I install Domoticz on my Synology DS214.
Everything works perfectly.
Is it possible to access this application from the web using quickconnect.to?
Example: http://QuickConnect.to/name/domoticz or other?
Thank you in advance for your help.
Best regards
Otto Haldi
Synology -> http://QuickConnect.to/name/domoticz?
- waaren
Re: Synology -> http://QuickConnect.to/name/domoticz?
Yes, if the port for domoticz is 8084, you can use something like http://QuickConnect.to/name:8084 (if port 8084 is forwarded by your router to your internal synology IP)ohaldi wrote: Wednesday 13 November 2019 18:43 I install Domoticz on my Synology DS214. Is it possible to access this application from the web using quickconnect.to?
ohaldi
Thanks for your help.
With my Asus Router this work with http://name.asuscomm.com:8084
But I like to know it it's possible to uses the DDNS form my DS214!
With http://quickconnect.to/name:8084 this does not working.
also http://ateho.quickconnect.to:8084
Otto
Otto
