How to get SAJ Solar xml values?
Posted: Thursday 14 November 2019 18:05
by BarryT
Hi all!
I try to use this script to get data out of my (ethernet module of the) SAJ Solar inverter..
Forget to add the version:
Version: 4.11487
Build Hash: ac3d2290d
Compile Date: 2019-11-14 16:41:43
dzVents Version: 2.5.0
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
lineNo = 0
now    = 0
temp   = 0
today  = 0
total  = 0
v1     = 0
v2     = 0
i1     = 0
i2     = 0
ip     = '192.168.1.18'
i = 1
-- Only run during day
-- if ( uservariables["Het is Donker"] == 0 ) then
    function UpdateDevice(device, data)
        idx = otherdevices_idx[device]
        if (idx == nil) then
            print('** Unknown device '..device)
            commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
            i = i+1
	--Get the XML data from the inverter
    local url = 'curl http://'..ip..'/real_time_data.xml'
    local data = assert(io.popen(url))
    for line in data:lines() do
        if (lineNo == 0 and string.find(line,'Normal') ~= nil) then
            lineNo = 1
        elseif (lineNo > 0) then
            if     (lineNo == 4) then now   = string.match(line, "%d+")
            elseif (lineNo == 5) then temp  = string.match(line, "%d+%.%d+")
            elseif (lineNo == 6) then today = string.match(line, "%d+%.%d+")
            elseif (lineNo == 8) then total = string.match(line, "%d+%.%d+")
            lineNo = lineNo + 1
    data:close()
    if (lineNo >= 14) then
        -- Update the Domoticz GUI
        ep = v1*i1
        wp = v2*i2
        UpdateDevice('PV SAJ', now..";".. total*1000)
        UpdateDevice('Temperatuur SAJ', temp)
The script seems to doesnt work at all, no errors but also no executing in the log.
I use the EventSystem, and also made a script by hand with script_time_saj.lua, but both seems to do nothing.
Someone know what is wrong?
Ps, i can only test the dummy updating (when its hopefully going to executed once) when it is daylight because the SAJ goes offline when it is dark, and so the ethernet module goes to..
thanks!
Re: How to get SAJ Solar xml values?
Posted: Thursday 14 November 2019 19:29
by waaren
BarryT wrote: Thursday 14 November 2019 18:05 I try to use this script to get data out of my (ethernet module of the) SAJ Solar inverter..
assuming that the eventSystem is active and the script is saved as enabled with a time trigger, a start to debug the script would be to change
to
print(data) -- should show something like 'file (0x42e0f8)'
print(line) -- should print all lines of the return of the url
could help
Posted: Thursday 14 November 2019 19:37
by BarryT
waaren wrote: Thursday 14 November 2019 19:29
to
could help
Thanks waaren, but the script isnt function at all. :(
Eventsystem is active and ofcourse a time script used.
there is no logging who said lua..Status or triggered like all other scripts.
Example of other scripts wich working correctly:
2019-11-14 18:47:28.728 Status: RFLink: 2 level: 7
2019-11-14 18:48:29.246 Status: LUA: Lampen in de badkamer AAN
2019-11-14 18:48:29.350 Status: RFLink: 2 level: 7
2019-11-14 18:49:04.253 Status: LUA: Lamp Overloop AAN
2019-11-14 18:51:03.455 Status: LUA: Lampen Garage UIT, 2 minuten geen beweging
2019-11-14 18:51:03.456 Status: EventSystem: Script event triggered: GarageLampenUIT
Also did a reboot and change the lua to device but that didnt do anything.
Also made a fault, then the lua gives an error, so it looks like it IS reading the script but not executing?
Is it possible that Domoticz had changed the eventsystem / lua script readings?
Posted: Thursday 14 November 2019 20:39
by waaren
BarryT wrote: Thursday 14 November 2019 19:37 Is it possible that Domoticz had changed the eventsystem / lua script readings?
Not that I am aware.
