Script help; rgb 255,0,0 on for 2 sec
domogijs
Post by domogijs »
I need some help with my script.
I have a co2 meter and if the value is to high i want a lamp to turn red for 2 seconds. This lamp can be already on (white) or off. After the 2 sec i want the lamp back on his original state.
I tried this with this script:
    on = { devices = { "CO2" }},
        Ikea = domoticz.devices(792)
        if  (domoticz.devices('CO2').co2 > 1250) then
            Ikea.setColorBrightness(255, 0, 0).forSec(2)
but i get this error
2019-11-03 10:53:31.897 Status: setcolbrightnessvalue: ID: 318, bri: 100, color: '{m: 3, RGB: ff0000, CWWW: 0000, CT: 0}'
2019-11-03 10:53:31.880 Error: dzVents: Error: (2.4.29) An error occurred when calling event handler Co2 test
2019-11-03 10:53:31.880 Error: dzVents: Error: (2.4.29) .../domoticz/scripts/dzVents/generated_scripts/Co2 test.lua:10: attempt to call field 'forSec' (a nil value)
any ideas how to fix this?
Greets Gijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
Re: Script help; rgb 255,0,0 on for 2 sec
domogijs wrote: Sunday 03 November 2019 10:59 Hi
Below script could do the job. Not tested with Ikea bulbs but works with hue and other RGBW device types.
         local myDelay = 2 -- seconds delay before restoring old color
            local function restoreColor(device, delay)
                local url = dz.settings['Domoticz url'] ..
                            '/json.htm?type=command&param=setcolbrightnessvalue' ..
                            '&idx=' .. device.id   .. '&brightness=' .. device.level .. '&color=' .. device.color
                dz.openURL(url).afterSec(delay)
                device.switchOn().afterSec(delay + 0.3 --Force store of device.color in domoticz database
                dz.log('Color will be restored to ' .. device.color .. '( brightness: ' ..device.level ..') after ' .. delay  .. ' seconds.',dz.LOG_DEBUG )
            restoreColor(Ikea, myDelay)
            myLight.setRGB(255,0,0)
domogijs
Post by domogijs »
Thanks, i get a few errors, but i will try to solve it :)
domogijs wrote: Sunday 03 November 2019 13:18 Thanks, i get a few errors, but i will try to solve it :)
Majority of the errors will go away if you add
local dz = domoticz
directly after the execute = line
I am too lazy to type domoticz that often :)
domogijs
Post by domogijs »
i dont understand this one; myLight.setRGB(255,0,0)
should i make a local variable for this one ore something?
domogijs wrote: Sunday 03 November 2019 14:09 i dont understand this one; myLight.setRGB(255,0,0)
This was a left behind from my example.
Please try this one.
    execute = function(dz, item)
        local Ikea = dz.devices(792)
        if  item.co2 > 1250 then
            Ikea.setRGB(255,0,0)
domogijs
Post by domogijs »
Thanks, tried to make it work but bumbing from error to error (sorry; noob)
This is the status
        local dz = domoticz
         local delay = 2 -- seconds delay before restoring old color
        if  (domoticz.devices('CO2').co2 > 500) then
                device.switchOn().afterSec(delay + 0.3) --Force store of device.color in domoticz database
            restoreColor(Ikea, delay)
gives error: Error: (2.4.29) ...e/pi/domoticz/scripts/dzVents/generated_scripts/CO22.lua:14: attempt to concatenate field 'level' (a nil value)
domogijs wrote: Monday 04 November 2019 23:20 Thanks, tried to make it work but bumbing from error to error
Suggest you start with this one and after every change check if it still works.
        if item.co2 > 500 then
                dz.log('Color will be restored to ' .. device.color .. '( brightness: ' ..device.level ..') after ' .. delay  .. ' seconds.',dz.LOG_FORCE )
