to save data obtained from devices? Since I know little of dzvents I am wondering if writing to databases (or even external files) could impact on the execution of the scripts.
As a side note, I found some weired behavior if I try to install packages from the luarock installation directory: the packages are installe in the ./lua_modules subdirectory...
- waaren
I don't understand your question. Please elaborate.mm148881 wrote: Monday 18 November 2019 11:21 Is there a good reason not to use a sqlite3 database to save data obtained from devices?
Yes depending on the hardware / OS used there can be a huge difference in reading / writing to external storage compared to reading / writing memory. This is not specific to dzVents or domoticz; it is general in computing.Since I know little of dzVents I am wondering if writing to databases (or even external files) could impact on the execution of the scripts.
- mm148881
One could use sqlite3/mysql/file to save persistent data, just to have more flexibility with respect to saving data in domoticz.data. It was just a general question and your next statement answers it. I understand that especially on some SBC that could have an impact. I am running domoticz on a 6th gen intel processor and have a sata ssd as storage. Thus, reading/writing small data set shouldn't be a problem in my case.
OkYes depending on the hardware / OS used there can be a huge difference in reading / writing to external storage compared to reading / writing memory. This is not specific to dzVents or domoticz; it is general in computing.Since I know little of dzVents I am wondering if writing to databases (or even external files) could impact on the execution of the scripts.
- waaren
dzVents does use dedicated os.files for storing persistent data. I was not involved at the time this design decision has been taken but I think it was with the fact in mind that, in general, the amount of data is very limited and to be as independent as possible of external modules.mm148881 wrote: Monday 18 November 2019 12:29 One could use sqlite3/mysql/file to save persistent data,
But interesting enough to discuss with the original creator(s) of dzVents.