If I test your script (after changing part of it)
from
to
    local url = 'curl http://192.168.192.109:8084/json.htm?type=command&param=getversion'
    print(tostring(data))
        print(line)
the result is
2019-11-14 20:35:18.298  Status: LUA: file (0x20c93b0)
2019-11-14 20:35:18.324  Status: LUA: {
2019-11-14 20:35:18.324  Status: LUA:    "status" : "ERR"
2019-11-14 20:35:18.324  Status: LUA: }
When changing to
    local url = 'curl "http://192.168.192.109:8084/json.htm?type=command&param=getversion" '
        print(line)
the result is
2019-11-14 20:37:28.376  Status: LUA: file (0xf0994898)
2019-11-14 20:37:28.402  Status: LUA: {
2019-11-14 20:37:28.402  Status: LUA:    "DomoticzUpdateURL" : "https://www.domoticz.com/download.php?channel=stable&type=release&system=linux&machine=aarch64",
2019-11-14 20:37:28.402  Status: LUA:    "HaveUpdate" : false,
2019-11-14 20:37:28.402  Status: LUA:    "Revision" : 10717,
2019-11-14 20:37:28.402  Status: LUA:    "SystemName" : "linux",
2019-11-14 20:37:28.402  Status: LUA:    "UseUpdate" : true,
2019-11-14 20:37:28.402  Status: LUA:    "build_time" : "2019-11-08 17:59:05",
2019-11-14 20:37:28.402  Status: LUA:    "dzvents_version" : "2.5.0",
2019-11-14 20:37:28.402  Status: LUA:    "hash" : "5c5f579c3",
2019-11-14 20:37:28.402  Status: LUA:    "python_version" : "3.7.3 (default, Apr  3 2019, 05:39:12) \n[GCC 8.2.0]",
2019-11-14 20:37:28.402  Status: LUA:    "status" : "OK",
2019-11-14 20:37:28.402  Status: LUA:    "title" : "GetVersion",
2019-11-14 20:37:28.402  Status: LUA:    "version" : "4.11476"
2019-11-14 20:37:28.402  Status: LUA: }
So one conclusion: the double quotes around the url do matter..
Posted: Thursday 14 November 2019 21:20
by BarryT
waaren wrote: Thursday 14 November 2019 20:39
from
to...
Wauw, hero! :-)
Well, there is something going on indeed:
2019-11-14 21:19:00.135 Status: LUA: file (0x72b3bbe0)
        lineNo = 0
        now    = 0
        temp   = 0
        today  = 0
        total  = 0
        v1     = 0
        v2     = 0
        i1     = 0
        i2     = 0
        i = 1
        i = i+1
    local url = 'curl "http://192.168.1.18/real_time_data.xml" '
        print(line)
                lineNo = 1
                lineNo = lineNo + 1
        data:close()
            ep = v1*i1
            wp = v2*i2
I guess i have to wait till tommorrow when its light?
I cannot fully check now because the ip is offline :(
Or.. is there a way (debug) to see if it try to open the curl "url" ?
Thanks so far :-)
Posted: Friday 15 November 2019 9:24
by BarryT
Getting this now:
2019-11-15 09:23:00.058 Status: LUA: file (0x6f502b68)
2019-11-15 09:23:00.136 Status: LUA: <?xml version="1.0" ?>
2019-11-15 09:23:00.136 Status: LUA: <real_time_data>
2019-11-15 09:23:00.136 Status: LUA: <state>Normal</state>
2019-11-15 09:23:00.136 Status: LUA: <Vac_l1>230.9</Vac_l1>
2019-11-15 09:23:00.136 Status: LUA: <Vac_l2>-</Vac_l2>
2019-11-15 09:23:00.136 Status: LUA: <Vac_l3>-</Vac_l3>
2019-11-15 09:23:00.136 Status: LUA: <Iac_l1>0.17</Iac_l1>
2019-11-15 09:23:00.136 Status: LUA: <Iac_l2>-</Iac_l2>
2019-11-15 09:23:00.137 Status: LUA: <Iac_l3>-</Iac_l3>
2019-11-15 09:23:00.137 Status: LUA: <Freq1>49.99</Freq1>
2019-11-15 09:23:00.137 Status: LUA: <Freq2>-</Freq2>
2019-11-15 09:23:00.137 Status: LUA: <Freq3>-</Freq3>
2019-11-15 09:23:00.137 Status: LUA: <pac1>38</pac1>
2019-11-15 09:23:00.137 Status: LUA: <pac2>-</pac2>
2019-11-15 09:23:00.137 Status: LUA: <pac3>-</pac3>
2019-11-15 09:23:00.137 Status: LUA: <p-ac>38</p-ac>
2019-11-15 09:23:00.137 Status: LUA: <temp>7.0</temp>
2019-11-15 09:23:00.137 Status: LUA: <e-today>0.01</e-today>
2019-11-15 09:23:00.137 Status: LUA: <t-today>1.0</t-today>
2019-11-15 09:23:00.137 Status: LUA: <e-total>2293.08</e-total>
2019-11-15 09:23:00.137 Status: LUA: <CO2>2286.20</CO2>
2019-11-15 09:23:00.137 Status: LUA: <t-total>6559.9</t-total>
2019-11-15 09:23:00.137 Status: LUA: <v-pv1>146.6</v-pv1>
2019-11-15 09:23:00.137 Status: LUA: <v-pv2>0.0</v-pv2>
2019-11-15 09:23:00.137 Status: LUA: <v-pv3>-</v-pv3>
2019-11-15 09:23:00.137 Status: LUA: <v-bus>359.8</v-bus>
