Page 1 of 5
Dashticz v3.2.0 beta
Posted: Saturday 09 November 2019 11:15
by Lokonli
I've just pushed v3.2.0 beta to Github.
Before updating read the release notes:
https://dashticz.readthedocs.io/en/beta ... s.html#id1
and upgrade instructions:
https://dashticz.readthedocs.io/en/beta ... ial-blocks
Most important: For your buttons you have to rename your image parameter from 'image' to 'btnimage'
Main change:
* Standardization of the html template for special blocks.
Other changes:
* Enable swiper for mobile devices
* Update to swiper 5.2.0
* Bundle most external dependencies (webpack, babel, package.json)
Fixes
* Calendar: Improved handling for recurring events
* Blinds: Fix for custom icons
You can update to this version with:
Update:
The Chromecast module contains a bug and is temporarily disabled.
Update 2:
The swiper functionality has been updated. Two config settings have been added to control swiping and scrolling behavior:
config['vertical_scroll'] = 2;
config['enable_swiper'] = 2;
See
https://dashticz.readthedocs.io/en/beta ... ation.html
This should solve most of the issues with the new swiper component.
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 12:27
by EdwinK
I only get the dashticz v3 is loading thingy, then everything went black
Update: I'ts working again. Needs to do some changes though.
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 15:26
by jake
I updated as well and after this:
the weather icons are not showing anymore and the buienradar button doesn't show the picture anymore (the previous version 3.1.2 worked fine):
By using the developer mode in Chrome:
Uncaught ReferenceError: Skycons is not defined
at eval (eval at globalEval (bundle.js:202), <anonymous>:1:15)
at eval (<anonymous>)
at Function.globalEval (bundle.js:202)
at domManip (bundle.js:213)
at jQuery.fn.init.append (bundle.js:213)
at jQuery.fn.init.<anonymous> (bundle.js:213)
at access (bundle.js:213)
at jQuery.fn.init.html (bundle.js:213)
at HTMLDivElement.eval (eval at globalEval (bundle.js:202), <anonymous>:138:54)
at Function.each (bundle.js:202)
RadarMapNL:1 Failed to load resource: the server responded with a status of 404 (Not Found)
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 15:42
by Lokonli
jake wrote: Saturday 09 November 2019 15:26
For the button probably you have to rename the image parameter to btnimage
I'll check the skycons
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 15:54
by Lokonli
Somehow only the static weather icons are working. Temporarily you could add the following to CONFIG.js:
config['static_weathericons'] = 1;
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 16:17
by pvklink
After upgrade
all my 4 pages are one long vertical page and no swiping buttons
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 16:23
by Lokonli
Lokonli wrote: Saturday 09 November 2019 15:54
Skycons have been fixed.
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 16:25
by Lokonli
pvklink wrote: Saturday 09 November 2019 16:17
After upgrade
What kind of device do you have and which browser are you using?
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 16:33
by pvklink
I use my dashticz on a rpi 3b with the latest buster and latest beta of domoticz and dashticz
On my pc i use chrome and i also tried edge..
I clear the cache and after that nothing works anymore...
i get Dashticz v3 is loading...
no errors nothing...
i also tried
1. cd /home/pi
2. git clone
https://github.com/Dashticz/dashticz dashticz --branch beta
3. copied my custom folder back
no screen, only loading
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 16:48
by jake
@Lokonli Nice, both issues solved, the weather icons by a 'git pull', the buienradar by changing image to btnimage. Shall I update the wiki for this image thing? I guess this is a recent design change that forces everybody to upgrade their CONFIG.js?
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 16:55
by Lokonli
jake wrote: Saturday 09 November 2019 16:48
That was the goal of the link in the first post to the upgrade instructions ...
The wiki is not maintained anymore.
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 17:11
by Lokonli
pvklink wrote: Saturday 09 November 2019 16:33
i also tried
1. cd /home/pi
2. git clone
If you press F12 to open the Developer Window do you see any error on the console tab?
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 17:26
by pvklink
see attachment..
i do have a working copy 3.1
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 17:35
by Lokonli
In v3.2.0 most dependencies are bundles into bundle.js. I see somehow the files still are requested, which should not happen.
It seems you have an old index.html. Did you try to refresh the cache?
or:
How did you install Dashticz? Which www server are you using?
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 17:39
by pvklink
i first did a git pulll...
that did not wend ok..
after that i renamed the folder to old and then
cd /home/pi
2. git clone
3. copied my custom folder back and indead an old index file !
Can i
1. rename the folder again to old2
do another git clone
and only copy the custom folder ?
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 17:57
by Lokonli
pvklink wrote: Saturday 09 November 2019 17:39
cd /home/pi
2. git clone
Can i
That should work I guess.
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 18:28
by pvklink
Ok, i solved almost everything!
i did a git pull and after that my screen was a chaos.
so i did a new install etc. etc... and copied the old custom files back, and again a chaos screen!
i enabled column by columns (4 pages) and...
i had one line with 'chromecast' in it...I did not use this anymore and removed the plugin longtime ago in domoticz because it was unstable
it was still in the column line and with 3.1 this is no problem, but with 3.2 all kind of switches are missing ...
columns[7]['blocks'] = [publictransport.ovinfotrain,publictransport.ovinfotram,tvguide.dutch,'chromecast','streamplayer',1749,1750,1473]
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 19:03
by HansieNL
pvklink wrote: Saturday 09 November 2019 18:28
Does your custom.js contains these lines?
function afterGetDevices(){
function getExtendedBlockTypes(blocktypes){
//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
return blocktypes;
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 19:06
by pvklink
This is my js file, so YES !
// add custom javascript in here
// http://192.168.20.35:82/json.htm?type=devices&rid=982
// check properties en kijk welke wijzigt evt lastupdate nemen
// "Usage" : "3 Watt", neemt js wel t getal en heeft het geen last van Watt als text?
function afterGetDevices(){}
return blocktypes;
//0,8 was 1864_1 veranderd naar 1864 en Usage verander naar value
function getChange_1864(idx,value,device)
if(parseFloat(device['value'])>1){blocks['1864']['icon'] = 'fas fa-thermometer-full';}
else {blocks['1864']['icon'] = 'fas fa-thermometer-half';}
//function getStatus_1474(idx,value,device)
//if (device.Data == "On") {blocks[1474]['title'] = "Zon op"}
//else {blocks[1474]['title'] = "Zon onder"}
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 19:23
by HansieNL
pvklink wrote: Saturday 09 November 2019 19:06
return blocktypes;
Have you read the upgrade instructions from the 1st post? You have to change the icon names for the special blocks. You already have renamed them?
