Script help; rgb 255,0,0 on for 2 sec
Posted: Sunday 03 November 2019 10:59
by domogijs
I need some help with my script.
I have a co2 meter and if the value is to high i want a lamp to turn red for 2 seconds. This lamp can be already on (white) or off. After the 2 sec i want the lamp back on his original state.
I tried this with this script:
on = { devices = { "CO2" }},
Ikea = domoticz.devices(792)
if (domoticz.devices('CO2').co2 > 1250) then
Ikea.setColorBrightness(255, 0, 0).forSec(2)
but i get this error
2019-11-03 10:53:31.897 Status: setcolbrightnessvalue: ID: 318, bri: 100, color: '{m: 3, RGB: ff0000, CWWW: 0000, CT: 0}'
2019-11-03 10:53:31.880 Error: dzVents: Error: (2.4.29) An error occurred when calling event handler Co2 test
2019-11-03 10:53:31.880 Error: dzVents: Error: (2.4.29) .../domoticz/scripts/dzVents/generated_scripts/Co2 test.lua:10: attempt to call field 'forSec' (a nil value)
any ideas how to fix this?
Greets Gijs
Re: Script help; rgb 255,0,0 on for 2 sec
Posted: Sunday 03 November 2019 11:32
by waaren
domogijs wrote: Sunday 03 November 2019 10:59
Below script could do the job. Not tested with Ikea bulbs but works with hue and other RGBW device types.
local myDelay = 2 -- seconds delay before restoring old color
local function restoreColor(device, delay)
local url = dz.settings['Domoticz url'] ..
'/json.htm?type=command¶m=setcolbrightnessvalue' ..
'&idx=' .. device.id .. '&brightness=' .. device.level .. '&color=' .. device.color
dz.openURL(url).afterSec(delay)
device.switchOn().afterSec(delay + 0.3 --Force store of device.color in domoticz database
dz.log('Color will be restored to ' .. device.color .. '( brightness: ' ..device.level ..') after ' .. delay .. ' seconds.',dz.LOG_DEBUG )
restoreColor(Ikea, myDelay)
myLight.setRGB(255,0,0)
Posted: Sunday 03 November 2019 13:18
by domogijs
Thanks, i get a few errors, but i will try to solve it
Posted: Sunday 03 November 2019 13:34
by waaren
domogijs wrote: Sunday 03 November 2019 13:18
Majority of the errors will go away if you add
directly after the execute = line
I am too lazy to type domoticz that often
Posted: Sunday 03 November 2019 14:09
by domogijs
i dont understand this one; myLight.setRGB(255,0,0)
should i make a local variable for this one ore something?
Posted: Sunday 03 November 2019 14:16
by waaren
domogijs wrote: Sunday 03 November 2019 14:09
This was a left behind from my example.
Please try this one.
execute = function(dz, item)
local Ikea = dz.devices(792)
if item.co2 > 1250 then
Ikea.setRGB(255,0,0)
Posted: Monday 04 November 2019 23:20
by domogijs
Thanks, tried to make it work but bumbing from error to error (sorry; noob)
This is the status
local dz = domoticz
local delay = 2 -- seconds delay before restoring old color
if (domoticz.devices('CO2').co2 > 500) then
device.switchOn().afterSec(delay + 0.3) --Force store of device.color in domoticz database
restoreColor(Ikea, delay)
gives error: Error: (2.4.29) ...e/pi/domoticz/scripts/dzVents/generated_scripts/CO22.lua:14: attempt to concatenate field 'level' (a nil value)
Posted: Monday 04 November 2019 23:40
by waaren
domogijs wrote: Monday 04 November 2019 23:20
Suggest you start with this one and after every change check if it still works.
if item.co2 > 500 then
dz.log('Color will be restored to ' .. device.color .. '( brightness: ' ..device.level ..') after ' .. delay .. ' seconds.',dz.LOG_FORCE )