2019-11-15 09:23:00.138 Status: LUA: <maxPower>43</maxPower>
2019-11-15 09:23:00.138 Status: LUA: <i-pv11>0.27</i-pv11>
2019-11-15 09:23:00.138 Status: LUA: <i-pv12>-</i-pv12>
2019-11-15 09:23:00.138 Status: LUA: <i-pv13>-</i-pv13>
2019-11-15 09:23:00.138 Status: LUA: <i-pv14>-</i-pv14>
2019-11-15 09:23:00.138 Status: LUA: <i-pv21>-</i-pv21>
2019-11-15 09:23:00.138 Status: LUA: <i-pv22>-</i-pv22>
2019-11-15 09:23:00.138 Status: LUA: <i-pv23>-</i-pv23>
2019-11-15 09:23:00.138 Status: LUA: <i-pv24>-</i-pv24>
2019-11-15 09:23:00.138 Status: LUA: <i-pv31>-</i-pv31>
2019-11-15 09:23:00.138 Status: LUA: <i-pv32>-</i-pv32>
2019-11-15 09:23:00.138 Status: LUA: <i-pv33>-</i-pv33>
2019-11-15 09:23:00.138 Status: LUA: <i-pv34>-</i-pv34>
Posted: Friday 15 November 2019 10:04
by waaren
BarryT wrote: Friday 15 November 2019 9:24 Getting this now:
This part looks about right.
I see two other (potential) problems in your script.
- The script assumes certain values on fixed line numbers. Even it would do the job now (which is doesn't) it will fail whenever something changes in the return.
- The script uses match on number to extract the values from the output but the XML tags also contain numbers. It will fail on some of the fields.
See this example:
Lua 5.3.3  Copyright (C) 1994-2016 Lua.org, PUC-Rio
> a = ' <Freq1>49.99</Freq1>'
> string.match(a, "%d+")
1 -- Not what was expected ?
line = '<Freq1>49.99</Freq1>'
49.99 -- Here it does the job
Maybe better to change to something that takes the tags into account.
This function takes a line and a tag as input and return the value between the tags.
local function getValueFromTag(tagLine, tag)
    local _, beginValueString = tagLine:find(tag)
    local _, endValueString = tagLine:find('<', beginValueString)
    return tagLine:sub(beginValueString + 1, endValueString - 1)
Posted: Friday 15 November 2019 11:00
by BarryT
waaren wrote: Friday 15 November 2019 10:04
See this example:
Thanks man!
But what now?
Do i need a new script or...?
I wish lua was a bit easier to understand.. haha
Posted: Friday 15 November 2019 11:16
by BarryT
I used another script, its working now!
Thanks for your help Waaren :-)
local now    = 0
local bNowUpdated = false
local temp   = 0
local bTempUpdated = false
local today  = 0
local bTodayUpdated = false
local total  = 0
local bTotalUpdated = false
local ip     = '192.168.1.18'    --customize this to your invertor IP
local i = 1
            i = i+1
    --print(string.format("http request from SAJ: %s", data))
    local LineNr = 0
--    print(tostring(data)) -- debugging
--    print(data) -- should show something like 'file (0x42e0f8)'
--    print(line) -- should print all lines of the return of the url
        LineNr = LineNr + 1
        if( string.find(line, 'temp') ~= nil)
        then
            --print(string.format("line %d: %s", LineNr, line))
            bTempUpdated = true
        elseif( string.find(line, 'e%-total') ~= nil)
        then
            bTotalUpdated = true
        elseif( string.find(line, 'e%-today') ~= nil)
        then
            bTodayUpdated = true
        elseif( string.find(line, 'p%-ac') ~= nil)
        then
            bNowUpdated = true
    data:close()
    if( bTempUpdated==true)
    then
        --print(string.format("updating SAJ temp:%4.1f",temp))
        UpdateDevice('Temperatuur SAJ', temp)                          --customize the temperature sensor name
    if( bNowUpdated==true and bTotalUpdated==true)
    then
        --print(string.format("updating SAJ energy:%d %d",now, total*1000))
        UpdateDevice('PV SAJ', now..";".. total*1000)       --customize the energy sensor name
--        local ep = v1*i1
--        local wp = v2*i2
		-- Upload the data to PVoutput every 10 mins
		-- date = os.date("*t")
		-- if (date.min % 10 == 0) then
		--     baseURL="http://pvoutput.org/service/r2/addstatus.jsp?"
		--     API="yourAPIkey"
		--     PVO_URL= baseURL .. "sid=36263&key=" .. API .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M")
		--     PVO_URL = PVO_URL .. "&v1=" .. (today*1000) .. "&v2=" .. now
		--     commandArray['OpenURL'] = PVO_URL
		-- end
